ryansoh3
(ryansoh3)
August 14, 2013, 4:20pm
1
Hi all, I thought that it would be good to have a thread dedicated to where to find great information about LED's, optics, drivers, batteries, and much more. In other words, I wish this would be a go-to thread for all your basic flashlights needs.
Please help us categorize threads, and all feedback is appreciated. Don't hesitate to link others' threads as well as your own, if you feel like they contain valuable information.
I. LEDs
General
Emitter Tests
Reflowing
Dedoming
Purchasing
II. Batteries
General
Reviews
III. Flashlights
General
Modding
Tear Downs
Anodizing/Finishes
Flashlight Parts
IV. Measurements
General
Digital Multi Meters
Lux Meters
Integrating Spheres
Last updated: 8/16/13 11:56PM KST
ryansoh3
(ryansoh3)
August 14, 2013, 4:22pm
2
Reserved for personal notes.
Off to sleep, see you guys in the morning!
gadabout
(gadabout)
August 16, 2013, 2:12am
4
Great Eneloop overview thread by ChibiM
Panasonic eneloop and Sanyo eneloop overview
I`m currently running a website called eneloop101.com which is built solely around Sanyo and Panasonic eneloop batteries , charger and products.
Also check out the smart analyzer and best rechargeable battery chargers for eneloop and other NiMH + Lithium Ion batteries or go to the overview page the the complete panasonic eneloop charger list.
If you're Japanese or living in Japan, check out my new website: chibim.com
Overview of all Eneloop B…
Racer
(Racer)
August 16, 2013, 3:30am
5
Nice. What about useful links outside this site, like battery university?
ryansoh3
(ryansoh3)
August 16, 2013, 4:22am
6
Thanks guys, added the Eneloop overview and Battery University.
RaceR86
(RaceR86)
August 16, 2013, 11:02am
7
I dont want any credit for the BLF LED Database, I do some maintenance, but several others contribute. I want it to be a community collaboration.
Emitter tests, these covers most:
_philippe
(__philippe)
August 16, 2013, 12:47pm
8
Chloe
(Chloe)
August 16, 2013, 1:12pm
9
Recent thread about anodizing:
Ok, so I’ve been doing some reading on anodization. It seems there are sub levels, even within HAIII, HA II, etc. Then there’s also those who can tell the difference between HAII and HAIII, even if the manufacturers specs say something different. My question is, how does one tell the physical difference and feel between II and III- based up touch and look?
Soldering setups:
Hi guys,
After recently completing a mod on my JM07 I’ve decided that the cheap $2 chinese soldering irons are not the way to go for future mods, especially considering the one I’m using doesn’t seem to get hot enough at the tip even at 60W.
I’m going to buy a new one on the net somewhere. Any advice, in particular on soldering vertical (when relying on the tip of the soldering iron).
Are flat tips better? How many Watts would you recommend?
Tool recommendations:
Hello fellow flasholic+modders,
I’m looking to mod my SMALL SUN ZY-T13 (T40cs clone) like the links below. It’s under-driven and I won’t stand for it
Do you have any recommendations/deals for tools?
I know I’ll need a decent soldering iron with a fine tip, and something to measure voltage and current. Depending on how this goes, I hope to mod more in the future.
Thank you for your help!!
Two threads on DMM leads:
one thing i dont get is people modifying digital multi meter (dmm) leads i have a cheap dmm and a fluke dmm they read very very close to each other i belive the fluke leads are calibrated with the unit (and should not be changed).
i also belive the cheap dmm is to, i have used shorter larger dia leads with less resistance it gives higher current draw test on the cheap meter but when compared to my fluke dmm and a family friends new fluke the readings are much higher more impressive but to me th…
Using my Excel XL830L cheapie multimeter, just tried measuring some tailcap readings and get consistently lower readings.
Leads too thin? I’m using some leads that labels itself as MASTECH 1000V CAT III 10A, bought it at local supermarket.
Would a Fluke test lead be good?
I’m expecting some people to reply DIY own test leads (btw can’t find any good guide to DIY thick leads), but I’m wondering if there are ready-made around.
Cerakoting lights:
Hi folks,
With the recent arrival of several Star Wars-themed lights, I thought it appropriate to add my take on the theme.
Here are some Stormtroopers.
White Cerakoted Solarforce L2T with custom head and black Cerakoted Klingon bezel:
[image]
[image]
[image]
Solarforce L2i body, custom finned head in white Cerakote, coated tailcap:
[image]
[image]
[image]
Custom grooved and Cerakoted Solarforce L2i body, custom white bezel ring:
[image]
[image]
[image]
Solarfor…
Resourceful reflowing:
[image]
I did my first reflow work today and discovered that it was so easy that I had to report it here.
I reflowed 5 bare nichias to 16mm stars for XP-G’s in less than 5 minutes including a function test of each. And the result is excellent.
A year ago I bought some solder paste but have’nt really used it:
http://www.dealextreme.com/p/lodestar-soldering-paste-50g-4711
It had hardened some (solder paste should be kept in a refrigerator) but I managed, with tweezers, to put small blobs of i…
Sourcing o-rings:
I’m looking to order some o rings. I need a size chart and good place to order from.
DIY integrating sphere:
Gentlemen,
(Foy inspired quick summary: I made my own I.S. using a $2 big rubber ball, paper mache, and a luxmeter[image])
[image]
When I was into building disturbingly fast street cars, one tool that I always wanted was my own personal dynometer so I could accurately test/tune the fruits of my labor. Seeing as how they cost over $15k and would take up the entire garage, I was stuck either finding a local shop with one or testing at the local drag track.
For reasons I can't fully…
ryansoh3
(ryansoh3)
August 16, 2013, 1:37pm
10
Updated until Chloe’s post, thanks a lot guys.
Keep up the good work!
brted
(brted)
August 16, 2013, 3:02pm
11
I appreciate what you are trying to do, but I would encourage people to visit the Flashlight Wiki and contribute there as needed. Information gets lost in threads (even if it is stickied since we have so many sticky threads) and the only person that can change anything is the person who writes the thread when the information gets out of date. Anyone can edit the wiki and keep it up to date, you can even disuss the page behind the scenes in the Discussion tab. You can link to threads or use footnotes in wiki articles that link to where the information came from (kind of complicated to do footnotes, but it is pretty neat).
Not all of what you are linking would probably belong on the Flashlight Wiki, just because some of it is so very specific (a teardown of a particular light). Some of the information could just go on the wiki (there is a section on Anodizing on the wiki which mentions a lot of what is in the recent thread). But I think a wiki can handle a lot of the information that people might refer to over and over again.
I now yield the soapbox.
