I finally did one with a display in it! I haven’t been very active on here for a while, but I just finished one of my best mods ever and had to share it. My video below goes over the basic info and I’d be happy to answer questions if anyone wants more detail.
This is a Lumintop SDmini that I updated to MELD firmware with RGBWUV. While doing that, I noticed that the charge port opening perfectly fit a tiny 32x64 OLED display, so I had to put one in there! I added temperature monitoring on the LED board, voltage measurement for the battery, and an independent current monitor for the white LED. I ported my firmware to a much more capable microcontroller and added in display functions to show mode/menu info, drive level, strobe speed, LED temperature, LED drive current, and battery voltage. I consider the display aspect of the firmware a work in progress, but luckily I was able to repurpose some through holes on the driver PCB as programming connections so I can continue to work on it.
Wowser. Crazy skills, this man has. How the heck did you keep the those thin red wires straight? Sure that was easy compared to the programming skills though.
