Wurkkos FC11C 5000K - Stubby Edition
Always liked Lego.
Some interesting data for FC11C 5000K with 18350, 850 mAh Sofrin battery:
  • It will produce some 350 lm·h on High and close to 500 lm·h on Med.
  • Some 35 min main regulated runtime on High (550 lm), ~2 hours on Med (250 lm), and perhaps 10 hours on Low (50 lm).
  • All three modes work for extra ~15 min in reserve at 30 lm after the final step-down and before the LVP shuts the light off.
  • Red battery indicator starts blinking constantly at some 3% battery left, which coincides with the final step down to the reserve level.
  • Green battery indicator turns red quite early on at some 70% battery remaining.
  • Click-Hold to get from Turbo to Low, rather than to Off or Memory with Click.
  • Quality of light is pretty awesome.
9 Thanks
I was going to ask a technical question but it seems irrelevant given you have a label for “USB flap circumcision” :rofl:
Nice color combo. I’m EDCing one of those and man it does give me range anxiety.
I used scissors.
Any specifics on this “switch firming mod”? Sounds like something I’d like to do with mine 2 FC11Cs :grin:
While Sofirn’s 18350 battery isn’t a slouch, something like Vapcell M11v2 may give it extra runtime (haven’t tried it yet).
The simplest and quickest reasonable comparator would be timing it on High (~1.25A). I got some 37 min @~550 lm + 15 min reserve @~30 lm with the Sofirn 18350, 850mAh label.
What batteries do you use?
Just some random 900mAh 18350 cell. It does shrink the size of the light substantially. But 900mAh vs 3400mAh is no comparison. The 18350 light remains a toy light to me.
I just received my green 519A version of Sofirn SP31V3 and this thing slaps. It has replaced the FC11C as my EDC. So many good design decisions. I might need a new post to talk about them. The beam has so much more punch, which I sorely miss for almost all of my 519A lights.
Did you swap the LEDs? I wonder how different the beam pattern is compared to the FC11C. Also, does one needs to click the tail switch first to operate the side switch, or are they independent?
Vapcell H16 might be a nice one to use. This one is almost half of 18650.
That said somehow i personally prefer 18650 tube. It just feels right in hand, while 18350 is too short. And i am fine with it being longer in a pocket…
No LED swap. It came with 5000k 519A in stock configuration. The beam is tighter with brighter, well defined hot spot and fainter but wider spill.
The tail switch is a mechanical forward clicky, which controls on/off state and side switch only changes modes. There is a short cut to moonlight by holding side switch while clicking the tail switch. The forward action makes it very easy to momentarily turn the light on by half holding without clicking all the way.
It’s a tactical UI, which is different to normal e-switch UI. It needs some getting used to but the operation is a faster and more snappy since mode change is a click and on/off also a click on a different button. Normal e-switch UI mode change means holding a button and wait for the mode to cycle through.
There is some voodoo magic which allows the USB-C port to charge the battery even when the tail switch is off, which is supposed to cut the circuit to the battery. I suspect some reverse connected diode or similar circuit in the tail switch to allow that to happen.
The only option I can see on Sofirn’s website is SST40 (6500K presumably)?
@FunkyRider86
Question regards the SP31 v3; Do you encounter any ‘delay’ while engaging the tailswitch? Like with sp31v2 and wurkkos fc12?
Cheers🔦
Green - 519a
https://www.sofirnlight.com/products/sofirn-sp31v3-1200-high-lumen-tactical-flashlight-high-cri-green-flashlight-with-buck-constant-current-circuit
Black - SST-40
https://www.sofirnlight.com/products/sofirn-sp31-v3-0-tactical-flashlight
Emitter is not the only difference
Ah… Thank you! I looked at specs, trying to figure out the difference in throwiness between the two flashlights, apart from the reflector vs. TIR optics.
It looks like FC11C is just a tad less throwy than SP31v3 Green with max intensities of some 6000 vs. 7000 cd and the beam ‘concentration factor’ of ~5 vs ~6 cd/lm.
Are you seeing a big difference between the two?
Also, having to operate both switches, isn’t it awkward? Never had a lamp like this, but I recon there are lights like some Acebeams with two switches: side to do everything and tail for Turbo at all costs. That sounds more convincing, but I don’t really know.
Sorry, I don’t own none of SP31v3.
Oh, I’m sorry, it was @FunkyRider86 that I was after.
After putting on the original reflector for the FC11C, I did some crude test using my phone lux meter. At the same distance and medium mode, save for the different CCT of 4000k vs 5000k, FC11C measured 540 lux while SP31V3 measured 940 lux. That is a significant difference matching my outdoor test.
I might swap the FC11C emitter to a 5000k 519A and compare them more later.
The hotspot of SP31V3 is also bigger but has a defined border, basically a circle of light with fainter corona. In real world the beam gives a lot of ‘punch’ to illuminate objects further. As some reviewered said, it is a medium distance beam and for a single 519A it is very impressive.
Perhaps it’s the LED CCT that makes more of a visual difference then the optics + maybe the Medium is set at a different level?
The way I see it, the best course of action for you would be buying another FC11C, orange this time, with a black 18350 tube, in 5000K, and compare the two directly :slight_smile:
