Specification:
1.Material:6061 aircraft-grade aluminum alloy
2.Lens material:Toughened glass lens with AR coating
3.Voltage: 2.8-6Volts
4.Color temperature:5000K-5500K(white)
5.Output:Low(60LM)/Medium(350LM)/High(1000LM)/Turbo(2000LM)
6.Light cup:orange peel reflector
7.LED bulb:Cree XHP35 HD LED
8.Mode memory:Yes
9.Waterproof level:IPX-8,underwater deep: 150m/164yd
10.Dropping test:1m/3.28ft
11.Lighting distance:300m/328yd
12.Size:head:40mm(1.57in) *body dia.:25mm(1in)*length:144mm(5.67in)
13.Weight:0.39lb(not include battery)
14.Battery used:1* 18650 3.7 Volts Li-ion lithium battery
一,Why you choose our Wurkkos 2000 lumen scube diving flashlight?
1.Our Diving Flashlight is designed for the professional divers or under water Photographer.
2.-Super Bright illumination
3.-High waterproof level
4.-Reverse polarity protection
5.–100,000 hours bulb lifespan
1)★Universal fit
It is an ideal choice for outdoor activities, such as night fishing, diving, swimming, hiking, sailing, caving hunting and seeking survival without fear of rainy days.
2)★Recharge indicator
Wen the volts lower than 3.2v,it will blink 3 times to remind you recharge or change battery.
3)★How to choose the light mode
Press the side switch to turn on or adjust light modes from low to high.
4)★Voltage protection
When the volt is higher than 4.4v it will not on.
5)★Warranty Guarantee
二,Wurkkos is the Authorized Seller.Each diving flashlight comes with a 1-year warranty & a 45 days money back guarantee. If you have any issue or suggestion with your light ,please do not hesitate to contact wk-us@foxmail.com ,your satisfaction is paramount!
三,★What you will get:
—1*diving flashlight
—1*18650 battery
—1*charger
—2*O-ring
—1*User Manual
—1*USB cable
—1*lanyard!
