KD (kaidomain): Deals and new products thread
1787 posts / 0 new
vwpieces
vwpieces's picture
Last seen: 1 week 4 days ago
And if you are ordering from MtnE he will reflow any in stock emitters for free, bare or on another board. He does excellent work. I have tried and it gets frustrating to get the 3 emitters and jumpers done and done right. I will never do a Tpad quad again. 3XP are easier but still… it will be done right from Richard.
kiriba-ru
kiriba-ru's picture
Last seen: 2 hours 2 min ago
Maybe KD is interested in producing 20mm quad dtp boards? Tpad are Sick
giorgoskok
giorgoskok's picture
Last seen: 2 days 23 hours ago
Interested too , in more than 5 pieces . 20mm , quad , for Carclo 10621 / 10622 optics etc , 1.6-2mm board thickness , dtp , copper .
kiriba-ru
kiriba-ru's picture
No etc.
Carclo compatible only.
Round milled board with 5 drilled holes.
I can help with design to avoid usual problems.
Will take 50-100pcs from first batch and more in future.
Production methods and self-cost is same too other noctigon-style KD boards, so target price is $3.5 per 2pcs.
giorgoskok
With “etc” i meant frosted version of 10621 / 10622 like 10623 , 10624 .
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 32 min ago
Yep I agree T-Pads Sick ! Make a 32mm triple board in the KD Black! I would really like it if they made both, dedicated parallel boards also, dislike using jumpers! Thumbs Up
KB1428 “Live Life WOT
vidramon
Finnaly I can log in into my KD account on their site.
Same error like first time, add to cart, click checkhout with PP, go to PP, pay then automatic get back to their site with this error :
Any other of you have this problem ?
vwpieces
vwpieces's picture
A simple Parallel design similar to Manker, Mateminco, or who ever it actually is. But Must fit Carclo and have the Negative on the outer edge. Yes, with some Meat on the board, Not thin. Please.. Cash
Nicolicous
Nicolicous's picture
Last seen: 27 min 30 sec ago
i’ll be interested in quad pad / Tpad 20mm diameter that fit Carlo optic too.
i will get 10- 20 depending on price Big Smile
Nico -.-
kiriba-ru
kiriba-ru's picture
no no no
I will help with the design.
Problems with traces short-cutting to the body can be simly fixed other way.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 8 months 1 week ago
I want to mod my S2+ with a 219c triple.
I bought the LED´s from Clemence. Now i need the other Parts.
Will this fit? Driver is a MTN FET + 7135 Driver
- http://www.kaidomain.com/p/S023167.3-in-1-20mm-Optical-Lens
- http://www.kaidomain.com/p/S026381.KDLIGHT-Triple-3TP-20-DTP-Copper-MCPCB-for-Cree-XP-Series-Nichia-219-Series-3535-LEDs-2pcs
- http://www.kaidomain.com/p/S024023.DIY-22mm-x-8_5mm-Brass-Driver-Pillar-... (will this pill fit if i add copper spacers?)
And i want to upgrade my UF-1504 with a new XP-L2 LED.
Which LED should i take for max output? Driver is a MTN FET + 7135 or a LD-2 with a 100K current resistor (= max 9A)
1: http://www.kaidomain.com/p/S026205.Cree-XP-L2-HD-White-6500K-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
2: http://www.kaidomain.com/p/S026461.Cree-XP-L2-HD-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
I will use US18650VTC6 as powersource.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
mattlward
mattlward's picture
Last seen: 2 days 56 min ago
I just got in an assortment of the KD DTP copper stars a week ago… I have to say, they are really nice. They are flat, black and dimensions are good. I will use more of these.
Thanks KD, now I will have to order more led’s.
Matt
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
MILSPEC
Last seen: 1 week 14 hours ago
received mine too, very good packaging and quick shipping. My triples aren’t flat though. They are slightly bent and only a good amount of sanding makes them somewhat flat. Having said all of that – they work 100%. If anything this seems like a cosmetic issue.
Now I need to buy more emitters and hosts.
KawiBoy1428
Warning KD Black stars, de-doming a couple XHP35HD E2-1A’s in racing fuel, and the substrate is lifting, guess I have a couple more 20mm copper spacers!
Jerommel
Jerommel's picture
Last seen: 5 days 43 min ago
Ooh, that’s not nice.. Sad
I wonder how they will hold up in regular fuel and other solvents..
I have a bunch of KD boards, and they’re all quite as flat as Noctigon.
Only the triple boards are deeper in the middle.
mattlward
mattlward's picture
I did not try any triples, very happy with the Noctigon ones. I will have to watch them when removing domes, I always solder the led on before I soak them to remove the dome. Have not tried any of these in gasoline.
Matt
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
TheOnlyDocc
I hope that KD can get the new XP-L2-W2 LED´s until the BLF Q8 is ready to be sold.
This will be a lot of work and also not realy cheap but well worth. The Q8 + 4 new XP-L2-W2, a new XHP50.2 as upgrade for my modded TN31 (K40M driver with resistor mod and dedomed MT-G2 LED and i added a lot of copper to help with the extra heat), and a XP-L2-W2 upgrade for my UF-1504.
TheOnlyDocc
I have one question. I bought a few Cree MC-E RGBW LED´s. Now i need the MCPCBs.
Is this the right one for the LED?
http://www.kaidomain.com/p/S008602.20mm-D-x-1_7mm-T-Aluminum-Base-Plate-...
http://www.kaidomain.com/p/S006044.21mm-Parallel-Star-for-CREE-MC-E-5PCS
LightRider
LightRider's picture
Last seen: 2 years 1 month ago
Yes those would work
djozz
djozz's picture
Last seen: 3 hours 40 min ago
And don’t go over 700mA per die, that is really close to the max already.
TheOnlyDocc
I want to use 5 MC-E Led´s for the Lamp. It will be a Lamp for the living room. The led´s are pointing towards the ceiling. I want to use Aluminium profile 40*40mm and 50-60cm long.
Then a remote controller like this (https://de.aliexpress.com/item/44-Key-6A-IR-Infrared-Music-Remote-Contro...RGBW-LED/32710601191.html) which is controlling 4 of this drivers (http://www.ebay.de/itm/1-Stueck-1000mA-KSQ-8-32V-Input-0-30V-Output-dimmbar-/351975399530?orig_cvip=true).
And each driver controlls one color. Powersupply is 24V DC. And finally i have to find a optic with a really wide spot.
@djozz would it be better to reduce the current to 500-600mA/die? If all dies get 700mA the LED gets a total of 2,8A. I think that this could get really warm without extra effort regarding cooling.
LightRider
!https://s22.postimg.org/a26ou8xkh/IMG.jpg!
I love your project! Very nice:)
The full 1a per die may be a bit much if all are on at the same time. But then again, if it were me I would find a way to use the full power Wink Can you add some cooling fins or added heatsink to your aluminum profile?
Edit: Actually I see that 700ma is the max rated current for these dies. I don’t think I would top that especially without a direct path mcpcb.
finges
Last seen: 3 days 17 hours ago
Any opinions on this new (?) driver for 6V leds? http://kaidomain.com/p/S026606.H1-A-20mm-3A-1-cell-5-Mode-Boost-Driver-C...
Can it work with an e-switch? It would be nice in a Skillhunt H03 Smile
Lexel
Lexel's picture
Last seen: 44 min 48 sec ago
Finges I am currently working on a Narsil FET+7+1*7135 driver set up with thermal management
If the Narsil works out great I will have a spare H03 driver
The H03 one has too high voltage drops as the current has to go through the inductor and a small transistor
@3A the losses on the Skilhunt driver are 410mV, so a fresh 18650Q cell can reach 3A only with both springs bypassed for a short amount of time
And I dont like the timed stepdown
The UI is OK
An Attiny13A 7135*8 driver with eswitch firmware is also an option, but not priorized atm
You could get a XHP50 with boost driver in there, but I see thermal issues.
Jerommel
Jerommel's picture
Does the H03 have a step down driver?
Does it work on 6 Volts too, or even 8.4 Volts?
finges
No the driver I linked is for 1s only
Quote:
Input Voltage: 3V – 4.2V ( 1 Li-ion )
It boosts the voltage from 1 cell to power 6V emitters like XHP50, MT-G2 etc.
Lexel
Lexel's picture
Jerommel wrote:
Does the H03 have a step down driver? Does it work on 6 Volts too, or even 8.4 Volts?
The H03 has a stepdown driver up to 8.4V
Terry White
Terry White's picture
Last seen: 1 year 12 months ago
I have never ordered from them... Just found some tail switches I need badly and signed up ready to place my order and it says account not activated...
Anybody know a US vendor with 12mm*8mm*8mm for sk68's.  Ordering from anywhere else just ain't working tonight for some reason.
Terry White
Skype terrywhite1@live.com
finges
Send them a email they have problems with the register system atm.
I created an account not long ago and everything else did go smooth!
BanL
Last seen: 2 hours 9 min ago
Terry White wrote:
I have never ordered from them… Just found some tail switches I need badly and signed up ready to place my order and it says account not activated…
Anybody know a US vendor with 12mm*8mm*8mm for sk68’s.  Ordering from anywhere else just ain’t working tonight for some reason.
Hi friend
Please PM me your details or send an email to sales@kaidomain.com for further assistance.
Please don’t be worried. We will send the email activation email to you later.
Thank you
Ban
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
