The other half of the comparison thread - Modding the Nitecore EA4 - It's DONE and Beam Shots are up!
28 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Well, I did an EA8 already, so what could be different about modding an EA4? Four less batteries...
ea41a
Here's the light torn down. It has the same thin star and thin heat sink plate. It has the same plastic holder for the heat sink, switch, driver/contact plate, so it's the same as the EA8. The problem is it's only four NiMHs, so I will be using an XM-L2 led.
ea41b
Instead of getting rid of the stock plastic holder and the stock thin heat sink plate, I'm just going to back that thin plate with some copper.
ea41c
That copper round will now fit tight in the body. I made that thing out of 3 squares of copper. I cut them to hexagon shape, flattened them and soldered them together with pressure. Then I filed and finally used a small sanding drum on the drill press, to get the shape. I had some aluminum rod stock the right diameter, so I used it to trace the pattern. I think it's going to work out well.
ea41d
I will cut down the plastic holder so that when it's all together it will still be the same stack height. I believe there will be a lot better heat sinking with this. I will have enough room to slide a DrJones driver in and I will strip the driver so I can keep it as the upper contact plate.
ea41e
I have an XM-L2 T6 3C and I have a 3amp DrJones driver. I will add chips to bring it to 4 amps (around 4 amps- 3040mA +350+350+350=4090). I am not sure if I will use the switch that is on the star already or the black one next to it. Both are momentary, but the black one has a nice soft click to it, so I may use it.
It's finished, here's a couple more photos.
ass23e
The driver is now just a contact plate.
dstr76
smd switch is in place
bnhmyu9
DrJones driver is glued in place
wed5456
Other side, with the switch wires on
dfvt769
The whole pill, ready to go
fgbuui
It's finished, now for beam shots
 Beam Shots. These are Mouseovers.
The Mouse Out is the Modded Light  and  the Mouse Over is the Original Light on Turbo.
All settings were the same on the camera.
ae4mo1
ea4mo2
ea4mo3
ea4mo4
ea4mo5
The XM-L2 I used was supposed to be a T6 3C, but I doubt it. I think it was a cooler tint than 3C. The stock light was a warm. It was an EA4W, so this shows a good example of warm versus cool.
That's all Folks. I'm done.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 06/03/2013 - 03:17
Dale
Dale's picture
Last seen: 2 years 3 months ago
Cant wait to see the comparisons after the mods
Bort
Bort's picture
Last seen: 1 day 3 hours ago
i’m a bit surprised you didn’t stay with the stock driver since it should work fine with xm-l2
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
jacktheclipper
jacktheclipper's picture
Last seen: 6 hours 10 min ago
Old-Lumens
Bort wrote:
i'm a bit surprised you didn't stay with the stock driver since it should work fine with xm-l2
Once I add the extra heat sinking, there won't be room for the stock driver.
Bort
Bort's picture
Old-Lumens wrote:
Once I add the extra heat sinking, there won’t be room for the stock driver.
how long can the 4 nimh stay in regulation on the 105c driver?
Slim Pickens
Slim Pickens's picture
Last seen: 3 days 1 hour ago
Eh probably the entire runtime. Eneloops jump off a cliff shortly after reaching 1.05V at a 5A load.
Based on HKJ’s excellent plot of V vs. Time I reckon between 20-25 minutes continuous full output on High.
Old-Lumens
The light is finished and beam shots are up, in the OP.
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
That’s quite a difference in output.
Awesome shots.
MRsDNF
MRsDNF's picture
Last seen: 20 hours 54 min ago
Thats quite an improvement. Are you happy with the way its turned out? Which light do you prefer now after the mods? I sound like a broken record.
panthervision23
Last seen: 6 years 2 months ago
Those beam shots are good… really good! You did a good job in modding the FL.
troisanh
Last seen: 7 months 4 days ago
Nice mod as usual, think i gotta pick this up.
Pinetreebbs
Pinetreebbs's picture
Last seen: 1 month 1 week ago
jacktheclipper wrote:
Yes indeed.
Old-Lumens
I'm happy with the fact that the copper really puts the heat out to the body now. When I fired this thing up to do beam shots, the body was warm in less than 30 seconds and after a minute there was no mistaking that this thing was pumping the heat out. Output is better than stock, but it's also a cool white versus a warm white, so much of that is just the fact that cool white always "looks brighter". Overall it was a success, but if I had to choose, I would choose the TR-A9. It has a more defined beam and is a better thrower. It's slightly heavier and I like that. It also does not feel like it's going to fall out of your hand, like the EA4 does. The EA4 is slick and harder to hold onto.
The A9 has issues in stock form. It is touted as 2s/2P, but I found that it was manually changed to 4S by someone along the way. The light I got was 4S in configuration and that's not at all necessary unless they had the wrong drivers for 2S and had to change the lights. It has a cheap glass lens and that's the biggest downfall for me, along with the poor output in stock form.
My vote goes for the A9 in modded form and the EA4 in stock form.
jmpaul320
jmpaul320's picture
Last seen: 4 hours 25 min ago
wow – nice mod!
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Chloe
Chloe's picture
Last seen: 3 years 8 months ago
Thank you for the pics! It looks brighter, more spill, but I do prefer the warmer tint.
I was wondering if the stock heat sinking could be improved but I guess there isn’t enough room.
relic38
relic38's picture
Very nice mod! I need to find some copper to do press in heatsinks for some other lights.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
LightSeeker
Last seen: 1 day 2 hours ago
An MT-G2 with 14500s in the ea4 body would have been cool given the improved the heatsinking. Despite what appears (from your ea8 teardown) to be a small contact between the heatsink pad and the walls of the body, my stock ea4w seems to gets warm almost immediately. In a low power device like the XM-L led is there more heat generated than the flux between the 2mm disc and the body can handle? If not they’d probably get quite a bit of mileage simply by improving the interface between the parts.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Is that the same micro switch you referenced before? Nice build. I learn with each build but it’s still hard to acquire more skill doing infrequent work. You do an excellent job pushing your skills to keep up with your enginuity.
Scott
Old-Lumens
Rufusbduck wrote:
Is that the same micro switch you referenced before? Nice build. I learn with each build but it's still hard to acquire more skill doing infrequent work. You do an excellent job pushing your skills to keep up with your enginuity.
Both sytles of switch came from Spark Fun.
sb56637
sb56637's picture
Last seen: 4 hours 16 min ago
Old-Lumens wrote:
ae4mo1
This is my favorite shot. Apparently your new mod is so powerful that it vaporized your garbage dumpster! Shocked Better be careful with your garage door too. :bigsmile:
mhanlen
mhanlen's picture
Last seen: 2 months 4 weeks ago
Question. How easy is the switch to remove. Most importantly would it be easy to replace the rubber switch boot? Is there any locktite on the light or is disassembling it pretty straight forward? I have taken apart about 6 or 7 lights- but my concern with this one is screwing it up because it might be sealed.
Old-Lumens
There is no loctite. The "pill", consisting of the led/star, driver section (plastic) and the contact plate all come out the front, by pushing from the back, (against that upper contact plate. I used a 1/2" rod against the contact plate and tapped lightly till it all came out.
You can replace the rubber boot after that is all out. It can be troublesome to fit it all back in, since nothing really holds the boot in. There's a boot and button and all that has to be laid in the light and then the rest has to slide back in in proper alignment.
mhanlen
mhanlen's picture
Old-Lumens wrote:
There is no loctite. The “pill”, consisting of the led/star, driver section (plastic) and the contact plate all come out the front, by pushing from the back, (against that upper contact plate. I used a 1/2” rod against the contact plate and tapped lightly till it all came out.
You can replace the rubber boot after that is all out. It can be troublesome to fit it all back in, since nothing really holds the boot in. There’s a boot and button and all that has to be laid in the light and then the rest has to slide back in in proper alignment.
Thanks for the prompt response. Nitecore is offering a replacement on these lights if you email their service department. But only if your boot is comprised of the old material and is currently defective. While my boot for now is ok, I see the eventuality of my piercing the boot or something (inadvertently) and having to replace the switch. Only Nitecore is saying it does not want you to attempt this yourself. Of course the boot may degrade several months down the road because it is made of the old stuff. Anyway, it’d be nice if you could just buy some of these switches. Oh and going back and looking at your ea8 thread, man there’s some cheap “S” inside, isn’t there. I guess all the money is in the driver design, and not the build materials. Oh well. Anytime I ever spend this much again on a light, I’ll look for a full dis-assembly first.
Essexman
Last seen: 6 hours 49 min ago
Hiya matey, can you give any more details on the switch used in this mod please?? I’m doing a similar mod having been given a broken EA4 to play with. But I’m having trouble finding a suitable switch to use.
Rufusbduck
The black switch looks just like the momentary switch on some lasers I destroyed experimented with.
Scott
theFLASH12
Last seen: 6 years 5 months ago
Has anyone replaced the black switch side cap with a more translucent cap?
comfychair
comfychair's picture
Last seen: 3 years 11 months ago
Rufusbduck wrote:
The black switch looks just like the momentary switch on some lasers I -destroyed- experimented with.
LOL, you too? I finally had to make the decision to just avoid lasers completely, they don't survive more than about 5 minutes after I first touch them.
