KD (kaidomain): Deals and new products thread
1609 posts / 0 new
KevinZA1988
KevinZA1988's picture
Last seen: 1 hour 52 min ago
It’s down for me too…
Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
raccoon city
raccoon city's picture
Last seen: 1 hour 23 min ago
KD loads fine for me.
1stein
1stein's picture
Last seen: 1 hour 8 min ago
Hmm…
That would indicate a problem on the line China-EU… But I’m not an IT guy to figure it out properly…
Agro
Agro's picture
Last seen: 2 min 9 sec ago
I’m in Poland now and KD is up for me.
1stein
1stein's picture
Yep, working again.
Last time it was the same: a short warning off, then off for a few days.
Hope it’ll stay alive this time.
Thanks for all your feedback.
Mieciu
Last seen: 4 days 20 hours ago
Any chance of high cri neutral white nichia leds ? (219C 319AT 5000K)
adam7027
Last seen: 7 hours 31 min ago
Hello Ban,
Could you please get some of these LEDs below?
https://download.luminus.com/datasheets/Luminus_SST-10-DR_Datasheet.pdf
https://download.luminus.com/datasheets/Luminus_SST-10-FR_Datasheet.pdf
(B130 variants, please)
Now, these are the best deep and far red LEDs from Luminus (better than Cree equivalent), and you already have a recent driver for low Vf red LEDs with 1 or 1.4A current, which is a good match for these.
These LEDs also have (as I saw) the same MCPCB solder footprint, as the Osram KW CSLNM1.TG, so you could also sell them pre-soldered, with the recent 3030 MCPCBs already available.
1stein
1stein's picture
How about a poll? “most welcome new led @KD”
jasontheguitarist
Last seen: 11 hours 53 min ago
jasontheguitarist
VaKo wrote:
So how does one get support from KD about problems?
They don’t respond to emails.
I received a bad driver from them. I sent a message through the site and never got a response. Probably not worth the hassle for a $3.50 part.
Barkuti
Barkuti's picture
Last seen: 4 hours 12 min ago
User e1000 reported a downgrade for the H1-A driver, Nightsword confirmed it. What will happen now on high with modified drivers? Bad, very bad.
I see the H1-A is now “on sale” (can't use coupon then), with an old photograph it doesn't abides by. Most users here prefer quality over cut corners. Cut corners may end up costing us money.
Barkuti
Barkuti's picture
Incorrect way of believing. Every bit of your money is worth it. If you don't care, parasites will leech you to @#$%.
VaKo
Last seen: 1 day 21 hours ago
Or buy via Aliexpress who have their own policies. You pay a bit more but in the event something goes wrong you have an escalation pathway.
lumenzilla
lumenzilla's picture
Last seen: 1 day 22 hours ago
Barkuti wrote:
Incorrect way of believing. Every bit of your money is worth it. If you don’t care, parasites will leech you to @#$%.
Thumbs Up
Lexel
Lexel's picture
Last seen: 8 hours 6 min ago
http://kaidomain.com/Osram-KW-CSLPM1-TG-White-5400K-LED-Emitter?search=osram%20kw
5400K 2mm² white flat?
djozz
djozz's picture
Last seen: 8 hours 18 min ago
I did not notice that before. KD claims the fcbB46 bin of the PM1 which is indeed the warmest Chromaticity Coordinate Group that is in the datasheet.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 11 hours 23 min ago
Which Color is sold by neven? I have some of these emitters but they are way too cold.
https://led4power.com/product/osram-kw-cslpm1-tg-2mm2-throw-king-bare/
Is it right that KD sells 2C and Neven 1D, translated to the Cree Color Shema?
SKV89
Last seen: 5 min 28 sec ago
The fcbB46 is the warmest bin ranging from 5300K to 5800K but the duv is also above the BBL unfortunately according to the chromacity coordinates for this bin in the data sheet.
You can plug in the 4 corners of the tint quadrant into this link to see the CCT range for this bin.
https://www.waveformlighting.com/tech/calculate-color-temperature-cct-fr...
You can plug in the 4 corners of the tint quadrant into this link to see the duv range
https://www.waveformlighting.com/tech/calculate-duv-from-cie-1931-xy-coo...
It could still be below the BBL as we all know the actual emitter and bin labeling can be quite off sometimes.
contactcr
Last seen: 2 hours 20 min ago
When overdriven these things are never near the binned chromacity
Agro
Agro's picture
Voltage and flux bins are the same as that from L4P.
contactcr
LEFT: FW3A MCPCB + 10511
RIGHT: Kaidomain Quad Optic and MCPCB
I’m no expert but I don’t think this is right. It seems this optic sits too far down into the MCPCB since either the optic legs don’t have a big enough “shelf” and/or the MCPCB holes are slightly too big.
Sitting on the flat granite I can slightly rock the optic back and forth by the two optic legs but just barely. It’s basically just a thin sheet of paper shy of straight up resting on the MCPCB. In two of the MCPCB holes there is almost no rotational play so it probably wont shear a dome but I feel like it has a decent chance of crushing the substrate or not being in the correct focus?
MCPCB is 1.6mm high (listed as 1.5mm) so that probably doesn’t help either
VaKo
Had the exact same problem, the optic rests on the dome meaning that the optic cuts into the domes when it’s installed with any pressure on the optic. Lost 4x XP-L HI’s finding this out.
contactcr
RIP, sorry for your loss. I probably would have done the same if I wasn’t trying to dry fit it inside a FW3A to see how close it is.
I feel like I frequently pay the early adopter tax when it comes to this hobby :\
lumenzilla
I damaged a LED from the triple because of the presure too Facepalm
VaKo
The triples don’t seem bad, but then I use the Carclo optics with those.
The KD quad optic simply has a design flaw or isn’t suitable for use in flashlights.
contactcr
I hope KD will acknowledge this and address it.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 min 23 sec ago
I have built a few triples with Kaidomain optics and i always shave the legs so the optics sits flat on the MCPCB? The triples are deep enough to fit over the whole LED?
If you already have the optics over the dome and its done no damage there should be no problem? you can only apply a very limited amount of pressure more once tighten.
I tried the Kaidomain optics at the stock height looks similiar to your left pic and the beam is wrong its all wonky.
VaKo
On the domed LED’s its still resting on the LED itself and the pressure will cut into the domes around the bulge. On the XP-L HI’s it just sliced the phosphor off the package.
Weird maybe the quad is a different optic to the triple, Hopefully Ban can fix this problem.
contactcr
Lets not clutter up the issue with triples. It’s a different beast and he has already revised his triple boards at least once.
In any case, the optic will fit around the dome fine but not around the entire substrate.
