maukka
(maukka)
202
You okay in there
edit: doesn’t seem to be close to Bali
clemence
(clemence)
203
Yes, I’m okay. Thanks for checking Maukka. We’re in alert mode and stay away from the river and shoreline. Sulawesi shares the same tectonic plate with Bali.
- Clemence
Hi !
Not sure how PM work here ;-) so i prefer to double : I'd like to have a lights kit (you have a PM)
I was able to use maukka's calibration light with the Texas Ace Calibrated Lumen Tube in a review
HERE
Hi Maukka,
I was wondering something. When you use your sphere to test flashlights do you put them on that post in the center of it or do you shine them in thought a hole on the outside? Also does your sphere have a baffle that prevents light from hitting the sensor directly? If yes do you have a picture? Thanks
maukka
(maukka)
207
I use the side input port with an additional diffuser. The post inside the sphere is for omnidirectional light sources such as LED/incan bulbs. There’s a baffle between the light source and sensor port.
Ok, thanks. When you put it in from the side is the flashlight butting up against the added diffuser or a piece of glass to make the insertion depth the same each time? Or does that even matter?
maukka
(maukka)
209
Exactly, the bright end of the light is a couple millimeters inside the sphere pushed against the diffuser. The insertion depth doesn’t really matter as long as it’s not outside the sphere and the depth is the same as when I measure the absorption effect of the light itself with an auxiliary light. The consistency is useful though when measuring several similar lights as I don’t have to measure the absorption for all of them.
DB_Custom
(Dale)
210
Hi Maukka, I am interested in getting your calibration set… 3 of us here in Texas with boxes built from the same source have been talking and we’d like to test our boxes with the same two lights, so we will compare our P-Trap light boxes and see where we all stand based on a single set of calibration lights.
Please inform…
maukka
(maukka)
211
Sure, I’ve got two sets ready to go immediately. Will PM you the details.
ktown
(ktown)
212
I’m interested in purchasing one, and sent a PM asking for the paypal details. Thanks.
DB_Custom
(Dale)
213
Maukka has sent these calibration lights my way, 3 of us will be testing with them here in Texas soon, will report…
MRsDNF
(MRsDNF)
214
Hi Maukka. Do you have any left to sell?
ZozzV6
(ZozzV6)
217
Hi Maukka! Will you make more of these calibration lights? I consider buying a pair early next year.
maukka
(maukka)
218
I have some lights left, but haven’t measured them yet.
SKV89
(SKV89)
219
Maukka, I would like to send some Jetusolis to you to get some calibration readings. Optisolis makes for a better calibration light. How much would you charge for that? Thanks.
maukka
(maukka)
220
15 euros per light + 7.50 euros for shipping.
Do you already have those lights from Clemence?
