Good post miller, youāve done a great job on this project and I have no doubt my q8 will be perfect along with the others. Even a 1% failure rate would be acceptable in my opinion thorfire seems to care about their reputation on here and takes care of their customers. And finds a solution both parties are happy with. And they donāt overcharge for lights. Like the thorfire s70s was on sale for like 37-38$ shipped a couple weeks back 4000 lumens for $40 just like this light 4,000+ for $40. So they are still making out good building this for us. If the s70 still make enough profit at $40 this does to. And is soon as this is released they are making 40+ grand in a matter of 48 hours. Not to mention what the next couple years of sales brings probably with a higher price
Unlike the manufscter of the cometa, what basically happened there the prototype they sent out had all the right parts. Then when it went to production all inferior parts were used. And nothing like the sample lights sent out. Still to this day I avoid manker. They canāt seem to design a light without a lot of problems and ask to much for it. Light after light major issues. Name brand and contracted builds. And not the best support when issues arrise. But what makes the most mad. Is they cone on here with threads asking for blf members input and help with a design or things for a light. Build it and turn around and refuse to do a group buy for BlF when the community held their hand and basically built the light for them. Ok rant over now, sorry just gets me mad they screwed over so many members and didnāt even offer lube.
Since weāre all sitting and waiting anyway, replacing 20Ga Turnigy wires with 20Ga Teflon wires cost me more than 2A and 600 lumens. I got the reflector seated about 1mm deeper, which is all the centering rings in stock form are allowing. I found it interesting though that the teflon wires lost current, would have thought itād be the other way around.
Wow, thatās a lot. Maybe itās not teflon vs silicone, but rather that the particular brand of teflon wire youāve got just isnāt as high quality as the silicone wire? Smaller gauge wire sold as thicker gauge is way too common, as Iām sure you are aware. If you have a decent length of wire, you can figure out what the actual resistance of the wire is either by measuring it directly, or running a current through it and calculating.
Sure seems to me that Justin (Old Lumens) had tested the Teflon wires on a big triple build and found they carried more current. Thereās a pita to work with for sure, even stripping the Teflon off is a chore before you start soldering. Tough stuff, but such thick stout wires they can rip pads off a driver if you arenāt careful. Iāve had this Teflon wire for a couple of years, very seldom use it due to the stiffness. Not sure if itās quality wire or not. The wire inside the Teflon is pre tinned, seems like each individual wire is silver coated, theyāre not all soldered together. Seems odd to me.
Be nice to have a purpose built driver like the Q8 for the multiple emitters, Iām cramming triple wires on a single pad!
I had to inset the switch assembly deeper to facilitate button presses and the internal threads are shy of allowing the retaining ring to seat on the pcb the switch is on so I just picked up something to make it work, turns out to be a threaded piece of Titanium Iām using for that spacer. Probably losing a bit there, need to either re-cut the threads or make a copper spacer for maximum current path. That would matter on the lumens test, not at all on the amperage test as Iām doing that with the tail cap off.
With the reflector filed I might have room for 18ga leads, but then Iād have to drill the copper again for clearance for larger wires. Emitter mcpcbās are glued in with Arctic Silver, so thatād get risky. Always something. Build a light from scratch then start modding it for mo powah! Hahahahahahaha
Copper, love it and hate it. Replaced the Ti spacer with copper and am up to 9860 lumens. Thatās the love part. Had a spacer finished and was parting it off when it, at the last possible second, flipped over and jammed into the parting tool bending it up like a smashed pretzel and shutting the 1 HP motor down solid. UGH! Started over. What else can ya do, right?
Anyway, the 20700B isnāt a top discharge cell so itāll be interesting to see, like Tom has found in testing the Q8, just what cell works best. For those that donāt have a lot of lights to play with, it can be crazy finding the top performing cellā¦ sometimes itās not the one you expect!
Edit: With freshly charged 20700B cells Iām now seeing 10,448 lumens from the 3 XHP-50.2ās. Thatās 10,005 lumens at 30 seconds. Doing something right somewhere.
ā¦ Tom E, is that the first endorsement of the āSend Teacher to Chinaā campaign I am waging? ā¦. :+1: ā¦
āSmoke Testāā¦ā¦ā¦ā¦ I like thatā¦. metaphor or not. As well as everything else you stated. :+1:
The Miller, I pretty much agree with everything you say here except some of the Cometa statements.
I think the Cometa was a ābait and switchā for sure. It still, as of this writing; says in the OP of the first Cometa offering thread it was to be a āJAX Z1 hostā. Here are a few lines about that copied and pasted below.
Original message:
Hello to everyone, i am Cyberescudo a member of CPFItalia Forum.
In collaboration with Banggood we have created a custom flashlight on Jax Z1 host with many upgrades including the FET + 7135 driver designed by BLF members.
The name of the flashlight will be COMETA (the italian traslation of comet )
But, no use arguing about that and the how and why of it.
I call it tomÄto, you call it tomÄto.
Either way the outcome was the same, a sad disaster of a fiasco.
And the saddest thing of it all, āto meā; was this āCyberescudoā person crawling in a hole & disappearing. Mistakes happen, but the disappearing act was deliberateā¦ for whatever reason.
Which brings us to present timeā¦ā¦ā¦.
To date, it is impressive how āyou and the Teamā have handled this Q8 project. That is the bottom line for me.
Yes, even on the tightest run ship or manufacturing floor there will be some ālemonsā. That cannot be helped no matter how tight the standards areā¦ it is just the way it is. That is a given, whether it be lights, cars, dishes, do-nuts, or the space shuttle. Things can and do go wrong at times.
Personally, I think you & the team have done & are doing everything possible to keep manufacturing problems with this light to a minimum. But as has been stated aptly previously, there is just so much that can be done short of actually being there in person to see and check the production. That, in reality is not really an option. (unless of course you endorse the āSend āteacherā to Chinaā campaign, as hopefully Tom E has. ā¦ )
Aside from that, you all are doing all you can do to make this a success. :+1:
If it were to go bad, which I doubt & canāt even imagine; it goes without saying it would be none of yours fault.
It would just be the breaks of the gameā¦ā¦. simple as that.
Life would continueā¦ā¦ā¦ā¦
I donāt see that happening, partly because of the things you stated above and then being able to see the way this whole Q8 project has been handled from the start. You all have been on top of it in a steady and methodical manner. No rushing, no taking shortcuts, no nothing except focusing on the task. :+1:
I personally hope at least one other set of eyes trained in manufacturing examines the final Prototype. I just think two or three sets of eyes might spot something undetected. I have seen it happen to many times in other fields & instances. Something missed by one but all to obvious to another. Which is not to say that the first person missed something, not at all, But everyone looks differently at things and something may stand out to one that did not to another.
BUT, that is simply my opinion. Whatever is decided works for me. :+1: ā¦
Thanks again to you & the team for the manner in which this has been & is being handled.
Tried a pair of Sony VTC6 in the DBC-05 Triple, they give 21.12A on a rested pair at 4.13V. Thatās good for 11, 696 lumens from the 3 XHP-50.2ās. Iāll see if I can get my hands on a pair of VTC5Aāsā¦
The C6ās are some serious 18650ās to be sure.
The 50.2ās, adjusted in respect to the reflector, are showing just a hint of a spot in the center, with the cross radiating out from center on all 3 as situated. Probably more to do with this reflector than anything, but Iād say theyāre capable and it may well be interesting to see what 4 of em would do in the Q8.
Careful there young man- a lost workpiece is how I killed the mainshaft my hobby lathe A 1/4 horse motor and loose belt drive was still powerful enough to cause damage, especially to my ego.
I think weāre on the right path with the Q8, and if anything were to be added at this point a full up/down ramping test might be asked for and gotten. Since theyāre 100% testing anyway thatās only a few seconds more per light, right? Even when multiplied by 1000+ pieces it doesnāt seem unreasonable and it should go a long way to eliminating any possible DOAās which will be very helpful on both ends of the deal.
Canāt compare this to other GBās, the approach is entirely different because of the issues some of those had which have been analyzed and protected against much better here. That which can be done within reason is being done. The only thing I can see which could make a significant improvement is if there were someone who could bridge the language barrier better for us, but given electronic and engineering terminology that is a hope which will likely go unanswered.
I saw a place listing on a new Wuben light at Amazon that says Every light is 100% tested before being shipped. So maybe the idea is catching on.
Young, not so much, careful, well I thought I was! 1HP, jammed to an immediate stop! Left hand went immediately for the kill switch. On another occasion, the entire head came out of the chuck when boring the driver bay deeper with the 7/32ā holes for wires already in place in the thick chunk of copper, making for an interrupted cut on the boring tool. Left hand went for the kill switch, right hand went for the flying headā¦ caught the head before it could hit concrete but missed the kill switch which didnāt really matter at that point as it was spinning freely. Big WHEW! on the catch and save! lol
Have to agree that a Mandarin speaking BLFāer that had the time and inclination to act as go between would be an ideal situation, but everything else is being handled as well as possible from what I can see. Other group buys have pretty much been on existing lights, this is ground breaking in the creation of a new species. And the power level is also head and shoulders above whatās been accomplished before, another level to the new species chain. Gotta love it!
I totally agree Philā¦ :+1:
That is why I am waging the āSend āteacherā to Chinaā campaign.
A totally selfless endeavor (for the most partā¦ ā¦ ) on my behalf to be present as a liaison at TF in China when these are produced. To insure, my very own feet on the ground there; that all goes as smooth as a babyās butt with the Q8 production.
I even have a Passport, engineering drawing skills, blueprint skills - both drawing & reading, some machining knowledge & experience, and I am very fluent in using pictures - drawings - facial expressions - sign language - grunts & other guttural sounds to communicate.
And the best of allā¦ā¦ā¦ā¦ I know Kung Fu, as well as a few other Chinese words.
What more could we ask for Iād be a naturalā¦ā¦ā¦.
So come on manā¦ā¦ get behind this āselflessā campaign of mine and support it.
Hahahahaha, Teacher, you probably know General Tsao and his chicken army too! We could end up with little packets of soy sauce and concentrated chili pepper oil in the square to-go box our lights come inā¦
Captain Morgan and I have been telling tales all afternoon, so let me pontificate.
The average guy doesnāt have a clue about flashlightsā¦ especially if they grew up thinking Dads trusty 2D Maglite was āreally brightā. I love whipping out my EagleTac D25C to one of my unsuspecting āgear guyā buddies and throwing down 700lm from a torch the size of a Chapstick. Bewilderment followed by disgust followed by envy followed by, āWhere can I get one?ā
Iāve got some other lights that have some āwowā factor, but I donāt think Iām really ready for sparking up 6000lm. My brain just isnāt able to get there. Itāll be like learning that Iām strong with the Forceā¦ that some Heavenly power to bring illumination to the depths of the Universe resides under my thumbā¦ even Jesus took some time to find his groove.
And I have a feeling that when Iām not gonna be able to own just oneā¦ and that when I reveal the pricepoint to my before-mentioned āgear guyā friends, we will test the limits of the Chinese postal system.
Profound thanks to all who are making this happen, take as long as is needed to get it rightā¦ but remember that Iām freaking dying out here right now without one.
Sam, you an the Capān just carry on with the pontification while these lights are being perfected, once you see it you wonāt believe it anyway. I mean, when level 3 or 4 lights up the room with ceiling bounce youāre gonna be trippin. When level 5 and 6 blow forceful illumination youāll be drooling yourself, but when you finally reach Turbo youāll hear the Nirvana Choir kick in with the Angelic rythmās that will certify you a complete and total flashaholic to the core.
Yes, I know, default is ramping, but youāll be tempted to ease into it and creep your way up to Turbo, when all along itās a quick double tap away from offā¦ once you experience it and learn the rythm of it, youāll delight in showing your buds the low mode then blasting them with an eye searing Turbo and hearing their quick intake of breath as they too delve into the depths of flashaholism.
Just remember, bear it and share it my friend, bear it and share it. Welcome aboard!
