Does this thing have a large or intense hotspot?
I has a small smooth reflector. But the result seems like an OP. It has hot spot. relative large with good spill.
Tube is pretty tight, HiMax dont fit and so I guess XTAR wont fit either.
Are they too thick or too long? What are their measurements? And what measurement battery you need to use this lamp?
I’m thinking about ordering this and some battery if I just would know one that fits.
Too thick. HiMax are about 18.84mm in diameter and the tube is about 18.7mm. I think edc mentioned that long cells wont work either.
I guess TF3000 work, if you can find decent ones. Or other rather small cells. Flat top work, as well as button top. So maybe the new Solarforce V3 will fit. Or clear wrapper Sanyo cells (MarsFire) and so on..
Problem with HiMax is that they have a clear wrapper over the white wrapper. You could remove it, but the white wrapper is a little brittle.. so I wont do that.
Would 18.2 mm cells work?
Can someone take out the reflector and post a beamshot please?
I haven´t had problems with the diameter, but flat top cells doesn’t like this light.
I jus figured out the problem with the lenght of some batteries, is the retaining ring does not hit the end of the tube of the flashlight, I added just to try a little bit of aluminium foil and now it works with all my batteries, even the flat tops, where the problem was really with the length not the flat top.
So, I understand the best solution would be to leave a round lip on the exterior of the retaining ring by taking away a few material of it, or just doing the aluminium foil trick for longer batteries.
It is a pity having to do this, as I like it a lot in general, but for this.
Is it possible to remove the reflector Yavi?
I would not try, it looks like I will scratch the bezel trying it, the bezel doesn’t have any protrufing part where you could force it, nevertheless I am not that good at it.
Well, if so, anyone else waiting for the reflectorless version of this? Basically the u3 with an xml?
It probably can be dissembled. Whenever I find a light that has bezel I can't get off I wrap the whole thing in electrical tape and then stick it in a clamp. Then grab the other end with a handheld clamp and twist. With this method you can unscrew almost anything. I used this on my G2X which is glued and it worked really well.
Oh, I was just worried it was press fitted, or all one part, or just something wierd. Good technique to know Scaru! Do you think that i’ll get a hotspot if I do remove the reflector, like just from the light reflecting off the sides of the head where the reflector used to be in front of?
From my experience it won't have a hotspot unless you're white wall hunting. I'll see if I can get a picture to capture it.
That’d be fantastic if you could!
I will try today if possible to add an copper cord on the edge of the retaining ring on the tail cap, let’s see if it is a good solution for those wondering to use long batteries such as Hi-Max, protected NCR1650A…
All you need to do is remove the ring and add something 3 or 4 mm thick and long batteries will work. A 2032 battery will work but wrap it in tape. A 20mm magnet would be ideal.
Do you mean removing the ring and not using it again?
While the ring is there, with long batteries, the ring itself does not hit the not anodized part of the flashlight tube, so there is no contact.
Once that is solved, yes there is plenty room for a good magnet underneath the spring board, I tried with two of the ones I had, they were not that
powerfull, so it can stay upside down, but not fixed to a vertical surface, I will try with a better one I’ve got here.
Hi,
Have uploaded some beamshots. Not really pro at doing it. However, noticed that there is PWM in all brightness modes. Un noticable to the eye.
Could you say, it is better than in previous, the AA-model?
IMO it had it pretty bad…
