No worries, I have enough cells. I just need to get back home to get them.
Actually I was there yesterday but only for 10 minutes and I failed to think that I would need them.
And…back when you shipped the item I didn’t know where I would spend that night. Actually even now I don’t know where I’ll spend this. I have a lot of chaos in my life these days…
EDC 18650? That’s HUGE!!! I carry only tiny stuff like Utorch S1 Mini or Thrunite Ti4 or Lumintop GT Mini.
I’ve EDCed the received light nearly since I got it.
Not because I expected it be useful for EDC but because I hoped to find time to play with it.
Seems the time is now.
There’s still too bright to go out but I managed to play with modes and configuration.
The firmware is custom, based on Babka.
The default settings turned out to be perfect.
4 modes going from low to high with no strobe seems right for me.
Starting low w/out memory is right for me.
Batt check enabled - that’s right for me as well.
However it seems that I found a bug. When I do a batt check - it blinks 4 times. Then 5 times, 5 again and again and again. So the first blink-out seems shorter.
The batt check scale is 1-8 blinks so my cell is nearly half-empty. It seems the cell is not charged enough for full blast. I think it was 4V or more when I put it inside so it may be that the lighted switch drained it.
Babka is based on Biscotti and uses the same battery check logic, except that Biscotti is a 4-blink check by default. I upped it to 8-blink default. But the extra precision highlights a slight oversight… there’s no forced delay between starting the ADC and taking the first reading. The ADC can take a little while to “settle in” and give a good reading. When the first battery reading is done, it hasn’t settled in yet. I really should add a 100ms delay or so to help with that. Thanks for mentioning it!
