What did you mod today?
7691 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 3 hours 57 min ago
A new battery for my Camera costs $107.
Careful what you put in that Hitachi, it may well pull too much current for a lesser pack and fry something, in your hand, or even explode. A few bucks saved for a trip to the hospital… just sayin… be careful.
vwpieces
vwpieces's picture
Last seen: 1 month 6 days ago
Yeah I would have rebuilt my original packs with batteries of my choice before buying lesser quality packs. Also would not buy a tool that has packs that can not be taken apart, and put back together.
ohaya
That’s good advice. These were supposed to be my backup batteries, and will probably get some real ones next time. I was kind of surprised that they didn’t fit when I got them, and just didn’t feel going through the trouble of returning them, and just dumping them seemed like such a waste.
EDIT: size-wise, I’m pretty sure these have 14500 in them.
Budda
Budda's picture
Last seen: 1 week 19 hours ago
Cooyoo quantum and Veleno D2. Both got a XP-G2 3000K
All my reviews, in italian and english, here: Lumenreviews.com
pilotdog68
pilotdog68's picture
Last seen: 2 months 4 weeks ago
mattlward wrote:
KaiDomain. But now they only have 4B and 5A3. Now I cannot find them at any of the normal places…
I just put one of those 4B’s from KD in an L2. It’s quite nice, just a little more tint shift in the spill than I’m used to with the HI, but that might be from the coated lens. Decent performer too, I’m getting 5.7amps
DB Custom
DB Custom's picture
Budda, any specific issues faced when doing those?
CRX
CRX's picture
Last seen: 37 min 36 sec ago
Keepin it small… Wink
Convoy S2 super shorty Mule
vwpieces
vwpieces's picture
CRX, if I send you 3 flashlights, will I get 9 in return?
20 years ago I would have trouble making the tiny things you build. Today I would simply lose it cause I can’t see it.
CRX
CRX's picture
Possibly not LOL
pilotdog68
Finally, FINALLY finished building the L2 host that I bought on January 26th. It’s just been sitting here for awhile. It got my first use of the TripleStack driver, complete with my first use of the Sir800DP, and only my second use of the Attiny25 and Bistro. The driver is definitely more work assembling that a traditional design, but for me it’s worth it for the clean look on the battery side. I also could have compressed it quite a bit vertically, but there wasn’t any reason to with the L2’s big driver pocket.
You can see in the pictures below how clean the dedome was on my first emitter, but it wasn’t meant to be, one of 2 XM-L2 U3’s that I popped on this build. I ended up using an XP-L HI V2 4B which is giving me 5.7amps on a Basen. You can also see how I used the solder braid to gain reflector clearance.
I used three gold LEDs and a 50k pot in the tail, with a 1k bleeder on the driver. I had to add some hot glue on the switch post to alleviate some squish caused by the compactness of the reverse-clicky vs foward-clicky.
MRsDNF
MRsDNF's picture
Last seen: 3 days 11 hours ago
CRX wrote:
Possibly not LOL
I’d take my chance vw. It sounds like a better bet you getting nine lights back than getting a half descent SRK of Ebay.
djozz
djozz's picture
Last seen: 1 hour 12 min ago
In post #1451 I started this small AA zoomie mod, tonight I did more work on this light.
I noticed that the output was not stable and I could tell that the stock switch was the cause. If I could source a retaining ring, a common small Omten switch could be fitted, even a lighted tail could be possible. So I found an old 16340 light in the parts box that had the correct tail threading, a slice of that made for a fitting retaining ring for the AT-007. With the Omten switch, the output became completely stable (so the stock switch was rubbish), the output went up to 500 lumen, and throw (measured at 7 meter, 30 seconds after switch-on) went up to 41 kcd, that is 25% increase because of a better switch!
The rest of the evening was spent with getting a lighted tail to work but despite trying every combination of bleeder value, number of tail leds and all values of tail resistors, the UI was screwed up (backwards modes lost, no reset to low even after been switched off for minutes). This host combined with XP-G2 and 15mm Bistro driver is not suitable for a lighted tail.
Still wonder what electronic secrets happen with the lighted tail circuitry making drivers go weird, as a layman equipped with just Ohm’s law I can not get any grip on it.
MRsDNF
MRsDNF's picture
I’ll explain what you need to know later when I have a little more time djozz. Facepalm
Budda
Budda's picture
only taking apart the quantum required a lot of time.
I had to heat it a bit and then I used a couple of nails in the wood to win over the 2 bezels, but the first one was the most time consuming.
For the quantum, given the very small space on the board , I let the board in the pill and heat it everything with a heatgun from the bottom. Did the same for the new emitter. Then I had to resolder the solder spot on the metallic switch cover, for that I used the normal soldering station.
DB Custom
DB Custom's picture
Nice work Budda. The little lights are tough to work on as everything is so close together and heat to work on one thing spreads quickly to everything else.
Anyone have a great way to remove a Lummi bezel that has no cut-outs or holes for tweezers? Smooth on top, it came to me with no o-ring, when I tried fitting an o-ring it got stuck… can’t screw it all the way in to lock the pill down nor can I remove it.
Ouchyfoot
Ouchyfoot's picture
Hi guys. I haven’t done a thing in four months due to lack of energy. My doctor still hasn’t figured it out what’s wrong with me, but today I dragged my butt to the work table to build a light I should have finished in the spring.
Jaxman Z1 zoomie.
I decided to go for the XPH35 HI emitter. I know there’s been a few XPH35 builds done on the Z1 using boost drivers, so I decided to go with the 4S 16.8V MTN-MAX buck driver set at 2.5A
It’s a pretty easy build, which took all the energy I had. I really only had to solder two wires and color the white centering ring with a black Sharpie. (No, not that Sharpie! The kind you draw with. Facepalm )
It’s not the Jaxman supplied centering ring, but one I had that was just right for the XPH35 in this light.
The centering ring was a perfect fit and came out okay with the blackening on it.
Four series 26350s to go with 4S 2.5A buck driver, which ended up with 2.8A at the tail.
It’s really bright on high. Wall shot of the zoomed in HXP-35 emitter. Looks nice. Doesn’t have the visible quad matrix of the HXP 50 and 70
It was a good day. I got something done, and I’ll test it this evening down in the ravine during my “Doctor suggested “ daily walk.
MRsDNF
MRsDNF's picture
That sounded like a good bit of therapy Of. All the best buddy.
EasyB
Last seen: 3 weeks 1 day ago
Decided to resurrect the large fresnel lens from my spotlight build from a long time ago.
http://www.candlepowerforums.com/vb/showthread.php?282184-SST-50-homemade-spotlight
I made some Al arms to mount this lens on my UF-1504. I took out the aspheric lens and screwed the arms to the bezel.
A bit of “garage engineering”. Well, porch engineering in my case.
In the light I have a dedomed XPG2 S4 2B (old production style) and the precollimator lens I installed a while back. The beam is not great. It is yellowish and rainbow-y on the edges. I have a XPL HI V2 1A in another pill that maybe will counteract the yellowness. I measured 4,700Kcd at 10.25m. Similar result to the large fresnel thrower that djozz built.
Ouchyfoot
Ouchyfoot's picture
Thanks MRsDNF. I hope you made it through the magpie swooping season safely.
Ouchyfoot
Ouchyfoot's picture
Wow. What a project. Keep at it and get us some beamshots.
A continuing saga that will always be in the Beta mode.
djozz
djozz's picture
Nice projects, both Ouchyfoot and EasyB!
And I wish you better times Ouchy, glad to see some flashlight work again!
DBSAR
DBSAR's picture
Last seen: 10 hours 39 min ago
I did a thing. I modded my Klarus G20 with a tail clicky switch to eliminate any parasitic drain, plus eliminate the accidental activation with the protruding side switch when in a pocket or the holster. I also swapped the cool white XHP70 with a 4000K MT-G2, so now it has a nice neutral tint, and no more greenish hotspot and no more purplish blue spill. It’s still not the claimed 3000 Lumens, but the annoying bugs i didn’t like about this light are fixed. Now i have a G20 with a mechanical lockout, and a perfect tint monster pocket flooder light.
MRsDNF
MRsDNF's picture
That looks very impressive EasyB.
The Magpie swooping season is about to start Of.
vwpieces
vwpieces's picture
This was going to be a Quad but I decided against it. Keeping stock. Except for the 20 AWG And bypassed driver spring And XP-L HI V2 3A on Noctigon And stripped Polished exterior. OK, not 100% stock anymore.
WillyD
Last seen: 2 days 23 hours ago
That’s the funniest craziest thing I’ve seen! Please tell me you live near Licking County, ‘cause I wanna come over and see that thing!
robo819
robo819's picture
Took the stock driver out of my XinTD C8 (V5) and replaced it with a FET driver. I was going to dedome the XP-G2 S4 2B , but decided against it , as I did not want a pencil beam out of this light.
Getting 4.31 amps at tail with a rested LG HE4 (taken with Uni-T clamp meter from GB) think I can get the amps up just a bit more with a spring bypass at both ends, may try that later.
A couple of beamshots ……….
125 yards to Dead Tree
175 yards
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
DB Custom
DB Custom's picture
Nice solid C8 right there! Smile
giorgoskok
giorgoskok's picture
Last seen: 1 week 2 days ago
Nice work robo Beer
XinTD C8 is one of my favourite lights Wink I really like the quality of it .
robo819
robo819's picture
giorgoskok wrote:
Nice work robo Beer
Thanks. Yes i really like the overall quality of the Xin, certainly well built lights.
giorgoskok
robo819 wrote:
giorgoskok wrote:
Nice work robo Beer
Do you remember when you purchased it ? For old or new xp-g2 , it performs really well for a domed emitter .
