The day has come, had some sleep and got it done: sanded the spacer to size (1.5mm aluminium is almost an hour sanding) and while the light was open, decided to have a go at the red Noctigon with a black marker, I have enough triples with red front end, and this light is all black and silver so black suits it well. And the head closes perfectly now :heart_eyes:
OK after only removing 2 stars from a flashlight I wanted to bake the X5
The wires to the star need to be desoldered and thus also soldered back on
The space in the X5 is not very large but YAY I am proud of myself, I managed to solder them back on and the light is working while looking different.
Well I thought the Kronos set is HA3 right?
I baked the X5 just now.
It took very long to change color, much much longer then the rest.
It shined bronze/golden very brief (too short for even tone) and well I didnāt dare take it further so here is the result:
I didnāt bring it up at the time, but I didnāt really understand why black HAIII couldnāt be baked to a different color. I was under the impression that HAIII has a smaller pore size and thus is unable to be dyed lighter colors. I was also under the impression that HAIII required dye to reach a āblackā color rather than the dark ānaturalā color. My understanding is that the dye is what changes when baking - why wouldnāt this also apply with HAIII?
OTOH baking HAIII to achieve a light color seems pretty questionable and may indicate that itās actually Type-II anodizing.
EDIT: With that said about the ādarkā colors, some fairly reputable folks have claimed to sell HAIII in some very light colors. Iām specifically thinking of PhotonFanatic and Fivemega.
It certainly acted different from all the previous baking sessions.
Those were done in a less then 2 minutes, this took longer, as if the alu struggled to make the change.
First my old SRK, now with a 32x 380mA 7135 driver, Noctigons, springs bypass, extra copper heatsink and illuminated aluminium switch.
Second was my Xeno Cube triple, now with 3x XP-L HI on Noctigon, Carlco 10507 TIR optic, handmade 5x19mm copper spacer, spring bypass, trit and 17mm FET driver. 6A startup from a Red Trustfire 14500 IMR cell.
This one is my favorite! Pulls 1.3 amps with regular cr123s, and 3 amps with IMR123s. Per the Cree product characterization that is good for 1100 lumes and 2300 for this J4 XPH-50. On the IMR batteries it will make you giggle!
Beamshot on low, 2 feet. This has no donut holes, just one sweet smooth beam. Oh, and exposure on phone is ā2 for the shots. These are with just cr123 batteries
Today I decided to mod an old friendā¦ guess the model and year of this light!
This pic might give you a hint as to how old is itā¦
Look at that cutting edge led (Back in the day!)
Had to drill that delrin retention disk to get it out
Yep that is an old led, do you remember what it is? Think hard now!
Now, what to put insideā¦ Decisions, decisions, decisions!
One thing I never understood is why dafuq did jetbeam think this was a good idea! a frigging HOLE right in the center where the led goes!!! WTF!!!
We have a winner!
Here is the results!
Left is this Jetbeam Jet II IBS on highest setting, at the right is the Manker T01 on turbo, Not bad for an 8 year old flashlight!
Well, I took a Nitecore EA41 Pioneer, removed all the guts, made a custom heatsink from some copper, had Richard over at MtnElectronics make a momentary switch MtnMax driver running 12v at 2 amps, and stuck it all in the housing with an XHP-35 HI and 4x14500ās. Now I have an EA41 with an XHP-35 HI in it!
Iām sorry, I had to giggle a little bit on this oneā¦
Some pictures surely intensify the feeling.
Donāt you just hate it when a mod doesnāt go as you planned?
I say hit it with some MAP gas and see it if respondsā¦LOL
I really like it. it went from 35k candela stock to now just over 77k. It gets pretty warm in high, but itās very usable in the lower modes. Iāve been wanting to make a light with that led in it since it was released. I happened to find that the ea41 had the batteries in series and BOOM, that was all she wrote.
