Hello everyone,
Wurkkos has just launched their first (21700) headlamp, called HD20. This new flashlight offers a quite fresh, new and unique design by combining two emitters with an L-shaped angle-head tool lamp design. It is designed for a variety of indoor and outdoor activities like camping, hiking, fishing or hunting. With the supplied headband it can also be used as a headlamp. It is powered by a single 21700 lithium-ion rechargeable battery, is rechargeable via USB-C (both type A-C and C-C cables) and can also work in reverse as a powerbank to charge external USB-devices. 18650 batteries can be used as well. Moreover, HD20 comes with an adjustable lanyard, a magnetic tailcap and a sophisticated user interface - developed in collaboration with BLF members - for flexible and convenient one hand operation. Samsung’s LH351D and Cree’s XP-L HD emitter in neutralwhite tint (5.000K) enable HD20 to provide both spotlight and floodlight in one single flashlight. Using 90CRI for floodlight result in great color rendition at close ranges.
You may want to check out a very thorough, honest and extensive review of HD20 here on BLF, made by our fellow member Lumeniac:
[Review] Wurkkos HD20 aka Sofirn HD20 (dual light, 21700, Type-C, magnet, HiCRI, 5000K)
Technical discussions about HD20 and its development can be found here:
[Update]Wurkkos dual LEDs 21700 Headlamp design Photos/UI update~
Wurkkos is so kind to offer a nice promo discount for BLF members :-)
Green version of batch #2:
Specifications
- Emitter: 1x Samsung LH351D 5.000K 90CRI + 1x Cree XP-L HD 5.000K 70CRI
- Operating voltage: 2.7V – 4.35V
- Battery options: 1x 21700 or 1x 18650 lithium-ion battery
- Dimension: 122mm (length) x 30mm (head diameter)
- Weight: 130g / 0.28lb (without battery)
- Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
- Water resistance i.a.w. IP-68 (up to 2m / 6.56 ft. under water)
- Reverse polarity protection to protect against improper battery installation.
- Advanced Temperature Regulation (ATR) technology: ATR automatically reduces the brightness level when the driver temperature reaches 60°C to prevent overheating
- Low voltage warning
- Comes in black and army green (with batch 2); brown will not be produced in series
As of 06/2021:
If you have any questions or comments, no matter if commercial or technical, please contact Wurkkos directly. Thank you for your understanding.
https://budgetlightforum.com/user/32168
https://budgetlightforum.com/user/38972
