KD (kaidomain): Deals and new products thread
879 posts / 0 new
hank
hank's picture
Last seen: 2 hours 16 min ago
Quote:
http://budgetlightforum.com/comment/1157296#comment-1157296
That’s impressive testing. Good to know.
LightRider
LightRider's picture
Last seen: 3 months 3 days ago
Ollie wrote:
George, The pill has a good fit, the computer grease was just because I had it apart. But the fit of the reflector to the head is very loose. Take a bare head and a bare reflector; slide the reflector into the head, and look at the fit from the back. The only place the reflector touches the head is at the very front, at the lens. Room for improvement. The pill is pretty thin, too. I’ve “potted” them with lead-free solder. That’s probably unnecessary for the 3 Amp builds I do on a C8. Ollie
This is not uncommon actually. Most lights work this way and many only touch the lens at the end and the led centering disc at the mcpcb
BanL
Last seen: 1 week 2 days ago
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
giorgoskok
giorgoskok's picture
Last seen: 5 hours 53 min ago
Ordered ! thanks Ban !
BanL
Ha Big Smile
Thank you for your ordering.
bwl123
bwl123's picture
Last seen: 2 weeks 6 days ago
Hi BanL
Will it be possible to make this driver with a 17mm board?
http://www.kaidomain.com/p/S026606.H1-A-20mm-3A-1-cell-5-Mode-Boost-Driv...
glide 1
Last seen: 3 months 4 days ago
Im trying to get more info on this driver – http://www.kaidomain.com/p/S024906.FX7-17mm-2_8V-4_8V-3A-5-Mode-LED-Driv...(1-pc)
Hoping someone has used this driver and would be able to give us first hand information.
Current: Max. 3A
Lo : 300mA 4.6V Med : 1200mA 4.6V Hi : 2900mA @ 4.6V
- Interesting why amp rating is measured at 4.6V.
- Is it possible to do a resistor mod?
Barkuti
Barkuti's picture
Last seen: 2 hours 56 min ago
Presume a worst case scenario. Most useful input voltage value to make an output measurement is, in my opinion, the smaller voltage at which it still can maintain regulation. With an XM-L2 at the output most 7135 linear based drivers will maintain regulation at least down to 3.7V, and if PWM frequency is too high the voltage figure for mid and low modes will be even higher. Of course this is not based in 7135 regulators, but I said that to put this into perspective. That driver may not be able to stay regulated within an usual loaded li-ion voltage range (3 to 4V). This is how I believe we should teach these fellow testers how should they proceed. Thus, to answer your question:
Current is measured at 4.6V because the driver is a PoS and cannot stay in regulation below that voltage. Done.
Cheers Party
glide 1
I sort of get what you are saying Barkuti, and thank you for the explanation.
It is supposed to be a regulated driver and yet it will struggle to do just that at the typical voltage range of a li ion battery.
Barkuti
Barkuti's picture
Not exactly that, glide 1. That thing sort of pissed me off a little bit, I find it misleading. For a linear driver like that, I'd prefer to see the figures for ≈3.7V (or the minimum input voltage at which it keeps regulation -specifying the driven emitter-) and maybe somewhat below to see how it evolves.
This is not to say that 4.6V figure is not useful, it may be a useful figure for those aiming to use 4S Ni-MH input at the driver. Even in such a case, I'd complain because I always want to see worst case scenario figures, which for 4S Ni-MH would be below 4V.
Accepting those figures would be like accepting Ben Johnson's Olympic 100 Meter final record in Seoul, 1988. Sort of.
BanL
Hi
CREE XHP70.2 P2 1C White 6000K to 6500K is available and only US$10.99
http://www.kaidomain.com/p/S027059.Cree-XHP70_2-P2-1C-White-6000K-6500K-...
Thank you
Jensen567
Last seen: 1 week 1 day ago
Any plans to sell the driver separate from these new P60 drop-ins?
http://www.kaidomain.com/p/S026583.New-KDLITKER-P6-NIC-219C-Netural-Whit...(L-M-H)-OP-LED-P60-Drop-in
BanL
Hi
If you interested in this driver, you can send to our sales@kaidomain.com for further details
This driver has two version. Once is with 2500mA to 2600mA and you need to have a better heat dissipation.
Another once is 2000mA, that is the version installed on the current P60 drop in.
Thank you
BanL
Hi
New batch CREE XHP50.2 5000K arrived to KD
Cree XHP50.2 K2 3B Neutral White 5000K LED Emitter US$7.29
http://www.kaidomain.com/p/S027073.Cree-XHP50_2-K2-3B-Neutral-White-5000K-LED-Emitter
and more other XHP50.2 bare LED are available in KD
http://www.kaidomain.com/Search/SearchResult.XHP50.2/379
Thank you
Agro
Last seen: 16 min 24 sec ago
K2 from non-cutter store? Sounds like a deal!
Tom E
Tom E's picture
Last seen: 3 weeks 2 days ago
Keep the new stuff roll'n KD!
If you could please look out for SST-40's in higher bins, and lower temps, like 4000K-5000K. I got in 3 of your SST-40's - will be testing them soon! Everyone who has used them got good results.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 min 27 sec ago
Yes! I would like to see the higher bin SST40’s also! Thumbs Up
I would like to also request Higher Bin XHP35’s E4+ and Colder Tints 75000-8000k if possible please! I have purchased many of the E2-1A’s HD’s for de-doming, best tint so far 5200-5000k, no yellow, a very nice neutral white. Would like to shoot for something around 6000-5700k de-domed.
KB1428 “Live Life WOT”
g_sintornillos
g_sintornillos's picture
Last seen: 2 min 36 sec ago
Tom E wrote:
If you could please look out for SST-40’s in higher bins, and lower temps, like 4000K-5000K.
+1
Sorry for my bad English (gogole translator)
Jerommel
Jerommel's picture
Last seen: 8 hours 19 min ago
Tom E wrote:
Keep the new stuff roll’n KD!
If you could please look out for SST-40’s in higher bins, and lower temps, like 4000K-5000K. I got in 3 of your SST-40’s – will be testing them soon! Everyone who has used them got good results.
They also have Vf bins.
The lower the better i would say.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
Tom E
Tom E's picture
They also have Vf bins. The lower the better i would say.
Wut? What's Vf bin? I only see N4 listed for SST-40's: http://www.kaidomain.com/Search/SearchResult.sst-40, and in the specs, looks like N4 is the middle bin:
http://www.luminus.com/products/Luminus_SST40W_Datasheet.pdf
Jerommel
Jerommel's picture
In the PDF under the flux bins it says “Forward Voltage Binning Structure”, and it ranges from 2.5 to 3.3 Volts (!).
But i see now it also says: “Individual voltage bins are not orderable”.
So never mind then… Oops
Jensen567
Just have to hope to get a good one. The VJ bin KD has is pretty good, with VH being the only one better. A higher flux bin with a lower voltage bin will be more efficient.
L4M4
L4M4's picture
Last seen: 4 hours 44 min ago
Since these LEDs are under 2$ on AE you can just grab a few and solder the good ones on DTP Boards
Jensen567
The ones on KD are very nice, worth the extra few bucks for me to know for sure what bin and voltage I have. With the AE ones we have no idea.
Tom E
Tom E's picture
Ohhh - yes, forgot bout those specs. KD's SST-40's are marked as VJ, so should be 2.7V-2.9V, which is pretty low, and explains the high amps we can get from them. Yes, it's certainly something that is nice to know up front what that rating is when we order them from other sources. Fortunately, KD has been pretty good with giving us the details on bin, tints, manu part #'s, etc.
BanL
Hi friends
Another new batch of CREE XHP50.2 is arrived
http://www.kaidomain.com/p/S026568.Cree-XHP50_2-K2-3C-Neutral-White-5000K-LED-Emitter
Thank you
L4M4
L4M4's picture
Me wanting 219C Triple in 5000K Big Smile
giorgoskok
I agree… Nichia 219C 4500k – 5000K 90cri leds would be great Big Smile
djozz
djozz's picture
Last seen: 1 hour 17 min ago
Requests:
The new Lumileds Luxeon V led, in different colour temperatures.
And a new KD DTP ledboard for the Luxeon V (it has a different size footprint).
Jensen567
I second this request
