13576 posts / 0 new
Stippier
Stippier's picture
Last seen: 8 months 1 week ago
I also like the orignal the design better (even more with a 45 degree slope). But like ToyKeeper mentioned before, this way it gets a bit more thermal mass and that is (to my opinion) something this light could use very well. But I rather would have seen it in a different way (a thicker wall maybe). I still like the inside of this light so I would buy it anyway.
AAA: UF-T1, ITP A3 EOS, Tank007 E09
AA/14500: Xeno E03 XM-L T6 NW, Solarstorm SC01, Astrolux S3 (BLF X5), nameless EA41 copy, Ultrafire C3 XR-E Q5
18650: Ultrafire WF-502B XM-L, Ultrafire WF-504B P7, Ultrafire C8, SkyRay King 3x XM-L (gold)
joechina
Last seen: 2 days 21 hours ago
TK: For quick hack can you dremel the 7135 to size?
Are quick bursts shorter than 10sec?
How quick gets it hot fully regulated?
Gerrit
Last seen: 1 hour 23 min ago
DB Custom wrote:
I like the neat clean look that Fritz designed... !{width:50%}http://i.imgur.com/ERg3UIS.jpg!:http://i.imgur.com/ERg3UIS.jpg Minimalistic, elegant in it's simplicity.
Yes Dale, you have an eye for detail and beauty.
rayman007
Last seen: 6 months 1 week ago
Hmz,
I signed up for this
Now its fully blasted and tapered?
CrashOne
Last seen: 5 hours 52 min ago
I like the original shape (that tapered design, can’t get used to it), but the blasted look of the latest sample.
Kindle
Kindle's picture
Last seen: 5 hours 25 min ago
pepinfaxera wrote:
I like the original design better as well, but I will still order this tapered version.
DB Custom
DB Custom's picture
Last seen: 3 hours 14 min ago
Several times now I have headed out to the lathe to build a light, with the internal components in hand and no design cues in mind at all. Start out making the tail switch fit into a bar stock and then machine a copper light engine to hold the driver and emitter/s of choice. Then put the pieces together and shape the outside to whatever feels right. It’s odd maybe, but doing it that way the design takes it’s own shape on-the-fly and has produced some really neat and interesting results. Like making the battery tube fit my fingers in the grip I like to use, then seeing it resembled to spools of thread stacked on top of each other. I like machining it after it’s assembled because it makes the two pieces seem as one, even a transition between copper and aluminum the metal seems to be one piece that abruptly changes colors. I like that, it amazes me. (I’m easily amazed, true enough)
So it’s not that I don’t like the ramp on the tube, it’s just that I was drawn to Fritz’s primary design to begin with. It was more Raw, elemental, form following function. And so it goes, it’s never-ending…. Wink
Tixx
Last seen: 1 week 6 days ago
Dman7777 wrote:
Its funny how people have completely opposite ideas about the aesthetics of the old and new design.
I personally think the new design is a huge improvement.
I was not too crazy about the original, but functionally it sounded really cool. In my opinion the new design is much much better.
I dont like the luminitop Tool design at all, to me it just looks incredibly low effort and unimaginative. I have seen nicer looking spark plugs.
Yeah, agreed.
b1i1l1l1y1
Last seen: 1 month 4 weeks ago
From TLF regarding the design:
cawi wrote:
it has made some design changes. It came in the first place through the clip. We feared that the old design with clips in general, and the clip we’re likely to use, could be particularly problematic with clipping on the trouser pocket. That’s why Fritz revised the whole thing again. I have to say that I personally like it very much, even if it changes the original design very clearly. I’m sure some of you will see that as well, many others will find it terrible. I can only say two things about that.
1) The design is not set in stone yet. This is the first prototype we got, not the finished product.
2) IF there should be changes to the design then that will be Fritz’s decision. The whole lamp is raised as a special edition and forum lamp, etc., which is quite justified, the name is not by chance. It’s Fritz’s design, and in the end, it hits the market as he pleases. Of course that does not mean that you can not make any suggestions. That’s the great thing about the forum, of course: a huge collection of flashlight and creative mind experts who can push things forward.
Tixx
ToyKeeper wrote:
I’ve already managed to mess up my prototype a little. I replaced the 1×7135 chip with a different brand to see if it’d help, and it seems to have made the driver stick out a little so now I can’t thread the thing together quite as far. It still works, but I’ll have to fix it next time I take out the driver.
OTOH, I greatly improved the button debouncing. It’s not 100% yet, but it’s at least like 90% now.
Regardless of how the tapered section works out, whether it’s 5 degrees or 45 degrees or 90 degrees, the narrow middle area makes the light much more comfortable to hold. It fits comfortably between any two fingers, which isn’t something I can say for most of my 18650 lights.
This prototype has the wrong emitters (XP-G2), and there are some thin wires, and my main contact points are weak at the moment due to the replaced chip not fitting quite right, and my battery wasn’t full, but I did some quick output tests…
  • Moon: 0.24 lm (after swapping 1×7135 chip)
  • 1×7135: 160 lm
  • 8×7135: 1063 lm (highest regulated level)
  • FET: 2160 lm
The real thing should go significantly higher (though keep in mind the high modes are basically burst only, not for sustained use).
Nice Moonlight!
ToyKeeper
ToyKeeper's picture
Last seen: 2 days 10 hours ago
I don’t know how long a quick burst is yet, and don’t know how the thermal regulation will behave yet, because I haven’t measured it yet or adjusted the code to fit.
I can probably trim the chip’s wide tab down to fit.
… a few moments later …
Yeah, okay, it wasn’t the 7135 tab. The driver has a notch on one side, and so does the host. It just wasn’t rotated the right way. ;P
While I had it apart, I also fixed debouncing. It seems to work 100% so far.
DB Custom
DB Custom's picture
The Devil is in the details… Wink
infinity526
Last seen: 3 weeks 6 days ago
I’d like to throw in a vote of support for both the blasted finish and the tapered tube.
b1i1l1l1y1
Really wished the prototype could have come with the XPG3 emitters that were planned so we could see what the tint/beam would look like.
Maybe the next round or someone could swap some in?
ToyKeeper
ToyKeeper's picture
Is that where he’s been hiding?
I swear, that guy must have a spidey sense or something. He’s way too good at avoiding me.
ToyKeeper
ToyKeeper's picture
I was disappointed too. I was hoping we could settle the emitter type issue, but it remains unresolved.
lumenzilla
lumenzilla's picture
Last seen: 2 days 27 min ago
I was amazed by the initial design as well.
I don’t have any argument on latest design, it’s great, but it’s just different from the initial one.
Wishing that I can get the light as initial design which is already in my mind.
zak.wilson
Last seen: 2 hours 11 min ago
Haven’t checked this thread in a while. I think I prefer the tapered shape because I expect it to slide in and out of a pocket more easily. I do really appreciate the looks of the original, but I’m very much in the form follows function camp and it looks like the new form will function better. I liked the polished look better, but I use lights when it’s dark, so that’s not a priority.
I’m really glad to see that ToyKeeper is working on the firmware. Just using Narsil seemed like a good enough plan to me, but TK working out all the kinks should make it free of annoying glitches and well-tuned for the hardware. Thanks, TK!
I still think it needs more Niciha. As more XP-G3 beamshots in various optics show up, I think that more than ever. The XP-G3 always seems to make a beam that looks like a bruise. Yes, I can do that myself, but not everyone can, and it adds 40% to the cost.
As for what the final beam will look like, has anybody built a Convoy triple with these and a 10507? That should produce an essentially identical beam.
Ceilingbounce – flashlight testing and runtime graphs for Android
Ozythemandias
Last seen: 2 weeks 1 day ago
For what it’s worth, I love the new look and if anyone would like to give up their slots I’d gladly take it, I’d like a total of 3-4 of these,
zak.wilson
There aren’t a limited number of slots as far as I can tell. If you want more, sign up for more.
I’ll probably still buy the 3-4 of these I signed up for regardless of minor changes, emitters, optics, etc… as long as the original concept remains intact, as I can change emitters and optics myself. I’d buy these as host+driver with no emitters or optics too.
I probably wouldn’t recommend it to others not inclined to modification with the XP-G3 though.
Uname
Uname's picture
Last seen: 9 months 17 hours ago
Please add me to the interest list for two!
PBWilson
Last seen: 2 hours 22 min ago
fritz15 wrote:
  • I am also not 100% happy with the design. Currently it looks a little mixed up. Either there should be two chamfered parts or two sharp parts. We might make a small adjustment there,
I agree with this point and ultimately will buy a couple whatever the configuration (even a mixed up version). The small size, power and excellent UI will make this a light that other companies should take notice of.
We’ve been lucky to have high performing lights recently available and this one oughta go to the head of the pack once it’s in production. Thanks fritz15 for your design and I hope they’ll make a light that satisfies you and your vision.
Ormbett
Ormbett's picture
Last seen: 1 hour 18 min ago
I prefer the new design! Thumbs Up
maukka
maukka's picture
Last seen: 4 hours 8 min ago
Played with a triple XP-G3 I got from RobertB/CaptRon25 today with a couple of different optics. It was taken from a Wuben T046R with a claimed CRI of 90. Turned out it wasn’t high CRI, but the more interesting thing for me was the tint shift and beam as a triple.
Here’s the results using a heavily frosted Carclo triple optics with pretty much no visible hotspot and very low apparent output. The result is not bad at all.
Here it is with an almost clear, very slightly frosted with a much worse results. Even though the shift direction change near the hotspot is not as apparent, the overall tint is very unpleasant, cool and purple at 7000K and duv of -0.004. It is also very noticeably green towards the spill.
I still think the FW03 should be made with Nichias or at least the choice of optics and its setting must be very carefully optimized.
CRX
CRX's picture
Last seen: 4 hours 14 min ago
Thanks, yeah I’m not fancying the XP-G3 option.
ToyKeeper
ToyKeeper's picture
Maukka, do you have a 10507 optic to try?
SKV89
Last seen: 8 min 38 sec ago
Why not XP-L2 which is newer and more efficient instead of XP-G3?
bossf350
Please sign me up for 2.
Thanks,
Martin
doubleone44
doubleone44's picture
Last seen: 6 months 3 weeks ago
I wonder if dome slicing eliminates the tint shift on the XP-G3s. I read it works for the XHP50.2. Might be a simple mod for people who don’t fancy swapping emitters.
Tixx
I know its a cost thing, but XP-L 4000k (the A or D version) is a real winner.
