4. WUBEN Brightest Rechargeable Flashlight 12000 High Lumens Super Powerful Torch with 3PCS CREE XHP70.2 LEDs and 10200 mAh Battery Pack for Flashaholics - A9 Light of Dual UI Ramping and Regular Mode
$50 off code: 2HFSLVZW, plus 5% off Prime Day special coupon, after discount price $189.99 (was $249.99)
While we are on the subject of TO46R- I have 3 of these and they all have different emitters. Mountain Electronics sells 20mm triple emitter boards in various LED flavors making an emitter swap incredibly easy.
I have these three:
MTN3XP-219C-D240
3XP-XPL-HI-U4-3K
MTN3XP-LH351D-4K
If you want to try different emitters but don’t feel confident, or have the tools, to do a complicated emitter swap, this light is a great choice. All you need is a basic soldering iron to detach and reattach the wires at the LED board.
1- Remove the tailcap and remove the battery.
2- Remove the bezel.
3- Gently blow into the open battery tube from the tail end and the air pressure will pop out the lens assembly.
4- Unsolder the wires at the LED board.
5- Remove the LED board and set the replacement in it’s place.
6- Solder the wires back onto the replacement.
7- Reassemble the lens, o-ring, & bezel.
That’s it. About as easy as it gets.
