Should be salvageable. I think the ’20s use the same pill as cheepcheepcheep C8 clones (ie, the truly crap versions you can buy on Amazon for 5bux a pop in a 3-pak). So you can drop that pill into the crappy C8 and use plenty of DCFix on the glass to blend the beam.
Won’t be a thrower anymore, but will give you a nice even blanket of light without the hideous piss-yellow corona of the G3-in-reflector (or aspheric).
Then use the C8 pill in the ’20 with something else as far as LED/driver.
Fasttech has the nice (big beefy brass) C8 pills if you want better quality.
Also, check the lens on the ’20, make sure there’s no “bellybutton” at the top. I got a couple of Ahorton deep aspherics and spacers from Illumn to fit into/onto a ’502 drop-in. Horrible horrible “smear” of the image, couldn’t focus any better than, say, a 30° TIR lens. Actually worse than a reflector.
Cleaned top and bottom of the lens to make sure zero dirt, grime, fingerprints, anything… same smear.
Placed it flat atop my cellphone’s display, and slid it around. Instead of a nice clean magnification of each pixel, you could see the hideous distortion where the very top of the lens had a “bellybutton” indentation, ie, slightly flattened.
It wasn’t worn down or scratched or anything like that, just molded that way. No way to fix it. Haven’t touched it in probably over a year, but was hoping to fit a spacer under the LED to raise it up, right to the bottom of the lens, at least get a nice flood beam out of it, like a fully retracted zoomie.
