is that because the H150 has an 800mAh battery while the H04 mini has an 1100mAh battery?
fwiw, the 1250mAh Vapcel F12 flat top works in the H150
however the Skilhunt battery (50.1mm) is Protected, while the F12 is UnProtected. Also the F12 (48.7mm) is 1.4mm shorter, and the battery will move and turn the light off if I slap the palm of my hand w the base of the light…
then again this review says the H150 has LVP, so a protected battery may be redundant… not sure
Vapcell also makes a longer F12 button top (51.35mm), w 1250mAh capacity, but I have not tested it, I dont know if it prevents the H150 from closing all the way.
thanks for saving me from buying the H200
I agree the red+white mode is stupid and I can see that they eliminated the 3 lumen mode in favor of that one Red+white mode.
I was also concerned that the Red modes of the H200 have poor spacing:
those mode spacing issues is why I prefer Anduril… I have an Emisar D2 with a Red 660nm that works very well for me (I dont like that the Skilhunt H200 uses the more orange 620nm).
bottom line for me, is that the Emisar D2 is a better LiIon light than the H150 and the H200… the only advantage to the H150 is that it also works on AA, which I normally never use.
however, I have an H150 in my car with both LiIon and AA, just in case the LiIon gets drained by summer heat in the car. I just dont love the Skilhunt mode spacing…
The Emisar D2 w Anduril is soooo much better than a Skilhunt, for me.
But I did not list the D2 as an annual favorite because it is sooo picky about battery length… It does work fine w the Vapcel F12 flat top… but Ive had a lot of issues w even that battery, where the D2 will shut itself off due to poor contact between the tailcap and the body or between the head and the body.
So I just cannot fully recommend the D2. If only it had a slightly longer body tube, and a better contact ring in the head, it would be epic… It has such a Great feature set.
