This is the item page I ordered: mouser XMLBWT-02-0000-000LT60E3. Hope this helps. Down to 142 in stock.
Now if we only knew the exact tint.. :D
He, he, down to 140…
How long until a p60 dropin? :nerd_face:
I am guessing 3C or close to it.
Does the XML2 emitter fit on regular XML MPCB’s? I wonder when will Intl Outdoor be stocking these?
They are available now from This guy
in p60 drop ins.
Thank you sir!
We do… sort of.
The last three numbers in the product code are the chromaticity, and it’s an “E3 KIT”. Which means they will be one of four 5000k region.
Either 3A, 3B, 3C, or 3D. — Luck of the draw which one.
Any would be okay with me.
The XM-L2 document refers to the XM-L document for chromaticity, and here’s where I found the information on page 10:
—— EDIT ——
It’s also an XM-L2 T6 bin, which should be pretty much identical in brightness to an XM-L U3 bin. (But this one is a NW!)
Ohhhhh!!! I just found two more XM-L2 options they have IN STOCK!!!
XM-L2 T5 (same approximate brightness as an XM-L U2)
Chromaticity kit 51… which unfortunately means it could be any of these cool-neutral white possibilities: 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S
Spin the wheel of binfortune!
XM-L2 T2
(same approximate brightness as an XM-L T4)
Chromaticity kit E8… which means it could be any of these warm white possibilities: 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4
They have a whole bunch of others listed as on order, so we’ll have to watch and see as they show up…
Probably important to remember that the 7135 option provides zero boost capability. Buck/boost would be awesome if harder and more expensive. A straight buck should be able to gain efficiency while providing similar capabilities.
When these are more prevalent, I am definitely ordering a pile of them.
ChiggerPeppi: I'm looking for something in the 1A-1D range, have you found something like that?
Yes, but they list it as “on order”
Here: XM-L2 U2
It’s the E1 Chromaticity group, which is: 1A, 1B, 1C, 1D
They also have an XM-L2 U2 in the E2 Chromaticity group on order. A slightly warmer cool white. 2A, 2B, 2C, 2D
These both show an estimated ship date of 12/31/2012.
They’re also the brightest bin listed available!
Well, thank you kind sir. :)
That's vinh. Very good modder. He did my 7G9 - highly recommend him.
Illumination Supply mentioned the XML2 on Facebook, so I asked them when they’re making them available and they said: “They will be available bare at first mid-next week”
Anyone offering these on a good copper star yet?
I want to drive one hard in my HD2010!
keep an eye on led-tech.de
