Xtar VX2 Pro
Xtar reached out to me and asked if I could look this charger over, give them my thoughts and say a few things about it, good or bad.
First it came well packaged and included a 20w usb-c block with a C to C cable. The cable is about 18” long and feels of good quality.
It was also in this nice drawstring soft bag for storage or travel I guess. Includes full manual in quite a few languages shown in the picture, which details how the charger functions.
It will charge all the common cell chemistries including Lithium ion, LFP/Lifepo4, Nimh, 1.5v regulated lithium ion. From AAA to D size, there’s a lot of room
Max charging for lithium ion and LFP is 3A, for a single slot. 2A for both slots. Also 1A, 0.5A, and .25A, so all the rates are covered for cells small and large. Both Nimh and regulated lithium cells are fixed at 0.5A.
So on to functionality, theres are some things I really like about this charger, especially the storage mode. But starting, there are fine main functions this charger does; charging, discharging, refreshing, grading, and storage.
  • Charging. This is pretty self explanatory.
  • Discharging. Will discharge the cell at 300ma until cutoff (2.75V). I guess if you need to knock a cell down to a certain voltage this would be handy without having to do a full cycle. This will show how many Mah and Wah were discharged from the battery.
  • Refresh. This is for Nimh cells. I’ve never found a use for a setting like this, Nimh don’t need to do this as they don’t develop memory. But if you want to run a few full cycles on your Nimh cells, this’ll do it. It’ll keep cycling them until it feels it’s done enough.
  • Grading. This is what Xtar calls capacity testing. It’ll fully charge the cell at whatever you have the charging current set at, fully discharge it at 300ma, then fully charge again and record and display the total mah and wah discharged from their cell. This is obviously a handy function to test your cells. Whether to check if the manufacturer is telling the truth, or to check to see if your cells have degraded over time.
  • Storage. This is a new one I have not seen in non-hobby grade cradle chargers, and it’s nice to see. Whether is really matters all that much to you, cells stored at a medium level of charge do face less long-term damage than fully charged. There’s a lot of ways you could go about this. Pull your cells when they hit a storage charge while charging. Use a device for a while to drain your cell about halfway, ect. But this is so much easier. Put cell in either slot. Select storage. The charger will either charge the cell up to 3.6v at your selected charging current, or will discharge to 3.6v at 300ma. Doesn’t matter what level of charge your cell is at, walk away and when you come back the cell is at 3.6v. Which is a pretty good overall level to store at. Maybe not the best for some older chemistry cells which were almost dead at 3.6v, but who’s still running 2200mah 18650s anymore?
About the buttons. Each button on the charges has two functions depending on whether you click or press.
C/V button: First click “wakes up” the unit and the screen brightens up. Click the button to cycle through charging current. Long press the button to switch between lithium ion and LFP. Nimh and 1.5v lithium ions will charge in either mode as they’re automatically detected.
Mode Button: Same first click wakes up the unit. A click switches between slots. A long press cycles through the different modes. Charge, discharge, ect.
Things I like:
  • Sturdy and seems well made.
  • New functions like storage and discharge mode
  • Auto-detection of chemistry, though this has been a function of Xtar chargers for a while.
  • Completely independent slots. This is the big one for me. My previous examples of Xtar charges have a single function for all slots. Including charging current. So it’s difficult to mix and match cells, like one 14500 and one 21700. Either the 14500 is going to charge way too fast, or the 21700 is going to go very slow. This charger allows any combination of cell chemistry, current, and mode.(one slot can charge and the other could be in storage mode, ect.) The exception being you can’t charge a lithium ion and LFP cell at the same time, but any other combo works including Nimh and 1.5v cells.
  • Just about any size fits, though small cells like AAA and AA can be a little finicky to get good connection with.
Things I don’t like:
  • Not really sure what to put here. This is a good fully functional charger and I’m a fan. I guess If I had to find fault, I wish it was a four bank charger. But that’s not really a con to the unit and that’s not what it’s supposed to be.
  • I’d like to see chargers with higher discharge rates, but this would require a fan and large heat sink I’m sure. Just 300ma isn’t a lot, especially for a 6000 mah cell.
Thank you for review. I was considering this charger. Your review helped me to decide against it. Main deal breakers for me are: a) charging NiMh with only 500mAh is not enough, and b) 300mA discharge for LiIon is not just extremely low, but also wont allow you to measure capacity properly, so whole function is useless.
You’re welcome. But I have to disagree on your points. 500ma charge is fine for most nimh sizes. Maybe a bit slow for big ones like D cells, but not many use those.
As for discharge, while I would like to see more as well, like I said it would increase price and convenience greatly. Also, I have about a dozen chargers here. They all discharge at 300ma. So there’s not a lot of options out there for more. Also why do you feel it’s not enough to measure capacity properly? What do you feel is the correct discharge rate for testing?
I’m glad we are finally starting to see some USB-C chargers (especially those implementing proper USB-C protocols), this is an interesting unit.
In my opinion, which everyone is free to disagree with, this charger kind of sits in an awkward zone where it’s a little big/bulky to be a travel charger, but the cell testing capabilities are not quite strong enough to be a solid “workbench” charger for home use.
Storage mode in a multi-chemistry charger seems slightly redundant to me, unless I’m misunderstanding, why not just use the LiFePO4 setting to charge up a Li-ion cell to 3.6V? I do appreciate this will also discharge a full cell down to 3.6V, which I suppose might be useful to some people.
In any case, an interesting charger which will hopefully push other manufacturers to use USB-C, I appreciate the photos and your review.
I bought a different Xtar charger earlier and threw it away after it kept trying to charge NiMh batteries like they were Li-ion. Xtar thought that was normal too.
Yeah use this proper power delivery as well which is nice. My last three chargers from them have all used the same USB-C input.
Agreed on the storage mode. And I’m not one that feels the need to store my cells below full. But it’s a nice mode to have. I do agree with you though, this is quite big for a two bay charger. When able to handle all the way up to 26650 cells, I guess it’s not gonna be small
Interesting. Which model was that? I have never had that problem come up
  • on NiMh charging. 0.3C-1C or often 0.5C-1C is recommended for effective end-of-charge detection. 95% of my AA and AAA cells are Eneloop and LADDA (Ikea branded Eneloop), so for AA 2450mAh 0.3C = 0.735A. See where we are with 0.5A? For AAA 1900mAh 0.3C is 0.57A - still above charger’s 500mA.
  • LiIon capacity is rated with certain a) charge rate and b) discharge rate. Just look at specs of any good cell. So, if you can’t do discharge current adjustment you won’t get good reading. ANd you won’t be able to compare with other ppl posted measurement.
It was a VC4.
It worked like it was supposed to the first couple of times and then it consistently tried to over charge the Eneloops.
I’ve had a Nitecore charger that I mainly use for Li-ions and it doesn’t have a problem with the Eneloops.
1: that is the standard. That’s also quite an old way of thinking. 500 mA works just fine, and they quit charging when they’re full just like they’re supposed to
2: while you are correct, the difference is not that great. And the number that you get will be very similar to what someone else gets, even if you are a few hundred ma off. I’ve tested this myself. And the bigger the cell gets, the less it matters
IEC 62133 defines a discharge rate of 0.2C, but a) the difference at this low discharge rate is minimal and b) as long as you just compare it for yourself, it’s not a problem (just takes long).
NiMH termination appears to work good, even at 500mA.
Let’s agree to disagree. From what I have seen, for me discharge rate changes measured capacity significantly. ANd again - one will be measuring only for himself, no comparison with published spec and with other ppl measurements. 300mA is not even 0.2C for decent 18650 or 21700.
Fair enough. Whatever charger you get I hope it works out for you. Also I am curious, what chargers do allow you to set higher discharge rates? Like a charger with slots. Not a hobby charger
Evo C4, Vapcell BL4.
Thanks
SkyRC NC3000/NC5000, Gyrfalcon S4000/S8000.
According to the instructions, NiMh batteries are always charged at 500 mA, but I see in many video reviews that higher values ​​can be set, such as 2A.
So what’s the practice? Maybe even with the 2A setting, the charging rate is still 0.5A?
The setting is 2A. But as you can see it’s only charging at 150ma. So yes 500ma is the max. That 2A setting is for lithium ion
