list of my drivers
Name
Diameter
Architecture
Development Status
Testing?
Controller
MOSFET
A22DD-L
22mm
DD+7135
1-side
WIP
Untested
n/a
LFPAK56
A17-Hybrid
17mm
DD+7135
2-sided
Retired
Light
n/a
LFPAK56
A17DD-L
17mm
DD+7135
1-side
WIP
Light
n/a
LFPAK56
A15DD-L
15mm
DD+7135
1-side
WIP
Untested
n/a
LFPAK33
A12DD-L
12mm / 13mm
DD+7135
2-sided
WIP
Untested
n/a
LFPAK33
A10DD-L
10mm
DD+7135
2-sided
WIP
Untested
n/a
LFPAK33
TK35_Thing
36mm / 32mm
options
1-side
WIP
Untested
n/a
LFPAK56
A17DD-SO8 (etc)
17mm / 20mm / 26mm / 27mm
DD
1-side
Released
Extensive
n/a
LFPAK56
A17DD-LDO
17mm
DD
1-side
WIP
LFPAK56
A10DD-33
10mm
DD
2-sided
WIP
Untested
n/a
LFPAK33
A22-7135
22mm
Linear (7135)
2-sided
Released
Light
n/a
A17PZL
17mm
Linear (7135)
2-sided
Released
Light
n/a
n/a
A17-L81
17mm
Linear (7135)
2-sided
WIP
Untested
n/a
n/a
un-named
20mm
Buck
2-sided
pre-WIP
Untested
MAX16820
LFPAK33
un-named
17mm / 20mm
Buck
2-sided
Retired
No good
QX5241
A17LDX / A20LDX
17mm / 20mm
Linear (FET)
Retired
Light
QX7136
LFPAK56
un-named
15mm
Boost
1-side
pre-WIP
Untested
PAM2803
n/a
Reserved.
EDIT: Nice to see this wight to bad u did not have a build list for each driver in the OP just hate searching the forums for them :)
Thanks nitro. It is a WIP, I’m trying to determine the best way to organize the data. I wouldn’t mind adding more information (including cart links among other things) but I don’t want to make some mega-table which won’t fit on anyone’s monitor…
Not a problem when i first posted i thought u was going to do links to the design thread and below that post the parts list and describe the driver,but that was before u posted the info
I need to add things like that, I want this thread to replace most of my signature.
The design threads are linked, so maybe just add cart links to each driver’s op? A lot of them share the same components, but still a lot of work. Maybe Nitro can volunteer to build the carts for you :wink:
Once i ship out all the X6 heatsinks ill help out with it
:beer:
:wink:
Your a very clever chappy. Thanks for all the work.
Thanks for your work, very helpful.
Added TK35 thing WIP driver. Updated table to include single-sidedness.
It’s not the best, but I think it’s ready to replace the sig links.
maybe bold the category row and title column?
and if you’re worried about width, the diameter box for A17DD-SO8 could be stacked into two rows within the box
Very handy table. Cool to see all the options you’re working on!
Cheers
Thanks for the index!
I’ve been pondering how to do something similar for firmware, too… had been thinking of using tags, but perhaps a table would work.
Also, the ANNDD-L series is particularly nice. :slight_smile: I hope to see these used in pretty much everything soon.
No wonder I lost track of all your projects…
Thanks a lot for contributing so much, so well, and so thoroughly.
Your work literally drives this forum forward.
