Update Oct 3: PD68 TripleDown/TripleStack - Tri-Channel Driver
222 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 7 hours 3 min ago
Thanks tk .
I will probably need your help in modifying the code , or some tips , but i will ask when i have the drivers ready…
finges
Last seen: 1 day 3 hours ago
pilotdog68 wrote:
e-switch and dual-switch firmware adaptations are in the works (possible already done, I just have been to busy to properly test them).
Any news about this?
I would like to use this driver in a dual switch light (modified Courui D01)! Control the modes with the e-switch and on off via rear switch with mode memory.
pyro1son
pyro1son's picture
Last seen: 7 months 1 week ago
Not tested just quickly put together during lunch break.
http://pastebin.com/f11HDPZw
Feel free to give it a go
Mk2 Version here
Not sure which will work best.
Pastebin                                      &nbs
pilotdog68
pilotdog68's picture
Last seen: 1 month 4 weeks ago
“fixed it” also posted some code a couple pages ago that I still haven’t gotten around to testing.
Flashlights have been on the back burner for awhile now
finges
Thanks pyro1son, I’ll give it a try.
I see that #define ALT_MODES is commented out, do I need to remove the comment?
For example, if I would like to have 5 modes I would write the following?
#define MODES 1,90,255,255,255
#define ALT_MODES 0,0,0,255,0
So I would get moon, low, single 7135 on full, single + secondary 7135s on full, FET ?
edit: mmh I think with this config I would get the Turbo mode in mode 3 already. So it would be good if I could write
#define MODES 1,90,255,255,TURBO
pyro1son
pyro1son's picture
use ALT_MODES for the single 7135
MODES for the larger bank
put 254 in MODES for the FET turbo and 0 in the ALT_MODES
I’ve commented in ALT_MODES
Pastebin                                      &nbs
LightRider
LightRider's picture
Last seen: 5 months 1 day ago
Mk2 Version here
Nice clean looking code! Thanks!
finges
Ok, so I built a board and tested it with a working rear clicky firmware. All fine and working Smile
Then I uploaded the new dual switch firmware and soldered a small cable to the outer ring.
I connected it to a battery and it starts in direct drive (=the highest mode).
If I touch the otc pad (=pin 2) with the small cable it should change modes right?
Anyway, nothing happens. I tried a few other pins on the attiny, but only the fet pin (=pin 3) did lower the output and as soon as I removed the small cable it was at direct drive again.
I tried both firmware versions and also tried it with and without the otc cap, because this is not needed in a dual switch light right? But no difference, I can’t get it to switch modes.
Here is a pictures of the driver, sorry it is a little bit dirty looking now.
pyro1son
pyro1son's picture
Which code did you use?
Pastebin                                      &nbs
finges
I tried both, just changed the modes to
#define MODES 0,0,0,255,254
#define ALT_MODES 1,90,255,255,0
#define MODE_PWM PHASE,FAST,PHASE,PHASE,PHASE
Mk2 Version here
pyro1son
pyro1son's picture
Just make a fix in Mk2 there was a slight issue with some of the brackets. Try now.
I will try and get some time to test this myself but wont be for a while
Pastebin                                      &nbs
finges
Thanks, I’ll try the updated Mk2 version.
finges
Ok tried it and still the same problem, the driver does not switch modes.
I also tried changing the switch_pin and fet_pin, because the switch is connected to pin 2 and the fet to pin 3 right?
#define SWITCH_PIN PB2
#define FET_PIN PB3
But also no luck with that …
pyro1son
pyro1son's picture
Hmmmmmm,
I’ve tried something more like the current clicky switch FW HERE
Can you make sure that TK’s Ferrero_Rocher works on your driver first.
Pastebin                                      &nbs
finges
Ok I tried your new version but still the same, it starts in direct drive and won’t change modes.
I then downloaded the ferrero rocher hex file and flashed this and it also behaves strange.
If I connect it to the battery the led flashed one time very short and then it is dark again.
If I connect ground to pin 2 it cycles through the modes staring high to low.
If I connect ground to pin 2 for a short time it is at direct dirve and stays there.
Strange maybe I did something wrong with the driver.
The only firmware that I get to work properly is the one in the op for a rear clicky light.
pyro1son
pyro1son's picture
Hmmm sound like there is something else wrong
Pastebin                                      &nbs
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 32 min ago
FWIW, Ferrero Rocher is supposed to blink once and shut off when power is connected. Short and long presses should go through the modes in opposite directions. However, it also tries to use two pins for battery indicator LEDs, and that could be messing with the behavior.
I suspect that what happens is a short or long press cycles normally until you let go, then it tries to indicate battery status by turning on one or two pins. This causes the light to turn on another power channel at 100%, and it drowns out any mode changes you do afterward.
If you disable the battery indicator code, it’ll probably behave a bit better. But this at least suggests that the e-switch pin is physically working.
pyro1son
pyro1son's picture
Been looking into it a bit more.
Mk4
Pastebin                                      &nbs
finges
nope sorry, tried it still no mode switching Sad
Izombie
Last seen: 1 year 6 months ago
Sorry for the basic question,
Is there a driver that has a PWM above 8 kilohertz? I would like to shoot video with flashlights, but the pwm flicker isn’t good. Thanks.
LightRider
ToyKeeper
ToyKeeper's picture
Nearly every firmware in the repository has PWM above 8 kHz. Click the link in my signature for more information.
finges
Thanks to HarleyQuins SRK driver I now have a working e-switch firmware for this driver
https://github.com/HarleyQuin/Flashlight-Firmware/blob/master/STAR_momen...
LightRider
I have the 20mm Rev2z board. If I am using a single cell, do I need to populate the zener pad?
LightRider
Anyone know? I didn’t think it needed the zener if using with one cell. But I see that the new blf fet+1 includes a zener even when used with one cell. So IDK?
LightRider
Never mind. I determined I don’t need it.
LightRider
Well I build my first driver for good or for worst… Now I’m trying to sort through bistro triple down so I can flash it to this driver. This is the version optimized for two less, but I’m going to use all three channels on one xpl hi.
pilotdog68
I know it’s late but none of my driver boards should need the Zener for single-cell.
I hope it works out for you!
LightRider
Pilotdog68, under the 7135 on the top of the board is the trace that can be cut to separate the 7135s on the back from the fet on the front. The trace is small, would that small trace carry the current ok? It’s probably common, but I never thought about how much current goes through these traces til now.
LightRider
Ahh man… This is hard! I have so many questions Sick
I just realized I need to change the pin layout in tks bistro tripledown firmware. The layouts between board versions are a bit different. Do I just start changing pin labels in the attiny.h file?
