Ive got a light running 2 26350 batteries with a mtn fet +1 driver pushing xhp50 would i be able to swap led with xhp70 or would the 26350 batteries be pushed to hard
If they are high drain cells they should be OK.
I dont think they are they were the ones from bangood im not sure but around 10amp
I built a C8 using that same driver with a XHP70 — those batteries pull 7.75 amps but ramp down rather quickly—I set a 40 sec turbo timer so it works out pretty well
When did c8s start taking 26350 batteries
It’s a Supfire L6 —- basically a C8 with a deeper reflector —this enabled me to use a brass pill / copper heat sink with a standard C8 OP reflector
