YouOKLight-Portable Flood Light from GearBest- Review
I am testing for you a fully flood portable lamp,with built in rechargeable battery pack.
The lamp is suited for different indoor or outdoor use-for work,camping,emergency,domestic illumination, construction industry,property management,and other activities.
The lamp was provided by GearBest for test and review.
media.megavisor.com/player/embed?72dc3eb9-71f9-45a7-a63f-250de6325722
Product page at GearBest- http://www.gearbest.com/led-light-bulbs/pp_158215.html?utm_source=flashlionreviews.blogspot
Product Coupon code: 10WFloodlight
The YouOKLight comes in a cardboard box.
The angle of the light is quite wide.
Sufficient when using the lamp as an ambient light or for some work,that does not require a lot of light.
The beam is quite floody and does not provide high brightness at long distance.
If you are working something serious,you still may need a good headlamp.
The size and form are quite good for stable grip.
The YouOKLight comes with two chargers-for indoor and outdoor charging.
There are few openings allowing to mount the lamp to different stands,etc.
The maximum battery voltage is 8,4V. The LED is for 6V voltage.
The voltage is limited to the required level by a resistor.
The second-lower mode is also adjusted with another resistor.
Max brightness on High mode 556 lumens
Max brightness on Low mode 152 lumens
The used LED is powered with 6,2V on High mode and 5,5V on Low mode.
Current draw on High mode I=750mA (4.65W)
Current draw on Low mode I=190mA (1.045W)
Here is the front of the lamp,disassembled.
Metal frame and thick tempered glass are mounted on the front.
There is a battery pack of four batteries,glued in the plastic housing.
They seem to be 18650 batteries, 2x2200mAh in series with another two in parallel connection.
The lamp is advertised as 4400mAh,7.4V.
I did not cut the wrapping(yet) to see their brand.
The whole back side of the housing is formed as cooling fins.The heat dissipation is quite good.
Two screws ensures tight press for good heat transfer. There are two more threaded holes,but without screws added.
Thick enough wires,well soldered.
