these ones? (both protected it seems)
http://www.tinywind.com/xtar-16340-650mah-protected-rechargeable-battery-p-15418.html
or these? (OOS)
http://www.tinywind.com/xtar-16340-600mah-rechargeable-battery-p-3687.html
When you double click from off, it goes directly into red, no white flash.
I have no comment on the batteries. I just use AW protected and IMR from what I had before. The compartment is big enough for the Solarforce cells, that are supposed to have higher capacity (because they are bigger and out of spec for 16340. I think they are supposed to be more like 17360).
I would like to purchase some of these but am unsure what the best dealer is yet.
I wonder if 18350 would fit?
Can you stuff 18650 inside of it, will it fit diameter wise :D?
18650 appear to be cheaper and come with higher capacity, though not protected.
Warzinak - one piece of this http://www.tinywind.com/product_info.php?products_id=15377
and three pieces of these http://www.tinywind.com/xtar-16340-650mah-protected-rechargeable-battery-p-15418.html .
But it looks like their sale is over, sorry!
However, you could try TW1YEAR coupon, if it works, you could probably save even more than when batteries were on sale :D!
However, they arent THAT costly anyway(OK, given their capacity and cost versus 18650, they ARE more costly
), try Chinaprices.us to compare prices among different Chinese vendors. Some of them, Tinywind, are not on Chinaprices comparator, so make sure you check prices among biggest stores if you dont see them in Chinaprices search results ;)!
No, 18350 will not fit… My 17340 LiFePO4’s do fit, but 18350 is just too big… ![]()
Thanks, good to know that now!
If anyone knows a reputable place to get a few of the Solarforce RC123 (actually like 17360) let me know. Suppsoed to be quite a bit higher capacity.
EDIT: unless this is the best place to get it. Cheap. Not sure about shipping cost.
http://www.solarforceflashlight-sales.com/product_detail.php?t=BC&s=23&id=364
That’s direct from the solarforce factory, not a reseller. Unless they changed it, shipping is a flat $2 per order.
Cool, trying to determine if they really are higher capacity though.
It does say that but in general and many found out with the new Nitecore EC11 and EA11 that use both Li-ion and Primary cells that is not the case., PLUS the Xtar advertisements recommend protected batteries - just not worth the chance.
How long is too long to wait for shipping to the USA? I ordered this light on August 12th, GearBest says they shipped it on August 13th. It’s now September 30th (7 weeks later) and I have not received it. I have very little experience with international shipping. I expect to have to wait a while, but this seems a bit extreme. Any advice? Should I continue to wait? Will it do any good to contact GearBest about it? Or am I likely just out of luck?
I appreciate any advice or comments as I’m kinda new to this. Thanks all.
Im in the same boat, I contacted them yesterday and they said to wait until 60 days(two months) pass and then I suppose they will reship or refund.
Ordered two of these in two different orders, I doubt they werent shipped and Im getting runaround.
Still, paid no tracking on both of my orders so no idea how far they are.
My Olight S15R arrived within two or three weeks, while other orders are taking more than a month and still in transit.
If not for the sale price, Id be very pissed at them, also, Paypal has 180 day coverage, so no stress about it either ;)!
Most of my stuff takes a month. That said, some stuff is now taking 7+ weeks. Lame. I pay for tracking but the details are often useless.
When mine arrives, I will make celebration lol :D!
I generally figure 4 weeks. Often in 3 weeks, and sometimes lucky with two weeks BUT have been unlucky with two months.
Shippers are shippers and not much we can can do about them. For example GF sent me a card 1st Class Mail...should have arrived next day...USPS took 10 days! imagine the convincing it took that I wasn't being ungrateful, thoughtless, etc etc. because she thought it arrived a day or two after mailing.
And you thought running group buys didn’t give you anything but headaches… I bet your negotiating skills are top notch for that situation now…
I got mine in about three weeks, good light and wish I had better 16340’s but they run well on the cheap ones. Seems to have some parasitic drain like all eswitches, so I just undo the tail a 1/4 turn, good to go.
Small and light enough to clip onto my ID lanyard and the clip is big enough to hold on a hardhat brim… Good for what I wanted… Thanks Bugsy36!
First mod will be to sand down a 16mm noctigon S4 2B XP-G2 to the 14mm size in the light and mount it, should be better lumen over all. I need to get some of that diffusion film as well…
has anyone recieved their H2 yet? Still waiting, got a trip coming up early November, could really use it, dont know if i should get something else or hope that it comes by then
Yes, I did, several weeks ago, but I am in the US, so it may not help much…
Reman, when did you place your order for H2?
I might reorder one and been wondering if the star was 16mm? Given the lens/reflector is 17mm it could be.
Want to replace stock XPG2 with green XP-E2.
I ordered back at the start of August, it was about five weeks to get to me, with almost two of those weeks “processing”…
The star is about 14mm… you can file down a 16mm sinkpad or a noctigon, but the wires on the star are on the same edge, so you may have to run more wire to get the length you need.
I did with 24ga silicone wire, but it was tight.
I put a Nichia 219C in the thing, just reflowed onto the stock board, it is wonderful for up close work now. I also got some DC Fix from member Boaz here, and it is worth it more than the new LED…
Great light for the money, at $24 it is a steal for what it does.
EDIT: Forgot to mention, in the instructions it talks about the Low Voltage Protection. If you insert a FULLY charged 16340 and do not unscrew the tail cap, it has LVP. If you put in a LiFePo4, or a CR123, it reads the initial lower voltage and then DISABLES the LVP to run those battery types lower than it would a 16340. I had LVP come on today with a 16340 and it was at 3.2V when it started stepping down. I had it on level two for about three hours on the Nichia 219C, so it is running about as advertised.
