I won this light in a recent Five Flashlight Giveaway hosted by Aurabuy. The SKU is FLFA1XX02233A. Thank you Aura!
Summary:
This is a pretty nice light with a lot of mod potential. It’s has lots of power storage (4 parallel 18650’s) and a fairly big reflector. It’s beam profile is much like the Small Sun ZY-T08/T13, but the hot spot and spill are a little smaller. As would be expected, It throws further than the T08 stock. Measured 54kcd on my meter at 3.45 amps. The beam is slightly ringy against flat walls, but not noticeable outside. There is a slight green tint outside of the hot spot.
It has a handle that my wife really likes. We live in the country with no nearby area lighting. She has been grabbing this light lately when going out in the dark. The light does have one major flaw though. It has next mode memory. The driver looks familiar. I’ve seen mod threads on in before. If anyone knows a mode mod for it, please post it in this thread. Current measured:
High - 3.45 amps
Med - 1.20 amps
Low - .21 amps
SOS - Didn’t Measure
Strobe - Didn’t Measure
Here is a summary of Pro’s and Con’s:
Pros:
- Looks good
- Has a good quality finish
- Lots of heat sinking potential
- Holds 4 18650’s
- Large deep solidly built aluminum reflector (62mm OD x 57mm ID x 48mm deep)
- Has nice handle
- Glass lens (64mm by 2mm) - Not AR coated
- All threads anodized
- Has 10 AMC7135’s on a 46mm driver for 3.5 amps
Cons:
* Next mode memory
* Very thin wires for the emitter.
* Rolls until handle touches ground
* Hollow pill that was not properly thermal pasted *
The pill is quite large and has a decent sized lip for the outer edge of the 25mm base to sit on. It appears to be adequate for stock usage. If modded for more current, the pill would need to be modified. There was thin disk pressed in the pill. The disk was bowl shaped from being pressed in by thumb or something. It is very hard to bend for it’s thickness. Maybe a harder aluminum alloy. Even if it is aluminum, may actually interfere with pulling heat from the emitter as it is thicker than the depth of ledge that it sits on. Also, the ledge it sits on is much smaller than the ledge the emitter base could rest against. So the disk is only in contact with the emitter. At a minimum, I recommend pulling out this disk and using thermal paste around the emitter base. Better yet would be to modify or replace the disk with a thinner disk that is level with the upper ledge.
The light came in a gift box. Unfortunately, the trip was rough as it was clear the package had been crushed at least once. Fortunately, the light was well packed and undamaged:
Here are some break down shots:
I think the bezel is aluminum.
The thin disk may not be aluminum. It was more bowl shaped before I pressed it out of the pill.
Back of head and pill:
Pretty nice reflector:
All threads anodized:
Beam is about 11 feet in diameter at 10 feet. Hot spot is slightly smaller than ZY-T08. Not evident below due to the close proximity to the wall (about 2 1/2 feet) and maybe the ZY being held further from the wall. ZY on the right:
