Zebralight SC62D released
Looks like the Zebralight SC62D is now up for preorders on the Zebralight website.
I’m not sure I’m sold on the emitter choice though. 5,000k Philips Luxeon T 85 CRI, producing 320 lumens on high with a 3-hour run-time. Still, it looks pretty small for an 18650 light. Basically an SC52 with the same head and a slightly larger battery tube.
http://www.zebralight.com/SC62d-High-CRI-Daylight-tint-18650-Flashlight_p_135.html
Pre-order. Estimated shipping date: Feb 10, 2014
Main Features and Specifications
LED: Philips LUXEON T (Typical CRI: 85, Norminal CCT 5000K)
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels.
Light Output (runtimes)
High: H1 320 Lm (3 hr) or H2 145 Lm (9 hrs) / 66 Lm (23 hrs)
Medium: M1 36 Lm (45 hrs) or M2 17 Lm (4 days) / 6.6 Lm (11 days)
Low: L1 1.9 Lm (34 days) or L2 0.44 Lm (2.3 months) / 0.07 Lm (4.2 months) / 0.01 Lm (5.1 months)
Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1
Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using ZL634 batteries.
Operating Voltage Range: 2.7V - 4.2V
Battery: One 18650 size (up to 69mm long) 3.6/3.7V li-ion rechargeable. Batteries are not included in the package.
Parasitic Drain: Negligible (much less than the self discharging of a battery)
Beam Type
80 degree spill
10 degree hot spot
Dimensions
Head Diameter: 0.96 inch (24.4 mm)
Length: 3.8 inch (96.5 mm)
Weight
1.4 oz (40 gram)
Features
High CRI (Color Rendering Index) LED
Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
Automatic stepping down from High to Medium, and from Medium to Low when battery capacity is low
Builtin over-discharging protection (2.7V cutoff)
Durable electronic soft-touch switch
Smart user interface provides fast and easy access to all brightness levels and beacon-strobes.
Precision machined unibody casing from premium grade aluminum bar stocks
Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
Durable natural hard anodized finish (Type III Class I)
Sealed and potted LED driver circuitry
Battery reverse polarity protection
Tempered optical grade glass
Orange peel textured reflector
Waterproof to IPX7 (2 meters, 30 minutes)
Operations
This light has 3 main levels (High, Medium, and Low) and a beacon-strobe mode. Each main level can be programmed to one of its two sub-levels. The second sub-level of each main levels can be further programmed to different brightness levels.
Basic Operation
One short-click turns on the light to High or turns off the light.
Two short-click turns on the light to Medium.
Three short-click turns on the light to the beacon-strobe mode.
Press and hold (for over 0.6 seconds) turns on the light to Low and then Medium and High. Release at the desired level.
Advanced Operation and Configuration
Press and hold to cycle from Low, Medium and High, release at the desired level to set. When press and hold, the light always cycle from Low to High regardless which level you are currently in.
Double click to toggle and select between the two sub-levels for that main level. Sub-level selections for the 3 main levels are memorized after the light is turned off and through battery changes.
The second sub-level (H2, M2 and L2) of each main levels can be further programmed to different brightness levels. At a main level, double-click 6 times to start configuration. On subsequent double-clicks the light will cycle through different brightness levels. Short click to turn off the light when finishing configurations. The selections for the second sub-levels are memorized after the light is turned off and through battery changes.
This light uses the main LED (flashing 1 to 4 times) to indicate the estimated remaining capacity of the battery. To start the battery indicator, (from Off) short-click 4 times without pause.
Beacon-strobe mode can be accessed from 3 short-clicks when the light is Off. Once in the beacon-strobe mode, you can double-click to cycle through different types of beacons and strobes. Beacon-strobe settings are memorized when the light is turned off and through battery changes.
I got their H502c and H51c which uses a Luxeon emitter, albeit at a temperature of 4000K vs the SC62d’s 5000K and it’s a good emitter. It renders colour well and in terms of throw (in a reflectored light like the H51c), comparable to an XP-G.
This SC62d is smaller than their SC600 models. And I thought the SC600 was already small…
tried to replace a burned LED
but getting driver out, the inductor stuck in the potting material in the head, its not marked with any value
So what value to replace it?
Holy thread from the dead, Batman!
just a reboot like most Batman movies
