Wurkkos TS11S - group toggle
Hi,
Just received the Wurkkos TS11S (the simple UI version) and really like it regarding form factor and light, BUT I fail to toggle to ramping mode.
Manual says to click 4 times from ON. Does not work. I do own the FC11 (which I can switch between ramp and stepped modes) and also am capable of clicking me through the modes of the Sofirn lantern, but the TS11S seems to be stuck in stepped modes.
Any ideas?
Thanks for your help.
Daniel
I do not have this particular light, but since the manuals are not always completely correct, you could try the method used to toggle between the Stepped and Ramping modes on the Wurkkos FC11 to determine if that will work for the TS11S, which is:
While the light is OFF, press and hold the switch for 3 seconds to toggle between the Stepped and Ramping modes. Two flashes of the light after 3 seconds will confirm the mode group has changed.
EDIT:
Just checked my Wurkkos FC13S and “hold from OFF” was the only way I could toggle between Stepped and Ramping modes, even though the manual says to use “4 Clicks while ON”, but it took about a 5 second hold instead of 3 seconds and I also did get two flashes of the light after 5 seconds confirming the mode group had changed.
That is the solution. Thanks a lot!
@Wurkkos Please update your manual for TS11S.
