XP-E2 just can’t take the current that XP-G2 can. So at the same drive level, maybe an E2 can be a G2, I’m not sure, but I know a G2 is capable of beating an E2 when both are pushed to their limits.
These tests show the dedomed XPE2 and XPG2 will give similar throw numbers. And as mentioned above, the XPG2 has significantly more area and lumen output.
The new XPG2 does give lower throw numbers, but lots of them are within ~15% of the old style XPG2, so I would not consider them terrible. For example:
Yeah, I like E2s at 1.05A, maybe 1.40A if I want to push them. I like being able to keep them on 100% indefinitely and not have them cook.
Never used G2s before, so can’t say much if anything about them. They end up seeing at most Vbatt - 0.1V, not counting any IR drops in the switch, springs, etc. No idea how much current you can push through them on a single cell.
I have a dedomed XP-E2 R5 1A running on 6x 7135 = 2.1 Amperes in a Jacob A60.
Must say it works just fine.
The challenge is focussing the darn thing in the reflector…
Naw, all my E2s are on standard Al mcpcbs, not Cu, certainly not DTP. Most of the current would end up just as excess heat, not light. Even at 1.4A, the light curve is flattening out.
Like I said, I like my E2s unstressed, and able to run indefinitely. Kinda need to, in a 1-mode light.
Yes but OP is not talking about your light, he is talking about some other light, and he said he wants “max lux for throw” not “buy cheap aluminum e2 and run at 50% for mediocre throw”
I can find Djozz’s XP-E2 test, but i think he did test it, but i found a similar test of XP-E2 just now on DTP copper MCPCB and i.m.o. it’s not really worthwhile to exceed 2 Amperes.
Since the XP-G2 has roughly twice the size die, and it does pretty well above 4 Amperes, it will out throw the XP-E2.
But indeed, you’re not gonna get too far with a single cell linear driver, forward voltage is too high at that current.
At the maximum possible current the XP-E2 has less luminance than the XP-G2 including the newer ones. The Osram Black Flat beats all XP-G2s including the older ones. These things have been carefully measured in the German TLF forum. The XP-G2 only makes sense at really low currents and if the Osram Böack Flat is too much of a hassle (at low currents).
As I understand, part of the hassle (apart from the very inconvenient electrical connection between the thermal pad and led+ ) is that the variation of performance (output, current capability) is quite large and that you therefore have to buy a bunch of black flats and test them and pick the one that has that great performance.
