Sad to see these monsters go, but I need to recoup some funds. Prices are FIRM, no lower, no trades(unless you got something SUREFIRE…)
1: Trustfire z6vn [$55 shipped]: (original thread) NEVER CARRIED show off only, have 3 different lens that will go with, including the Ahorton.
- Direct Driven Single mode for simple UI and max brightness.
- XML2 Dedome on 20mm Copper Heat Sink
- Pull 4.0A+ on regular protected cells. 1420 LED Lumen
- Pull 5.5A+ on 20r 18650. 1700 LED Lumen
- 4.2V max single 18650 only
- Tail cap switch tweaks
2: MTG2 p60 drop in (no host) [$55 shipped]: (made by Vinh) NEVER CARRIED show off only, this thing is STUPID BRIGHT, and gets VERY HOT VERY FAST.
- 5000k MTG2 on custom fit copper star
- Pull +6.5a on 20r 18650’s ~3000 LED Lumen
- 2x 18350/18650 MAX (8.4v)
- Heavy orange peel reflector
- Tightly wrapped with copper foil
- 30sec MAX run time on fresh 20r’s, any other cells should be fine to run for as long as you can hold onto it. I HIGHLY recommend a good heat sinking head: Solarforce a001, Cryos cooling bezel, FM cooly, etc.
**These are absolute MONSTERS!! Not toys! Don’t leave unattended, don’t loan them out, dont use them carelessly. They are direct drive, absolutely no circuitry. Use at your own risk. I’m not responsible for fires, explosions, or apocalypses.
