Dear Digika,
Not long ago I used some password strenght tests, and overall according to them my passwords weren't secure enough. However, that does not mean my passwords are bad; rather, those password testers are ridiculous. And I'm serious.
First of all, do you really think you can brute force a password? In which videogame? Think of it…
In the first place, many modern or security-concerned sites warn you after a couple failed attempts, and force you to restore password after a third mistake or so. I think G00gl€ does it, if I do recall right.
I just checked BLF; BLF allows you to try “as much as you need”. Does this mean it is unsafe?
In practice, not really. This is because BLF needs time to respond to your login requests; this takes time. Compared to ridiculous password testers, a lot more time. Therefore, the rate of passwords you could try would at most be like 2 - 3 per second. Also, you'd need to design or get a special software bot to brute force the password of some account here. And then, this forum has a moderator, a person in charge who periodically checks forum logs and stuff like that. This means it would only take a limited amount of time for him to notice this odd behaviour (days, a week, etc.), proceed to ban any “inquiring into” bot IP address and inform the target user of this problem.
Whether the above is fully correct or not, our moderator sb56637 knows better. I'll try to draw his attention on the matter.
The strenght of a password namely relies on the energy and consciousness which is behind it, this is the energy and consciousness of its creator.
Its subtle energy makes a password strong; its consciousness makes it safe, knowing when to change if required.
This is the reason my passwords and the passwords of most people around here are never cracked. Not because they're unsafe according to some unrealistic and absurd password tester.
Back to my lair now…
