(prototype) the GT Mini
1637 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 7 hours 54 min ago
Teacher, fwiw… that 789D fully loaded weighs some 715,000 lbs. Wink The tires are 12’ tall and weigh 6640 lbs EACH, there’s 6 of em at a cost of near $50,000 each to replace!
teacher
teacher's picture
DB Custom wrote:
Give it a Cat scan…
Shocked . Shocked . Shocked . Shocked . Shocked .. Now ‘THAT is a TRUCK’!! A very expensive truck. Wink
Good info Dale.
I wish I owned a couple of those & could have them working 24 × 7 × 365…. that would mean a lot more $$$$$.$$ for lights, guns, fishing toys, & trips to exotic places to use them all. Cool Beer Wink
lexvegas
Last seen: 1 month 1 week ago
Hey DB Custom, did you get Anduril on your GT Mini? What light’s program did you use?
DB Custom
DB Custom's picture
I think I used the newest D1S Anduril, from July or something. Will have to look it up…
Pulstar
Pulstar's picture
Hey guys, what would be the best protected cell that actually fit in GT mini?
Brainsick67
Brainsick67's picture
Last seen: 2 months 23 hours ago
Maybe the Keeppower 3120mAh..
https://www.illumn.com/batteries-chargers-and-powerpax-carriers/batterie...
But most will run unprotected.
I'm ThatCrazyFlashaholic 67
Newlumen
Newlumen's picture
Last seen: 1 week 4 days ago
Yes. Keeppower 3120 mah will fit in the mini gt.
Brainsick67
Thats why i said it, you dnt need to say it again..OK..just messing..i got them also..great cells…
DB Custom
DB Custom's picture
A protected cell won’t run the GT mini the way it’s intended to be run though, best results come from a non-protected high discharge cell. The driver has built-in protections so everything is still safe and secure.
eas
eas's picture
Sure, a protected cell will limit performance, but The GT-mini is an XP-L HI light that was originally specced with a ~4.5A regulated buck driver. The impact is going to be less significant/obvious than it would be with a triple, or something with a low Vf emitter.
It looks like the difference between the protected and unprotected versions of that cell are ~10mOhm. That’ll be, what, maybe 10-15% of output? It may be unacceptable when hot-rodding, but hard to notice in practice.
RobertB
RobertB's picture
Last seen: 13 hours 19 min ago
DB Custom wrote:
Give it a Cat scan…
Accidentally drove into an open pit mine, in the middle of the night, in Wyoming. Suddenly found ourselves surrounded by these things.
I think it was the North Antelope Rochelle mine just south of Gillette Wyoming.
DB Custom
DB Custom's picture
I bet that was a mind-blowing experience Robert!
(Keeping in mind that the tires are 12’ tall, a pickup truck comes about to the axle and is completely dwarfed! The pickup is about 6’ wide, this monster is 25’ wide! The pickup weighs what, 4,000 lbs? Loaded with rock the big hauler weighs an impressive 715,000 pounds! [215,000 lbs of truck, 500,000 lbs of rock] The tires are 6,640 pounds of rubber, not mounted to their 57” steel wheel!)
PS: A 4 year old used one, which has probably been running and hauling rock 24/7/365, cost’s around $3,000,000 dollars. And it will take $2,000,000 a year at pump prices just to fuel it with diesel! The 1,000 gallon tank lasts 12 hours, two tanks of fuel a day!
DB Custom
DB Custom's picture
Illumn’s site states that the Keeppower 3120mAh protected cell is utilizing a Sony VTC6 inside, with a maximum continuous discharge rate of 15A. This cell should run the GT mini’s XP-L HI just fine. MOST protected cells can’t.
When you can get a Samsung 30Q for around $5, paying $12 for a protected cell in a light that has internal protection built in seems kind of wasteful.
RobertB
RobertB's picture
Haha, it was. Oil field work before GPS and cell phones. Most of the gravel roads weren’t on any maps. All we had were someone’s directions to a well that we had to work on. We got lost, “hey there are some vehicles over there, lets go ask them”… The headlights on those trucks are mounted quite low, so you don’t realize how big they are until you drive up next to one. Of course they were moving so we were trying not to end up like this.
DB Custom
DB Custom's picture
Lord have mercy! (but that IS what I was thinking when I suggested the CAT scan. lol )
The driver sits about 15’ in the air, on the far side of a 25’ wide vehicle. He can’t see much of anything on the right hand side, like that pickup that put himself in a bad place. Nowadays they have 360º camera’s with monitors in the truck, but still….
BlueSwordM
BlueSwordM's picture
Last seen: 18 hours 39 min ago
BTW, guys, with the 35$US sale price(45$CA), I finally plunged on the purchase of the BLF GT Mini.
When it comes, what kind of mods should I do? I’m personally going to replace the tail cap springs with my own BeCu springs.
How easy is flashing the driver? Is it glued?
DB Custom
DB Custom's picture
Blue, change to your springs and be done with it. The light is really already a hot rod right out of the box. They glue the bezel so it can be a damaging experience getting in to change the emitter…
BlueSwordM
Really? Wow that is impressive. Do you think Anduril would be better on this light or should I keep NarsilM on it?
Cereal_killer
Cereal_killer's picture
Last seen: 3 weeks 4 days ago
Is there a dead guy still in the [crushed] white truck?!
BlueSwordM
Looks like it. Really sad for the guy inside.
shirnask
shirnask's picture
Last seen: 4 hours 13 min ago
There was so little glue on my bezel that is was easy off with just a towel
DB Custom
DB Custom's picture
My bezel was so tight I had to mount it in my 5” chuck on the lathe and use 16” adjustable pliers. Had aluminum between the jaws and the bezel but it took so much force the aluminum marked the bezel.
I really like Anduril, use it as much as possible. I find Narsil confusing, just me but of course I build lights for me so… Narsil is a pretty complete package out of the box, if you can deal with it’s complexity and like it, by all means keep it in play.
I’m hoping the driver of the pickup got out to tell the truck operator something and left his truck in the wrong place. The passenger was just unlucky enough to not realize the big truck was moving and didn’t have time to evacuate!
Delta_V
Last seen: 14 hours 53 min ago
Guess who still hasn’t received their pre-order light…. this guy!!!
Wait, this isn’t a competition for whose shipping takes the longest? Well, crap.
On the plus side, after taking three weeks to go from China to New York, a week to get through customs, and almost a week to go from New York to Queens (seriously…), the package is finally in my county. So hopefully it gets here this time. The worst part was USPS repeatedly giving an estimated ship date, and only once that date had passed, updating it to say lol, nevermind.
Now hopefully the light isn’t in a thousand pieces from being stuck in shipping for so long. To top it off, I’m also waiting on an Armytek order from weeks ago despite paying $15 just for shipping. Yeah, not having great luck here.
teacher
teacher's picture
Facepalm …… Wow Delta_V, you have had a rough go of this for sure. Sad
Hopefully tomorrow!! By the way, what state do you live in??
Delta_V
I’m in Wisconsin. Southern half, so not too far from civilization. Have made multiple orders from China, and never had this many issues.
Although it’s not like a thrower would have seen much use this last month with this constant rain. Just got done with the wettest August I’ve ever seen, and September has just continued the trend.
Newlumen
Newlumen's picture
I hope you will get it tomorrow.. I measured 1286 lumen @ 5 seconds for the CW.. I like this light. Small and compact thrower..
teacher
teacher's picture
Ok, thanks Delta_V. I hope you do get it tomorrow.
This has also been my strangest order from China ever. No rhyme, reason, or continuity to it. I hope to never have a repeat…. Wink
Strange summer & August in Alabama too. Both have been somewhat mild compared to other years & not as dry as a chip either.
mortuus
mortuus's picture
Last seen: 2 hours 26 min ago
Delta_V that sucks.. really long time even for shipping to usa from china seems long, but dont worry the light was packed very good so it shouldnt have any damage unless a truck ran over the package.
...where Frugal meets with Flashlight!
M4D M4X
M4D M4X's picture
Last seen: 3 hours 43 min ago
please send Neal a mail asking him to investigate what happened to your parcel
neal@m4dm4x.com
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
KawiBoy1428
KawiBoy1428's picture
Last seen: 20 min 34 sec ago
Got my GT mini today… GT miniscule measured 1318lm with a 30Q and 1463lm with a VTC5D.
Very Nice…INDEED! Thumbs Up
KB1428 “Live Life WOT
