I’ve been reading quite a few reviews lately and it’s plain to me that many us if not most really don’t understand what the term “Tactical Light” means.
For ME, first and foremost it must be easy to operate under stressful conditions. It needs to work every time without thought as to which “mode” I’m in. If things go really bad and maybe you’re running for your life and you need your light, you probably won’t be able to cycle through modes very well, also you could be making yourself a target if you have to stop and are fumbling through firefly-low-medium-high-turbo-strobe. I’m never going to remember what mode I was in last.
Next, I like a strike bezel. (I guess we could argue as to how aggressive it needs to be) If I need to strike, I may not have time to go for a weapon, I may need to use what ever I have in my hand at the time.
Finally, I like the light to work well with a firearm whether mounted or not mounted. If it’s mounted, the switch needs to be in the right spot (something like a pressure switch works well for some firearms such as rifles and shot guns, but, not so much for handguns).
I’d love to read some of your thoughts. Especially some of you who write the reviews of these so called “Tactical” Lights.
I would say my Thorfire VG10 is the ideal tactical light. robust, good weight. Can flash other firmware or put another driver into it as well if required. (any modes I like then).
What I see as tactical is a sturdy and bright forward clicky torch that doesn’t change modes by turning on and off. Pressure switches and cigar grip rings are optional.
This NiteFox UT20 I just got seems to have a real nice tac mode. Turn the light on, hold the side switch for three seconds, it flashes twice, then you are in tactical mode.
When the light is in tac mode, it’s tail switch only with memory. It has momentary, and you can also do a full click straight to turbo. Modes in both momentary and clicky are high, strobe, low, in that order.
Turn the light on, hold the side button down for another 3 seconds, and you go back to normal 4 mode side button mode.
Doesn’t have a strike bezel or pressure switch, but I’d have a dedicated light for a rifle anyway.
Even if I don’t use it much in “tactical” mode, this is a nice light, both in construction and working!
I would just add that if you (OP) want to change the mode while using the “momentary ON”, you can also click the side switch (+ the half press on tail switch) and it changes the modes in the order mentioned above (H-Str-L)! You can then full press the tail switch to “lock” the mode you want to use continuously!
I always mentally substitute the word “tactical” with “tacticool” whenever I read a supposedly “tactical” light is using Eletronic Switch and/or reverse clicky.
I think one feature of a real “tactical” (military use) flashlight is the ability to use the forward-click momentary-on to flash signals, like Morse code. In that case, there can only be 1 mode, or at least locked into 1 mode, without accidentally changing levels because of the continuous button pressing. I guess mode selection options can help with that, as long as one of them is 100% only or 50% only.
But yeah, for the most part these days, “tactical” is just a buzzword for selling to the mall ninjas out there. And to a lesser degree, it also has something to do with the militarization of society.
While I don’t personally use tactical lights to their fullest potential, I presume there are military or LEO’s that can comment here, and the features we casually discuss are probably very important to those in situations where someone is actually shooting at you. … . just a guess.
Very true, what I hope is that light manufacturers like Olight and others will stop with the silliness and keep making lights like the M1X. I like the extra brightness of the new lights, but not enough to trade my M18 for the M2R.
That’s not to say I don’t use other lights, I do. I love some of the bells and whistles, for example, the ramping on my Emisar D4.
You can set the light for Outdoor (ML-L-M-H) or for “Tactical” (H-Str-L).
If you want to set it in Tactical mode, when the light is ON on the Outdoor setting, click for +3 seconds on the side click to get it into the Tactical mode.
Then, on Tactical, the light always starts with High mode (either through momentary ON, by half press, or by full click to use it continuously).
If you make half presses while on Momentary ON, the light will change from High > Strobe > Low > H > Str > L…. .
If you are in High (after full click) and you want Strobe, make a full press + fast half or full press from there and the light gets into Strobe.
If you are in High (after full click) and you want Low, make a full press + 2 fast half presses from there and the light gets into Low (that you can use continuously after full click).
If you are in High and need to turn the flashlight OFF and then need it to get in High again, switch it OFF and after 1 second it will switch ON in High again. If during that 1 second you’ve made a full or half press the light will change the modes to Strobe or Low.
The Tactical setting doesn’t have memory, the Outdoor setting has.
If you need a light to always start on High, a Convoy light with biscotti on modes 6 (100–20–1), 11 (100–20-Strobe) or 12 (100), no memory set can do the trick! No striking bezel, though
I like the old school format of surefire for tactical
modes are on and off only
tail cap is “only” momentary. Twist fully to turn on.
I really liked the format surefire offers but sadly no lights ever used such methods for their tailcap.
And surefire is overpriced in my country. I could buy a phone with it
No no no, it at least tells you it will be black and will have wet product shots, ideally in the rain. Oh and the pictures also tell you that you need tactical gloves to hold it. That has to count for something, right?
