What did you mod today?
I’ve seen 1mm steps, but nothing on the halves.
If you wanna be almost perfect, you can wrap the next-smallest step with paper (but not to overlap), and that should get it almost perfectly centered, then the next step will dig in.
“Canned air” should blow off most of the shavings after you’re done.
[quote=Lightbringer]
Oh, and you might wanna leave a little slop in case one/more chips are ever-so-slightly “off”, so that putting the reflector on ’em doesn’t push/crush the corners.
You can still swap tailcaps, but not switches. Eg, as I mentioned, a black tailcap with rubber boot on a purple head+tube. But you won’t be able to stick a rubber switch in the purple tailcap without modding it first to swap metal/rubber.
Ahh, I see why you crossed it out.
Yeah, tailcaps are interchangeable as long as you don’t mind a different color going from rubber ⇄ metal.
RPM e body, stripped + polished Malkoff VME head + tri cap, sst-20 3000k triple, h17f driver. Bypassed springs.
For Convoy S2+ hosts with a rubber boot:
  • There’s also a silver (clear), which comes with the presentation box (and a pocket clip): convoy S2+ host
Beautiful (y)
Thank you
Made L6 3x26650 with sliced XHP70. It was fun :smiley:
link
Looks good 1stein! Someday I’d like to build an L6. It’s a good looking flashlight with lots of power!
Thank you. It’s quite regular flashlight, just big. But often small flashlight is more difficult to mod due to smaller parts and less room. Thus CRX’s builds are so amazing.
Cut off the little protective fins around a Jetbeam SF-AA01 switch that were too small for my thumb to comfortably press, and repainted. Huge usability difference.
Forgot to take picture: modded Novatac 120T into XPL, it was “leftover” emitter found in my storage box.
The driver can’t really put enough juice though.
My DBC-05 now sports a Tofty, gained ~400 lumens on a 30T such that the CFT-90 now makes 5010 lumens on my calibrated light box. :smiley:
Edit: it finally dawned on me that with a near 26A draw I was asking a lot from a mini Omten.
I usually use a jumper wire in place of the Tail Cap while on the Lumen Tube —- That will tell you how your switch,spring , Bi pass is holding up— I started doing this after I’d measure ridiculous amps with my clamp meter and the Lumen readings were a Let Down
Tells you how dirty your switch pcb or the inside of the tailcap is more than anything…
First Impressions
V11r modded to E21a 3500k, repacked control ring w Nyogel 767a
blue locktite:
XM-L2 star about to be unsoldered:
E21a, freehand centered (from Clemence, his reflow, his mcpcb):
beams:
I like the 3500k E21a better, because it is more pink, than the 3500k 219b
I like the N219b 3000k better, because it is more orange, than the two 3500k
Initial V11r lumens on 16340 w XM-L2 was 0.01 low and 420 lumens max (spec is 1 lumen low, and 570 lumens max w 16340)
after the swap to E21a, 0.02 low, and 255 lumens maximum, that is a 40% drop
The control ring arrived very loose due to old grease. The Nyogel made it noticeably resistant to turning but can still be done with one finger.
Im waiting for a replacement reflector, atm the stock reflector produces rings in the spill w the E21a, plus there is a cross in the center of the beam when closer than 3” from the target. otoh, when shining on a wall 25 feet away, I like the tight hotspot w the E21a.
the V11r arrived with a metal switch cover that made noise and felt wrong. Installed the rubber switch cap, which I like better. The clip was not to my liking… took it off…
E21a 3500k, YES!
I would do it again…
all opinions subject to change… lol
relative tint, iphone auto white balance
the 3500k is “whiter” than incandescent… makes for a nice evening light…
the V11r reflector makes a tighter hotspot than my RRT-01’s that are flanking it.
Im really conflicted about the tailswitch on the V11r, but it has its strong points
momentary
memory
Finally I used my last stashed 219c 4070e. I put them in ReyLight Ti Dawn 2.1. MCPCB was glued to the pill.
Uploaded firmware with customized modes:
PROGMEM const uint8_t modegroups[] = {
/* 0 */ ONE7135, 0,
/* 1 */ ONE7135, ALL7135s, 0,
/* 2 */ 10, ONE7135, ALL7135s, 0,
/* 3 */ 8, 14, ONE7135, ALL7135s, 0,
/* 4 */ 10, ONE7135, 28, ALL7135s, 0,
/* 5 */ 8, 14, ONE7135, 28, ALL7135s, 0,
/* 6 */ ONE7135, 28, 0,
/* 7 */ 10, ONE7135, 28, 0,
/* 8 */ 10, ONE7135, 26, 0,
/* 9 */ 14, 28, 0,
/* 10 */ 8, 14, ONE7135, 28, 0,
/* 11 */ ALL7135s, 0,
/* 12 */ ONE7135, TURBO, 0,
/* 13 */ 10, ONE7135, TURBO, 0,
/* 14 */ 10, ONE7135, ALL7135s, TURBO, 0,
/* 15 */ 8, 14, ONE7135, ALL7135s, TURBO, 0,
/* 16 */ 10, ONE7135, 28, ALL7135s, TURBO, 0,
/* 17 */ 8, 14, ONE7135, 28, ALL7135s, TURBO, 0,
/* 18 */ 10, ONE7135, ALL7135s, TURBO, 0, // DEFAULT
/* 19 */ BIKING_STROBE, BATTCHECK, ONE7135, 28, ALL7135s, 0,
/* 20 */ 6, 16, 26, 0 // muggle mode
Album with pictures
Put a Luxeon V2 5000K in the Skilhunt M150. Details here: “REVIEW”: Skilhunt M150 – 1 x 14500 / AA – 750 Lumens – Double UI – Magnetic Charging [PIC HEAVY] (Beamshots added = Post#21)
Summary:
(Comparisons with Luxeon V 4000K (under a TIR, on the right))
Congratulations on your mod Jon! You are getting better at it by the day! :+1: :beer: I like the incandescent the most in your tint comparison. The E21A 3500K actually looks kind of green but it could be the camera playing tricks.
