Wurkkos TS10 Review ($20, High CRI, 14500, EDC Flashlight)
The Wurkkos TS10 was a light designed with input and feedback from forum members at BudgetLightForums (BLF) and the company. The idea ended up being an inexpensive triple-emitter flashlight with auxiliary LED’s powered from a 14500 battery to maintain a slim profile. Thanks to Wurkkos for sending me the black light here, I liked it enough, I bought this white MAO (Metal Arc Oxide) version myself when it was available for a brief time.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
Follow me on TikTok: liquidretro1 (@liquidretro1) | TikTok
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Find all my social media at liquidretro | Twitter, Instagram, Facebook, TikTok | Linktree
See my Amazon Store with my gear recommendations Liquidretro Reviews's Amazon Page
I also did a separate video https://youtu.be/wdQad-9HKmo on how to flash the firmware of the Wurkkos TS10 with Android thanks to u/the_gchart great hardware.
Links to Purchase
Wurkkos Direct WURKKOS FLASHLIGHT
AliExpress Store https://www.aliexpress.us/item/3256803886988095.html?spm=a2g0o.store_pc_promotion.promotePruductList_2003993329748.4&gatewayAdapt=glo2usa4itemAdapt&\_randl_shipto=US
Amazon
TS10 Silver: Amazon.com (Affiliate Link)
CODE: USTS10BSR 20% OFF +10% coupon on the Amazon Page
TS10 Black : Amazon.com (Affiliate Link)
CODE: liquidre 20% OFF +10% coupon on the Amazon Page
TS10 Red: Amazon.com (Affiliate Link)
CODE: TS10USBSR 20% OFF +10% coupon on the Amazon Page
Packaging & Accessories
The light comes in a Retail Wurkkos orange and white box. The only identifying info is a sticker on the side showing which model and options you have. Inside it comes in a plastic tray, and the accessories include a lanyard, clip and optional Wurkkos 14500 battery (recommended), as well as the manual.
Construction & Design
The light is made from aluminum mainly (There is a brass version too) with a number of configurations. The bodies come in 4 main body colors, Black, Red, Silver, and Green, with two LED tint choices 4000k and 5700k, as well as 4 aux LED colors, red, orange, ice blue, and green, and the final option is with or without a battery. I have the Black, with 4000k tint main LED’s and Ice Blue Aux here. Then I have this limited run of MAO finish that Wurkkos did with 4000k tint main LED and Orange Aux that I bought. The MAO finish looks great but isn’t the most durable as you can see from some of the marks and scratches on it.
The design itself is quite small at only 2 and 6/8ths inches long. I have AAA lights that are longer. The tail features a metal disk with rings for texter covering the button On both of my lights it’s gray, not body color which is a little disappointing. The tail is glued to the body tube for reliability I assume. In the hand, it works reasonably well for a cigar or pinch grip. There is no texture on the body so in some conditions it could be a bit slick. The head is simple with some milling for grip and style. There are a few too many markings on the light for me, with a warning, brand, and model number as well as a CE, ROHS, nonrecyclable symbol on the back, and a battery polarity symbol on the tail. There isn’t a serial number that I can find on the outside of the light.
Retention
Retention is where I deduct a few points for this light, and that’s mainly for the double-direction pocket clip. If I am going to EDC light, I use a pocket clip so it’s an important feature for me. The clip here could be deeper carry in the pocket in my opinion, it leaves about a ½” of the top of the light sticking out. It’s the pocket clip from the Sofirn SC21 and I had similar complaints there. The top hoop of the clip itself needs a bit more space for the material to maximize that deep carry ability, in my experience, it’s not enough to fit onto my jeans. Lastly, there is a bit of a shelf when putting it into your pocket for material to catch in prematurely. There are a few alternatives that the community has found fit, like the Olight Baton 3 clip, or Lumentop E05C clip that both carry deeper. There is also the option to attach a lanyard at the tail, but as you guys know that’s not really my thing.
Size & Weight
I measured the length of the light at 71.3mm, and a diameter of 21mm at the head. Weight with the included battery and clip at 1.79oz. The light is IPX8 water rated.
LED & Beam Profile
The TS10 is using 3X LatticePower CSP LED’s as its primary LED’s, and they are available in 4000k, and 5800k variants. There are also 3 secondary LED’s of various colors depending on what you order, these don’t have a brand mentioned. The colors available are Red, Orange, Blue, and Green. On the two examples, I have blue is brighter than Orange, and that’s not unexpected.
With my Opple Light meter, I measured the primary LED’s at 4152k and 96ra (CRI). DUV was good in my opinion and has an ever-so-slight orange tint. The beam profile is pretty good out of a triple LED light with an optic, it’s not perfectly round, and a larger hotspot for such a small light. As expected with an Anduril light, there is PWM here but it’s fast and not noticeable to my eye or camera.
Here are the outputs I measured on my lumen tube at the 30 second mark.
  • S1-NA
  • S2-7 Lumens
  • S3-52 Lumens
  • S4-300 Lumens
  • S5-1070* Lumens
Runtime & Heat
For my runtime tests I ran with the thermal configuration as the light arrived to me with the included Wurkkos battery for most of my tests. It was reported by others that the the light’s thermals were pretty accurate from the factory, and let’s face it most probably won’t be recalibrating this but know that you can, and that will improve how long it can sustain higher outputs. I also tested mine in a ramping mode which might explain why I didn’t see any step up in output like I would expect.
Turbo produced about 1250 peak lumens but within about 45 seconds stepped down to 150 lumens or so because of heat. Heat peaked at about 42C during this run, and this is factory setting. This is warm to the touch but quite safe. I probably should set it a bit higher and I will be messing with that after my review here. Total runtime was 2 hours 5 minutes at this lower output.
I tested the battery as well, It’s a claimed 900mAh and I tested it as 836mAh on my Vapcell S4 Plus charger. I then did my runtime graphs with a Vapcell H10 and had only minor differences, with the Vapcell battery recovering a little better and producing more light in the first 5 minutes of runtime but overall getting down to that lowest output at the end about 6 minutes earlier.
UI
This light uses Anduril 2 firmware. I won’t go into great details on how to operate it because I have done that on other videos but know that it can do nearly anything you want.
All that said the original version of the light shipped with a buggy firmware version (2022-02-08-0614) that meant the auxiliary LED’s stayed on during use of the primary LED’s, the larger problem was that the Auxilary LED’s had no Low Voltage protection. This would allow the light if the aux LED’s were on in high to drain the battery in a matter of days, potentially damaging the battery if it had no protection. Another thing the fixed firmware does is allow the lowest mode to be lower output.
The good news is this bug has been fixed on lights shipping the past 2 months, so if your buying one today especially from Wurkkos direct the light you receive should be fixed. If not I created a video on on how to flash the firmware with Android since the light does have exposed pogo pins. I will flash this black light here after filming the video.
https://i.imgur.com/ciZHxYP.jpg
Recharging
The light has no build in recharging. To recharge you will need an external charger. I have reviewed several here on the channel that would work well,
Conclusion
The Wurkkos TS10 is a really nice small EDC light in my opinion. It has a lot of the features that you typically have to step up in price to get, like auxiliary LEDs, high CRI in a slightly warm tint, a triple LED driver. It has enthusiast firmware that’s easily modifiable due to the exposed programming pads. It’s also relatively easy to do LED swaps on since the front bezel piece unscrews and gives access. There are a few Redditors that do this as a service for people wanting LED swaps.
As with most triples High and Turbo produce a lot of heat and don’t last very long. This isn’t surprising but like most people, I wish it would last a little longer. The clip is a disappointment all around, I suspect they used parts bin part to save cost, but I would gladly pay a few dollars more for a purpose-built clip here that worked better.
Overall it’s really a great value, with normal prices around $25 with battery, and if I get this video out soon enough you can even catch it for $20 on Singles day 11-11-2022 on Wurkkos AliExpress Shop. Any other coupons or deals I have I will put in the description below as well. I am sure some of you guys have this light already, so let me know what you think of it in the comments below.
I can’t see it in the spec here, could just be me on small iPhone screen…
But did you measure max current draw?
Just looking at getting a second battery,
Guessing no protection best ?
You should beable to pinch and zoom and search. I would buy a higher drain battery due to the type of driver being used here.
