YEZL T7-Q5 Mini Home-defense Flashlight With Charger
This is a review of the Yezl T7-Q5 flashlight available from most of the regular sellers here. This particular sample was supplied by Wallbuys. I was contacted by Wallbuys and asked if I wanted to do a review on one of their flashlights and I’d get to keep the light after the review. Well, like what most flashlight guys would do, I said sure.
The light arrived very quickly, taking only two weeks and was well packaged. Here is a pic of the package before opening.
Inside the padded envelop was a decent enough black box with the YEZL logo.
I opened the box to find the T7-Q5 flashlight with clip and lanyard, single position Li-ion battery charger, 18650 battery, battery sleeve, and even a AAA battery holder. I know what Wallbuys is currently selling this for and I figured if everything worked well this may be a good entry level kit for someone just getting started. Here is a picture of everything except the charger.
I did a quick check of the battery voltage (3.85v) and popped it in the light. Clickie, clickie, clickie, several times and no light. Hmmmmm. Let’s tear it down. Threads are mediocre and un-lubed of course, but there is at least enough of them. There is an o-ring at the tail cap, but the front o-ring is missing. A quick inspection showed the tail-cap switch not working. I grabbed my snap ring pliers and tightened the switch retaining ring and checked continuity again. Bingo! It works now.
The next thing I noticed was the twist style zooming head. I have had them before but this one required only a half turn to go from full zoom to flood and could be done with one hand. That’s a pretty good improvement over other twist zoomers I’ve tried before. I still prefer the simple slid mechanism like on a Sipik sk68, but this was pretty good.
Light output was roughly what I expected. The LED looks to be XR-E. Specs claim Q5 bin and no reason to doubt that. If you’ve been playing with XM-L’s you’ll probably be disappointed in the lumen output. A quick estimate puts it at about 150 lumens on high with a cool bluish tint. Intensity is 6.5kcd fully zoomed in so it should throw over 150 meters per ANSI standards. On high it is only drawing .65 amps from the battery, so the LED is seeing maybe half an amp. Low draws .15 amps which is pretty good spacing considering the .65 amp high. Modes are High, Low, and Strobe. It appears to come on in the next mode from where you turn it off. Next mode memory, if you will.
There is also a moveable rubber ring on the body allowing you to get a good cigar hold. I really like these rubber rings and wish more lights came with them. The clip seems a little weak but worked without problem during the test. You can also reverse the clip if desired. It has a pretty nice lanyard and the switch feels solid.
SUMMARY
The easily fixed switch problem outstanding, the build quality and exterior finish is as good or better than other lights in its category. The twist zoom works well. It comes with an 18650 battery and a charger. Where else can you get a decent light, battery, and charger for $11? I wouldn’t give it to a flashlight aficionado, but the package would probably make a nice gift those still using the old EverReady d-cell flashlight.
Need to copy the direct link code from photobucket. Well the links are only half copied.
pictures are not working, im curious to see why this light is for self defense
Yep. Pics aren’t working. I saved it accidentally. I’ll have to get back to this.
