ENEDED
151 posts / 0 new
Tom E
Tom E's picture
Last seen: 9 hours 11 min ago
GearBest? Tell us how a flashlight works? laughing
Sorry, it's the other way around...
freeme
freeme's picture
Last seen: 2 min 54 sec ago
I am also using OTR 16340 with M3. I did a quick comparison just now, both OTR 16340 and my trusty Olight 16340 are almost identical in length. It might not  be the battery length issue. Could you bypass the tailcap with a wire, and see if the the light is working?
eeagle wrote:
At: @EyeballFryer, @daninho, @hank, @Liber8 Thanks for the replies and ideas. I am using the yellow button top OTR battery that came w/the full pack. I can't imagine the spring being deformed enough upon tightening to open the circuit, or the OTR battery they provide to be too long or too short to function, but maybe that is what is happening. Strangely when the tail cap is tightened all the way it consistently disables the M3. I did open a trouble ticket w/GearBest, and so far they simply have said to charge the battery for 6 hours and report back. I have never had to deal with GearBest CS, my previous purchases have all worked and been delivered just fine. Maybe they will clarify how this light is actually suppose to work if they frequent this forum.
©freemex1thedeals.com
eeagle
eeagle's picture
Last seen: 2 years 5 days ago
eeagle wrote:
At: EyeballFryer, daninho, hank, Liber8 Thanks for the replies and ideas. I am using the yellow button top OTR battery that came w/the full pack. I can’t imagine the spring being deformed enough upon tightening to open the circuit, or the OTR battery they provide to be too long or too short to function, but maybe that is what is happening. Strangely when the tail cap is tightened all the way it consistently disables the M3. I did open a trouble ticket w/GearBest, and so far they simply have said to charge the battery for 6 hours and report back. I have never had to deal with GearBest CS, my previous purchases have all worked and been delivered just fine. Maybe they will clarify how this light is actually suppose to work if they frequent this forum.
I took the tail cap off and bent a paper clip to simulate the end cap connection and the light works correctly.
I did notice I the battery had a bit of spring like forward motion against the module, so while shorting with the paper clip I pressed the battery to simulate tightening the end cap and the light went off and of course would not come back on until I let me finger pressure off.
If that is correct it would mean it is operating like the ad says. ie “If flashlight will not be used for a long time tighten the screw”. So they either now have a pressure sensitive switch in the module…..or I have a bad module connection that acts like a pressure switch?? From the responses I have seen in this forum I suspect it is a bad/loose connection in the module.
EyeballFryer
Last seen: 6 days 23 hours ago
I think that’s a mistranslation. I’ve never heard of a flashlight where you TIGHTEN the tail cap to lock out the flashlight and disable the standby drain.
RobertB
RobertB's picture
Last seen: 8 hours 5 min ago
The battery included is a protected 16340 according to the website. I wonder if you have a problem with the protection circuit on the battery itself. Go buy a CR123 or a non-protected 16340, and see if you have the same problem.
eeagle
eeagle's picture
Good point, we think alike.
I put a brand new CR123 battery in the light during my initial trouble shooting with the same outcome when the tail cap was tightened. I would think the protection circuit in the battery would make a better connection w/pressure rather than open, but then I have never taken one apart.
@EyeballFryer Agree, I have never seen a light that you TIGHTEN the tail cap to lock out the flashlight and disable the standby drain.
RobertB
RobertB's picture
My thought was that since the protection circuit is in the bottom of battery, that adding pressure at that point may have been the problem, but guess not. Sucks.
Hope you get it straightened out with GBst. Getting nice discounts sure is nice, but when something goes wrong, dealing with these companies can sometimes test your patience
daninho
daninho's picture
Last seen: 2 years 1 month ago
I dont have that light, i won it some days ago in a gearbest give away. Have you tried a different 16340 ? I only have the 18650 version of that light and sadly none of my protected 18650 will fit, only unprotected ones. Even one of the shortest, the eagtac 3400.
If the light works with a paperclip i dont know what the problem could be. I guess you have to make a little youtube video for gearbest, dont worry, they have a decent service. They always offered me fair solutions.
Can you make pictures of the tailcap and inside, maybe the experts can see the fault.
eeagle
eeagle's picture
Thanks for all the ideas and insight everyone.
GearBest CS does answer, takes about 24 hrs for a response.
In my case they offered $5 store credit and 15 reward points (50 points=$1) which I accepted….easier than pursuing a return and replace, and it is super bright in turbo mode (w/tail cap unscrewed). I was hoping they would just send out another light.
If you get a properly working M3 as most here have, it is a true bargain compared to the Olight look alike.
BEARS ARE PEOPLE TOO
BEARS ARE PEOPLE TOO's picture
Last seen: 10 months 1 week ago
Anymore deals for this light?
B E A R S
freeme
freeme's picture
It's $19.99 now. Not too far from previous group buy price.
http://www.gearbest.com/led-flashlights/pp_366735.html
andygold
Last seen: 2 years 6 months ago
The Jinx wrote:
A couple of question for those who bought the "kit" M3 1) Is the included 16340 battery an IMR battery? 2) Have you noticed any difference in brightness output between the included 16340 and other brands? 3) What batteries did you use and which brands do you recommend? TIA Jinx
The above was never answered.  From what I understand, the included battery is not an IMR.
 I placed my order for the M3 1A last evening.  I have little to no experience with LiIon batteries, so I'd like to also know the answers.  Since the M3 itself has all the built-in protections, would there be any benefits to using an unprotected IMR in it?  Would an IMR give any extra brightness?  Would an ICR be better for this light, and give longer runtime per charge?
Lummi Wee, Lummi Raw, Tank007 E09, On The Road M3, Nitecore Tube, Cube Light, various AAA COB lights, Eternalight,
daninho
daninho's picture
The included 16340 was similar in output to the Klarus 16340. Surprisingly the light was much dimmer with a Fenix 16340.
I measured the M3 with 725lumens in a DIY sphere, so it is a very bright 16340 flashlight. I guess only the nitecore EC11 with the IMR cell is brighter
strongest2004
strongest2004's picture
Last seen: 3 weeks 1 day ago
Got my M3 earlier together some other lights.
I am really surprised how small it is. This will definitely bump off my Convoy S2+ with 18350 tubes as my current main EDC light.
For reference, my protected Trustfire Flames “almost” fit. I hope the Windyfire IMRs I ordered will also fit.
Update:
Got my Windyfire IMRs. They are the same dimensions as the yellow OTR battery and fit perfectly. Will put the flames on backup duty.
Low mode and long runtime lover…
Deputydave
Deputydave's picture
This thread is 6 months old. I wanted to bring it back up to see if anyone that has the M3 has good/bad opinions on it now that they’ve been using it for a while. I just ordered a Utorch UT01 but also have had my eye on the OTR M3.
How’s it working out for you?
Survival & Emergency Preparedness http://sepboard.us
Lowtech
Last seen: 5 months 4 weeks ago
Abit worn finish and thinking of changing the led othervise it works great.
Pete7874
Pete7874's picture
Last seen: 8 hours 14 min ago
Looks like the 5C version is no longer offered in a package with a battery… or at least I’m not seeing it.
If that’s the case, what 16340 battery would you guys recommend for this light?
Thanks!
Tom E
Tom E's picture
I like the IMREN here, but my M3 is modded for high performance and these cells work pretty well. EFEST's are also good,
Pete7874
Pete7874's picture
Thanks, Tom.
Yeah, I saw the EFEST ones on imrbatteries.com as well, but the button-tops are out of stock, and I’m not sure if the flat-tops would work with this light.
Tom E
Tom E's picture
Pete7874 wrote:
Thanks, Tom. Yeah, I saw the EFEST ones on imrbatteries.com as well, but the button-tops are out of stock, and I'm not sure if the flat-tops would work with this light.
Oops, I also have and use the IMREN flat tops in the M3, so any flat tops should work ok.
Pete7874
Pete7874's picture
Good to know. Thanks.
I just ordered the OTR M3 with 5C tint. I was going back and forth between 1A and 5C… I guess I will be losing a bit of output with 5C, but I’ve seen people speak highly of this 5C tint on the M3, so I thought I’d give it a try. I’m hoping I can just attach it to my baseball cap and use as a walking light.
Pete7874
Pete7874's picture
Tom E wrote:
I like the IMREN here, but my M3 is modded for high performance and these cells work pretty well. EFEST’s are also good,
So… IMREN vs EFEST… is one generally considered better than the other, or should I toss a coin?
Tom E
Tom E's picture
I suspect they are the same cell under the label, but not sure. Dunno - the IMREN's do better than my EFEST's but the EFEST's are older, so hard to say.
The 850 mAh capacity protected EFEST may do well in the stock light, but not sure if it fits.
vince
Last seen: 7 months 4 weeks ago
I like this flashlight a lot - it's perfect as a travel light. The low voltage indicator is a really nice touch too. But it's well made, and I like that you can pull it apart fairly easily.
The only negatives (for me) are:
  • I'm skeptical about the 900lm claim, but it's fine, it's still plenty bright
  • The UI
    • I really don't like the long press to switch it on. I much prefer the Olight UI. A long press for on is counter-intuitive, and annoying (for me)
    • I wish there was a way to go straight to moonlight/ultra-low from off (again the Olight can do this), or if I could turn off mode memory, and always start from ultralow?
    • It would be great if they copied the Olight's timer feature
Otherwise, I love this light - it's very practical. If OTR does an upgraded version, I'll certainly look at it.
ooi - has anyone swapped out the driver in their M3 yet?
letorih
Last seen: 1 year 11 months ago
This cree flashlight look like same as Olight S1. According to your comparison Olight S1 flashlight is more powerful than M3. S1 is one of the best edc flashlights. totalguide and comparison review is here. Then why buy that M3 flashlight?
maildroid
Last seen: 5 days 19 hours ago
How long did it take for you to get it ?
"Let your lite shine "
korpzgrinda
korpzgrinda's picture
Last seen: 7 hours 25 min ago
Location: Eastern Woodlands in the Wilderness of North America
Because the M3 costs 20 USD and the S1 costs 40 USD. Remember, this is BUDGET light forum.
letorih
Ya get it. S1 price almost double than M3.
myblog
Paul321
Paul321's picture
Last seen: 11 hours 6 min ago
A 5C tint is available as well, Olight is cool white FWIW
Paul-
Tom Tom
Last seen: 6 months 4 weeks ago
I have had one for 15 months, full kit, 5C
I cannot fault it.
Uses very-slightly long press for on and off, then cycle through modes. Last mode memory. Triple press for useless blinkies. Very low, low, med high. Simples.
Never tried anything but the included cell (excellent). Never tried the included charger.
Also have Olight S15. Different UI, very low “moon” but it is not obvious how to enter it, otherwise just low-med-high, much worse tint, blinkies, if used, can switch back to original setting with a long press.
Mode changes take long press. Also has last mode memory. I get it, most don’t.
M3 very-low is perfect.
S15 has slightly involved procedure for lockout, M3 doesn’t at least not one I’ve found, but tailcap twist does that.
Simple test: hand M3 to novice user, they all get it, straight away. Not so with Olight.
Quality appears identical, Anodisation equal although different colour.
Still EDC S15 because of AA cells. Favourite by far is M3. So small. So easy. Just right.
Both have negligible parasitic drain when off. Almost unmeasurable.
