Sofirn C8F 21700 Teardown and Review
152 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 1 hour 36 min ago
LoL all of this current draw optimization treadmill is pretty crazy. I see the MOSFET used in the new 21700 C8F should provide some extra edge over the 18650 version, but it seems you do not get the expected results because of some “unaccounted” roadblock. At least on paper the newer PSMMN2R0-30YLE MOSFET is better than the AON6418 used in the 18650 C8F, but please note both MOSFETs are outside their optimal RDSon to VGS zone in the graphs, RDSon creeps much higher under ≈3.8V for both according to datasheets. Maybe going back to the AON6418 would “fix” this (= AON6418 “better” in practice)? Or using a MOSFET which actually works well with low VGS values.
I do not really care about flashlight drag racing. To me the actual performance of my flashlights is the one I can always count/rely on nearly irrespective of battery SoC or temperature.
Preheating batteries to attain higher current draw LoL!
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts or at least trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
JasonWW
JasonWW's picture
Last seen: 20 hours 9 min ago
Barkuti wrote:
LoL all of this current draw optimization treadmill is pretty crazy. I see the MOSFET used in the new 21700 C8F should provide some extra edge over the 18650 version, but it seems you do not get the expected results because of some “unaccounted” roadblock. At least on paper the newer PSMMN2R0-30YLE MOSFET is better than the 1.pdf”>AON6418 used in the 18650 C8F, but please note both MOSFETs are outside their optimal RDSon to VGS zone in the graphs, RDSon creeps much higher under ≈3.8V for both according to datasheets. Maybe going back to the AON6418 would “fix” this (= AON6418 “better” in practice)? Or using a MOSFET which actually works well with low VGS values.
Cheers Smile
I wish I understood more about the mosfet specifications, but I barely understand how they work. Lol
I’m not sure why you talk about preheating a battery to get better performance. I don’t think that was mentioned in this thread.
I agree that trying to get maximum amperage is not very practical. It just heats up the head and runs down the battery quicker.
I switched over to using the Sofirn SP33 v2. It’s got a nice regulated output. It doesn’t build up heat very fast and the battery lasts a longer time.
Barkuti
Barkuti's picture
JasonWW wrote:
Lol I'm not sure why you talk about preheating a battery to get better performance. I don't think that was mentioned in this thread.
Yes it's been mentioned by… yourself!
JasonWW wrote:
He may know a few other tricks to boost output as well. Like using warm batteries fresh off the charger. I've heard warming up the batteries gives them some extra oomph. He might replace the lenses with UCP which have lower losses, etc... Dale just gets all the highest output. I can't compete with him. He's the king! Lol
Cheers Party
JasonWW
JasonWW's picture
Barkuti wrote:
JasonWW wrote:
Lol I’m not sure why you talk about preheating a battery to get better performance. I don’t think that was mentioned in this thread.
Yes it’s been mentioned by… yourself!
JasonWW wrote:
He may know a few other tricks to boost output as well. Like using warm batteries fresh off the charger. I’ve heard warming up the batteries gives them some extra oomph. He might replace the lenses with UCP which have lower losses, etc… Dale just gets all the highest output. I can’t compete with him. He’s the king! Lol
Cheers Party
Oh yeah! I forgot. Lol
d_t_a
Last seen: 8 hours 22 min ago
I recently ordered another Sofirn C8F-21700, and noticed that the tailspring is now not factory-bypassed (left), but instead uses a double-spring (right).
I think they now have the same tailspring as the Sofirn C8G (which also uses the double-spring).  (I tested that the C8G and C8F-21700 are interchangeable)
Any idea if which one is better? Which can pass higher current?
I notice that Sofirn's factory bypass wires tends to get detached when using high-drain batteries (at least that's what happened on the Sofirn C8A and Sofirn C8F-18650 when I was testing Turbo mode for a bit longer time, and notice the factory spring-bypass wire on both sides got detached probably due to heat -- and I'm not good at soldering small parts)..
Barkuti
Barkuti's picture
Properly done spring bypasses require wire coiling. Without it, chances for the wire to break are substantially higher. So either do a custom spring bypass, or use the double spring is my advice.
Smile
ZozzV6
ZozzV6's picture
Last seen: 2 days 1 hour ago
As Barkuti said. Properly done wire bypass gives higher current but double springs far more reliable. Even a properly done wire bypass can break over years.
Barkuti
Barkuti's picture
User BlueSwordM can provide some nice high current springs. Check this thread: http://budgetlightforum.com/node/67401.
Party
contactcr
Last seen: 5 hours 10 min ago
I hate putting springs on boards like this. They always seem to fall in that green solder mask area. Not even sure what the purpose of making it like that is
Mantser
Last seen: 9 months 3 weeks ago
Hello everyone, where to buy a reflector “orange peel” for this flashlight? I really need this reflector! Thank you.
JasonWW
JasonWW's picture
I’m not aware such a thing exists.
Hugh Johnson
Hugh Johnson's picture
Last seen: 6 hours 13 min ago
I’m looking at the C8F on the Sofirn site. They’re selling various tints.
I’m wondering if the issues described in this thread have been resolved by Sofirn during 2019. I’m looking at the 4,000k and thought they were only selling cold white when I looked last year. Or if this is a more recent version. I saw them selling prototype LT1’s on the same page, so I don’t think I can rely on this being current stock.
I’d be even more interested in the SP33 that one only comes in cold white and I don’t know how to do emitter swaps.
Skylight
Skylight's picture
Last seen: 2 hours 30 min ago
In ‘The general Sofirn development thread’ Barry from Sofirn wrote that they are now offering hosts and custom leds and tints in their flashlights.
The Sofirn C8F can be ordered with LH351D’s now.
My Youtube channel: Alllightson Reviews
My 7th Old lumens contest build: Matainvoy ML18SBuilt video
My reviews: Sofirn SP31 V2.0Nightwatch NI40 StalkerSofirn C8F 21700Brinyte WT01 ApolloSofirn SD05
My Youtube video-reviews: Brinyte WT01 Apollo, Sofirn SD05
JasonWW
JasonWW's picture
The C8F never really had any issues or problems. They simply gave it too high a Turbo rating. They should not have said it’s 3500 lumen. More realistic would be 2600lm. Some get a bit more output. If they had rated it lower, all would be fine. I kind of prefer this lower power version over my modded high output version. Stock it didn’t get hot so fast and Turbo was more usable. After I did all my mods to increase output to 3100lm it just gets hot too quick.
I never considered this stock 5700K a cool white. It’s more NW. A bit of yellow instead of blue. I like it.
Like Skylight said, you can contact Sofirn at their Aliexpress store and request a different emitter. They will probably be busy with holidays until early Feb, though.
I dont know what other tints they have for 50.2. If it’s the SP33 v3 it’s a 3v led which is very new and limited in tints. If it’s the SP33 v2 (6v), there should be more options.
To do an emitter swap first requires you to unsolder two wires on the led mount called the (mcpcb). If you buy a new mcpcb with the new leds already mounted, you swap the boards and solder the two wires back on. Pretty simple.
Things are a lot more tricky if you can’t buy the LEDs already mounted to the new MCPCB. In this case you have to reflow solder the old LEDs off and the new LEDs on. This is a little more advanced. It requires the use of a hot air station, a hot plate or maybe just a controllable heat source. The process and technique is what is key for a good reflow.
Hugh Johnson
Thanks, Jason.
I have some lights on which I’d like to change the tint and will approach that at some point.
I have lots of lights around 5,000k and I’m trying to migrate to warmer tints, which would be the purpose of this purchase.
Phoneas
Last seen: 3 weeks 2 days ago
My apologies if this was already noted above and I missed it, but does anyone know the diameter and thickness of the lens on the C8F? It would save me a bit of time if someone knows this already. I am looking to put a high quality yellow lens into a C8F – fog and heavy snow at night (star field effect) render my higher lumen LED’s ineffective. I would like to swap out the lens for a yellow lens and see what the result is. Thanks for any info or advice – I am a total novice and am just at step 1 (an idea) of trying to pick my way through any modifications to a light.
Hugh Johnson
My 4,000K C8+ is good for fog. Warm, focused beam.
JasonWW
JasonWW's picture
42mm x 2mm
Phoneas
Thanks for sharing that info – I will definitely take that into consideration. I am looking for something like the old Hella or PIAA fog yellow. My led fog lights on my car cut glare big time in fog and snow – so I thought can I come somewhat close for a flashlight and maintain lumen output? We get some driving snowstorms where I live and taking the dog out at night – it would be great to be able to turn on a light without it feeling like I am looking into my own light on strobe effect. So I thought I would give it a go and report back if it seemed newsworthy. I can’t do all the fancy things most of you do – but I could make one small contribution to the collective good – and report the result good, bad or otherwise.
Phoneas
JasonWW wrote:
42mm x 2mm
Thanks for sharing the specs! This is a huge help on my quest!! We shall see if it turns out to be worthy of a minute of my time – you don’t know until you try. Smile
Skylight
Skylight's picture
Once I tried to paint a glass lens with yellow felt pen. If you have a totally yellow lens the light is yellow as well. Half yellow, half transparent is not bad. However, it does not even get close to a real warm white emitter.
The C8F can be purchased on sofirnlight.com with 3000K XP-L or 2700K LH351D.
2700K or 3000K SST20 should be nice as well like in the Fireflies ROT66, E07 or Emisar D4S, D18.
Funtastic
Funtastic's picture
Last seen: 12 hours 48 min ago
I recently purchased 8pcs C8F and it’s been improved big time
Using the 40T and Blue’s spring installed
Turn On – 3500
30 sec – 3270
Brand New C8F from 4 months back with the same as above
30 sec – 2700
Edit:
Bypassed tail spring
Turn On – 3850
30 Sec – 3570
Now that’s more like it!
Texas Ace Lumen Tube calibrated with maukka lights
JasonWW
JasonWW's picture
Turn On – 3500
30 sec – 3270
30 sec – 2700
Edit:
Turn On – 3850
30 Sec – 3570
What about stock, with no alterations? Are you seeing a bump in output?
Funtastic
Funtastic's picture
Turn On – 3500
30 sec – 3270
30 sec – 2700
Edit:
Turn On – 3850
30 Sec – 3570
Turn On – 3290
30 sec – 3070
JasonWW
JasonWW's picture
Funtastic wrote:
Turn On – 3500
30 sec – 3270
30 sec – 2700
Edit:
Turn On – 3850
30 Sec – 3570
Turn On – 3290
30 sec – 3070
Okay, I suspect that they improved the driver contact and got the retaining ring to clamp it down tighter.
Funtastic
Funtastic's picture
3370 at 30 sec with the Sofirn 21700
Wanting to add that many have previously said Sofirn were using 40T’s but this isn’t the case. I ran tests on my CBA and the 40T is much much better
08CivicSi
Last seen: 1 week 1 day ago
Turn On – 3500
30 sec – 3270
30 sec – 2700
Edit:
Turn On – 3850
30 Sec – 3570
what do you mean by “blue’s spring”?
Funtastic
Funtastic's picture
Turn On – 3500
30 sec – 3270
30 sec – 2700
Edit:
Turn On – 3850
30 Sec – 3570
BlueSwordM sells his custom high current springs
08CivicSi
ahh, i see. Did your c8f already have the double tail spring before or was it the single spring?
Funtastic
Funtastic's picture
Dual tail stock I think it was the old 18650 c8f that had two single bypassed springs
