arenat
(arenat)
1
Needing a two AA host ordered this one.
Emitter , generic Chinese's unknown characteristics
Body ; not like the C78 despite the similar look , a considerable less weight.
Pill ; here in my opinion is the advantage of this torch, the pill is larger with room to improve the heat management a bit.
Light output; don't ask..
Driver; died at the first try, look like the one cell which do not support two cells. Curiously the driver board has a red SMD emitter ..
The finish is ok , nice anodized
Switch ; pressed like some C78...
below the pill with a polished copper coin which fit perfectly pushed with a hammer...
So the driver died on the first try?
Sounds like a *FAIL* to me. That's a shame on a new light. Hopefully you can resusitate it.
arenat
(arenat)
3
No problem, I bought it for the parts , I'm planning putting an UV diode there, the one which came with this torch...
Only work with two cells.
arenat
(arenat)
4
A ticket was made, just to test PA's customer support...very easy made...lets see.
