Zanflare C4 Battery Charger
This was provided to me for review and so far I’m happy with this versatile charger. It can charge many different cells including 18650, 26650, 26500, 22650, 18490, 17670, 17500, 17355, 16340, 14500, 10440, A, AA, AAA and SC sizes. It can also charge at four different rates independently, 300/500/700/1000mA. The USB out allows you to use one or two 18650 batteries to charge your devices at 5a 1v and 5a 2v respectively. With the bright LED screen you can monitor voltage ( V ), current ( mA ), time ( h ), capacity ( mAh ) and internal resistance ( mR ) during a Charge, Fast Test or Normal Test.
The “end” indicator will let when you your batteries are charged, it will also let you know if your batteries are damaged. Overcharge, overdischarge, overheat, short circuit and reverse polarity protections are all built into this unit. It comes in a fairly sturdy box with instructions, ac adapter, dc adapter and the charger itself. I’ve been wanting a second charger and this one fits the bill nicely, mostly I was looking for one that told capacity and this one works great. Battery chargers are crazy exciting but in the pictures you can see me charging four different batteries, all at different rates at one time. Overall this is a solid charger with lots of options. As a normal guy lots of technical data output isn’t important to me. This one is working very well for me so far. I use it on the counter in a well ventilated place. It doesn’t get warm enough to worry me. If something crazy happens I’ll report back but so far so good.
