S2+ has an S3 style short reflector. At least I think it is the same as an S3. It is very short. Deeper pill though. The tailcap does not allow you to use one of those cheap clips either.
FWIW, the Solarforce L2 clip works pretty well on the entire Convoy S line, and is much sturdier than the cheap screw-on clip. However, it may require adding a paperclip to the tailcap on some models to ensure the switch connects to the non-anodized part of the main body. It may also be slightly larger in outer diameter, but not by much — 25mm instead of 24mm.
Hmm. Thanks for posting that. I’ve tried the SF clip on a Roche F12 after another BLF member mentioned that it would work, but quickly decided that I’d have to strip the threads for contact. I didn’t like that idea, so I took the clip off. I hadn’t considered adding a ring like that. Now that you’ve shown that way, I’m considering adding a ring under the brass retaining ring to keep things clean.
As far as I am aware the spacers that he offers are only for s2 so s6 not s3 can someone confirm this? And if this is true what spacer does he use for the s3?
I don't know about the new version with the integrated shelf, but you most definitely do need a small spacer on the old S3 or else you won't get hardly any thread engagement.
