If I go with the X6R, can I simply swap in a MTN FET+7135 driver with an ATtiny85 and flash Narsil to it?
Mountainās 17mm FET+7135 driver shows an option for ATtiny85 without firmware but the 20mm doesnāt.
Thereās an option for e-switch on both drivers, but it seems that includes only an ATtiny13.
How is the side switch wired to the Mountain driver? Iām new to modding e-switch lights.
Iāve seen the X6R thread involving stacking custom drivers on the stock X6R board, but Iād rather avoid custom PCBs and ordering individual components if possible. I wouldnāt use built-in charging anyway.
(use the pictures on kronoās original X6R thread as reference)
You should have no problem piggybacking a single-sided 17mm driver on top of the charging board. Youāll want to use the charging board as a contact board anyways and as long as you donāt damage it the charging function will still work in a pinch. There are 3 pins/posts on the stock driver: Switch, Batt+, and Batt-. Youāll just have to run 3 wires to replace those posts.
Could I still do as you suggest with a 20mm driver or will I run into clearance issues? I couldnāt find the diameter of the charging/switch PCB.
Iām a newbie when it comes to modding. Iāve only done some simple same-size driver swaps and a couple of emitter reflows. Iāve only this week bought re-flashing tools and successfully swapped firmware on a D4.
I probably should have waited to have an X6R in my hands before ordering parts, but patience isnāt my strong suit.
The only problem is that you are going to have to run a wire from the charging board to the top of the driver. It can be a tiny wire, but you might have to cut a notch for it.
My EagleEye X6R and 20mm Texas Avenger driver with Narsil have arrived.
Iām a bit confused on how to wire the TA driver to the existing X6R charging/switch PCB.
Iāve disconnected the two stock PCBs and labeled the pads A, B, C, and D.
Hereās my X6Rās charging/switch PCB. I poked around with my meter and it seems A is ground, B is positive, C is for the red/blue switch LED, and D goes to one leg of the switch.
Hereās my X6Rās stock driver PCB.
Here are the two sides of my 20mm TA driver.
Here is Lexelās photo about connecting the 20mm TA driver from this post.
PDās photo of his piggybacked driver setup from this post seems to show a different stock X6R charging/switch PCB than mine. His has only three pins connecting the two stock boards, while mine has four.
B +, but I highly recommend to scratch the paint off and solder the wire there or drill a hole (for the wire) where all the viases are next to the spring
C is a LED, you can probably use the TA indicator LED output here
D switch
on my picture the left of the switch/indicator LED pads is the one you need to connect
Thanks Lexel. I think I understand a bit more, but Iām still unsure.
Wire from the stock charging boardās spring, through a hole near the vias, connected to the TAās spring pad. Another wire from the TAās spring pad up to LED + on the emitter board.
Pad B on stock charging board will be unused.
Wire from pad A on stock charging board to ground ring on TA board.
Wire from pad D on stock charging board to TAās switch pad nearest pin 2 of ATtiny85.
Wire from large leg of FET to LED - on emitter board.
Iām still unsure about pad C and the indicator pads on the TA board. Are you saying to connect pad C to left indicator pad through a resistor?
The indicator LED is accessable at pin7 of the MCU as well as on the near side of R1 and R2
also you may not need or not a resistor for the indicator LED depending how it is wired on the chargin board
without the indicator LED the driver is working fine
The rats nest is the greatest part of a mod! You get to see if it lights up
Bummer when it doesnāt though. Or when it does and the not once every thing is final soldered and packed away. Thatās the worst! Iām sure it wonāt happen to you though.
