Just judging from that pic, I can say that they are NOT fake. But again, just assuming everything else is the same... the colors around the button are always a little different.. don't worry about that!!!
If you looks at post #1, you can see that one is almost grey.. and the special editions have again different colors.
Made in Japan
Modellnummer: HR-3UTG-AMZN (8P)
70% after 3 years remaining.
Similiar look, capacity and discharge values…
Only big difference they are rated for 1000 cycles…
Is there any definitive answer on how charging current affects cycles over the lifetime for the eneloop and eneloop pro? I generally charge all my AA at 700ma and my AAA at 500ma. Would it be better to charge faster or slower?
I`m confident that won`t effect the cells in any measurable manner.
I havent seen any hard evidence with somebody actually doing those tests.. those would be very very time consuming.
In the very very long run you might see a difference, only if you keep track of every little detail.
So the currents you are currently using are good enough!
the Panasonic chargers usually charge AA with 550mA and AAA with 275mA.
conclusion: No, there are not enough tests that would show the difference between charging AA eneloops at 1A or 750mA.
although member "powermeup" at CPF has done some extreme testing on eneloops that has some interesting results. but that kind of testing is not comparable to real life usage.
Left: Made in Japan 3rd generation Right: Made in (Japan?) 4th generation
I think they now make 2 versions, 1 in China (bottom) and 1 in Japan... (right)
Both say 70% after 5 years.
but this one below, is definitely made in China
65% and from a Chinese website
Backside of this 65% one, showing that its made in China
I've been visiting their website regularly in the past few months, but they haven't added anything new.
I really thought they would have a special eneloop 10th anniversary edition, but nothing. The latest edition is just a 2bay charger for eneloop lites,no new batteries.
The 10th Anniversary of Eneloop is later this year. November 2005 was the launch month of the original HR-3UTG series. I’ve been reliably informed that Panasonic will be doing global 10th Anniversary promotions for eneloop. Kind of ironic since Panasonic dont dont own the technology or the factory eneloop is made in (except the Chinese made eneloop that are actually using Panasonic Evolta technology, not Twicell factory technology the Japan made cells have always used).
Here’s the shortform history of the Twicell factory consumer NiMH battery line from even before the LSD days:-
April 2013 AA-AAA type low self-discharge type Ver.4 (UTGC) begin shipping. (2100 cycles)
October 2011 AA-AAA type low self-discharge type Ver.3 (UTGB) begin shipping. (1800 cycles)
January 2010 Transfer of Twicell factory to FDK Co,. Ltd (Majority owned by Fujitsu Ltd) from Sanyo Electric Co,. Ltd. Renamed to FDK TWICELL.
October 2009 AA-AAA type low self-discharge type Ver.2 (UTGA) begin shipping. (1500 cycles)
September 2008 Single, single-type two low self-discharge type begin shipping.
September 2009 Minister of Health, Labour and Welfare Award as the employment of persons with disabilities excellent office.
January 2006 AAA type (HR-4UTG) low self-discharge type begin shipping. (1000 cycles)
November 2005 AA type 2700mAh (HR-3UG) begin shipping.
November 2005 AAA type 1000mAh (HR-4UG) begin shipping.
November 2005 AA type (HR-3UTG) low self-discharge type begin shipping. (1000 cycles)
July 2005 Commendation award from the Japanese Red Cross Society.
March 2005 OHSAS18001 certification.
August 2004 AA type 2500mAh (HR-3UF) begin shipping.
November 2003 ISO14001: 2004 certification.
September 2003 AA type 2300mAh (HR-3UB) begin shipping.
September 2002 AA type 2100mAh (HR-3UA) begin shipping.
August 2002 ISO9001: 1994 certification.
March 2002 AA type 1850mAh (HR-3U) begin shipping.
April 2001 Transfer to Sanyo Electric Co,. Ltd from Toshiba Battery Co,. Ltd
May 1993 Building 2 new building construction and operation 6 floors.
October 1991 Nickel-metal hydride battery production start.
Product numbers of the actual cells have not been changed as far as I could tell.
Is this far fetched? Maybe.
Could this be a prelude to a “5th generation”? Who knows!
accumulator mentioned a couple of weeks ago, that he had found an unopened package for 1st generation AA eneloops with an April 2006 date code. His findings of the two cells from the package showed 72% and 73%
I also recently got a pair of 1st generation AA eneloops with a February 2008 date code. It came with the NC-MQH03 charger set from Singapore. I don’t have the fancy ZTS battery tester yet nor do I have the good Maha or La Crosse chargers to check this accurately yet. But, my cheapie Delkin tester showed 3 out of 5 lights. Not bad at all! I’ve decided not to touch them yet and will wait to test these for real on my friend’s La Crosse BC-1000 charger to get definitive results.
With Panasonic's ownership of the Eneloop brand, they've been doing some weird things to it over the past couple of years... who knows what will happen later this year?
I can't believe I missed Uniqlo's Eneloop t-shirts a couple of years ago!
I am just emerging from a dark age, having purchased my first high-power LED flashlight last month. It runs on 18650 batteries, but since the charger I bought, a Nitecore D4, can charge NiMh in addition to Li-ion, I decided to buy some Eneloop Pros. I selected the Pro, because I want the longer runtimes it offers in AA flashlights. I have 16 AAs and 4 AAAs arriving next week.
Since placing my order, I have learned that capacity and number of cycles are not the only differences between regular and Pro batteries. The Pro model is also better for devices that draw high current.
That's fine. My reason for posting, however, is this. The same post where I read about high-current draw said that regular Eneloops are better in low-current applications. I understand that they may be more cost-effective, but are they really better? Is there any reason I should not run my TV remote on Eneloop Pros? What about the AA flashlights I anticipate buying? Frankly, those will also be run on low-output settings most of the time.
From what I read, using high(er) capacity cells in low draw devices is bad because the cells sit mostly unused and internal resistance eventually increases until you go through a “refresh” cycle on a good charger. Not only that, using high(er) capacity cells in a low draw device is counter productive… they will self discharge before you even used up the cells. In other words, it’s not worth the cost!
For remotes and clocks, I’ve ended up getting a bunch of Eneloop Lites as they’re better suited for these applications. They are low capacity cells meant for low draw devices. Nevermind the fact that they have way more number of cycles than any one can practically use lol… At the very least, I feel it’s better to use regular Eneloops instead, which is what I’m using now in my DVR remote because that thing takes AAAs and sucks down batteries like none other
Other than high power flash lights, something that is better suited for Eneloop Pros are things such as camera flashes, hand warmers, cell phone battery booster packs, and electric shavers
