Very cool design idea to use copper wire to create a flashlight body!
Hopefully you can figure out a way to make it work. Maybe try Kapton tape?
What about baking paper wrapped around like a kebab lol?
Or maybe some silicon spray on the bolt. There are some that leave s sort of dry silicon lube when the carrier evaporates.
Just something to keep the glue from adhering well to the bolt?
So I combined about all your ideas:
I did bolt “Maki” - I have wrapped the screw with plastic wrap then add some grease, wrapped some more and created some layers of plastic and grease.
After everything was covered I wrapped it with the copper wire. It pushed all the grease toward the end of the screw.
Then, I have covered everting with a thin layer of clear Epoxy glue.
Now I have to wait for it to cure and check if I am able to take out the screw.
I forgot to update that the grease made it much easyer and I was able to unscrew it from the bolt
I have also made the “Pill”.
Using a hand saw I cut a short section of the screw
And drilled 2 holes for the wires
Had to sand it a bit to remove sharp edges
I continue working fast since only 2 days left.
Drilled a coin to close the bottom end and hold the switch and boot.
And also solderd a spring fo the switch
Then soldered the switch in place
And close the bottom part by soldwring the coin to the body
Oh my gosh this is great! What a fantastic idea for a truly scratch built light just using what you got. Reminds me of my early days in this hobby. I might revisit that and make a light like you are out of aluminum and copper wire. Will be following it and looking forward to the end product.
Thanks. Be prepared for a lot of frustration
After the switch I worked on th pill.
Solderd some piece of cupper to the driver in ordet to have place between the board and the pill for the components
Then I solderd the dtiver to the pill and glued the MPCB to the other side. And soldered the LED
And finally I have tested it
Less then 7h left for the deadline.
I have to cut the body to 2 parts to enable replacing the battary without taking the evrything apart.
Unfotunately, it broke the glue and trying to screw the pill just made things worse
In the time left I will glue it a gain and add the optics.
If I have enough time I have an idea how to make it stronger and nicer
For the optics I wanted to use spot lens but the only tight lense I have is 21 mm and did not fit so I had to take it out of the holder
I also had to cut the wire tube in order to make it fit in length. This time I screw the bolt into the wire in order to make it stronger so it will not break the epoxy
And placs the lense inside
Nice work there! the lens looks good. does the light function yet?
Now I have to re-wrap the edges re-glue them.
Since it is short sections I belive It will not be a problem to unscrew the bolt.
And now waiting for it to cure…
Same
Everythig is now dry and ready for assembly.
I have to admit it is not at all looks as I imagine it but it is nice add to my lights collection.
I like the idae that this is a functioning 1000 lm thrower made entierly frome acratch from nothing more than a copper wire, Epoxy and a screw.
If i had more time I would have add another wrap of wire to make it shiny
Hope to make a better looking light next year.
As always thanks a lot for the orginizers and lets remember Old Lumen
Congrats on getting a working light from your concept. Much better than what I did…which was nothing.
But darn it is not pretty… ![]()
Wow, you did it YuvalS! Good job finishing the build.
