If you have interest , you can use coupon code—STR01VTZLV86T to get the discount.
When you use coupon, please click “add to cart ” button to proceed. Do not click “BUY NOW” button.
Specifications:
◎ Cree XHP 50 CW 6500K / NW 4200K
◎Battery: 2 x 26650 / 18650(Not Included) ; With Extension body
◎160 mm (length) x 66 mm(Head diameter) x32 mm(Body diameter)
◎370-gram weight (excluding batteries)
◎3 levels of brightness: High (3A —2.5 hrs)>Med (15hrs)>Low; Current Regulation
◎Capable of standing up securely on a flat surface to serve as a candle
◎Tail cap click Switch
◎Made of durable aircraft-grade aluminum
◎ Super deep Aluminum Alloy Reflector;Shotrange up to 800meters
◎Premium Type III hard-anodized anti-abrasive finish
◎Toughened ultra-clear glass lens
Beam Shot
PS: All new registered member in new website will get one coupon bount to the user ID.
Hi Ric, looking forward to this upcoming BTU light: http://www.edc-light.com/upcoming-project-btu-cree-xhp70-5000-lumens-120mm-reflector-super-thrower_p0907.html
Just a question: are you guys considering a version with a battery carrier extension, so it is possible to do 4x18650 + 4x18650?
Ric, that extension tube would be very useful and I think you would sell many to those who already own the BTU Shocker.
I created a survey that gained a lot of interest but you never supported us. Why not? Can you please make this happen for us and start making the extension tubes and 6 x 18650 carrier?
