Thank you @L37 for your response!
I apologize for not making myself more clear. My idea is to replace Anduril Simple mode with the exact UI you prefer.
Basic 1C for on, 1C for off, hold to change modes, 1H from off for moonlight, 2C from anywhere for turbo. And mode memory along with ability to go from moonlight into main group (basically bypass memory). I do not need anything else and also generally prefer stepped brightness (moonlight + 3-4 main modes + turbo is sufficient).
This is totally doable, and dare I say, would not be difficult to implement (I would even volunteer to implement it).
anduril would be acceptable if it was possible to disable shortcuts like 2H momentary turbo, basically everything but what’s listed above. And also have complete configuration lock (basically read-only eeprom) which can only be disabled in a very deliberate way, not possible to trigger by bad inner tube contact or any other user action or malfunction…
Perfect. So, what about a light that comes right off the box with the UI you described, and to switch to Anduril, would need to be clicked exactly 11 times (with the clicks spaced at exactly once per second), then click-and-hold for exactly 5 seconds, then immediately clicked exactly 11 times more (again with the clicks spaced at exactly once per second), and then click-and-hold for exactly 5 seconds again? Would that be acceptable? If not, I’m pretty sure any sequence you deem good enough could be implemented, please just state the one you’d prefer.
Without having to modify/compile/flash firmware.
I totally agree, dealing with firmware is something that definitely should not be required for users that don’t want Anduril in their lights.
So, what do you say?
