Emisar D18 introduction
960 posts / 0 new
contactcr
Last seen: 4 hours 20 min ago
jojosupir wrote:
hopefully hank will do limited edition of d18.Maybe different material for the host or something.
The light is already really dense feeling and certainly not light weight. I can’t imagine who would want any other material.
In fact, I think the 18350 tube should be seriously considered for the weight savings and for the cool “puck” look.
emarkd
emarkd's picture
I would want that. A cu+ti setup like the D4ti run would be awesome and I’d buy it immediately. You’re right though – it would certainly not be lightweight and other folks may not like that, so I may be in the minority here.
contactcr
Avg BLF user >>>>>>>>>> minority >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> o->-< emarkd
jojosupir
Last seen: 4 days 8 hours ago
maybe i should wait for a while for ‘special edition or something’ before i get the normal d18 version.
emarkd
emarkd's picture
LOL LOL Sounds about right. Its fine though, I like it here Big Smile
Well I’m probably the wrong person to comment since apparently I’m all alone waaayyy over here, but this is what I’m doing. I don’t need a D18 so I haven’t bought a D18, because I know that if a special run came out I’d want it and then my “standard” one, which I didn’t need anyway, would just be an unwanted extra. But that isn’t a great solution because I do want a D18 and if that special run never happens, I’ve held out for…nothing?
trailhunter
Last seen: 1 month 1 day ago
Hank will ship out an empty d18 host, make your own special run Smile
ZoomieFan
ZoomieFan's picture
ichoderso wrote:
Thumbs Up
and please with USB-C charging port
Only useful if at least 30 Watts
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
BlueSwordM
BlueSwordM's picture
Last seen: 35 min 45 sec ago
Why?!
30W+ would be charging the cells at around 1C.
That would be very high, cost quite a bit, and have the risk of ultra fast charging 1x or 2x cells.
1x or 2× 30Qs might be fine, but NCR18650GAs will get absolutely demolished.
emarkd
emarkd's picture
Its the host that I want to be “special”, not the guts. Something besides aluminum, preferably. I mean I guess I could order up a standard host, strip the ano and re-anodize it in some funky color, that might be fun. Eh, we’ll see…
BlueSwordM
Why not just clear anodize it then?
If you have a power supply and some dilute sulfuric acid, that is easy as pie.
Or you could go for a zinc look with a dilute solution of sodium hydroxide and zinc oxide.
jojosupir
Copper head,clear alu coating body and ti bezel.My shelf queen.
Relampago
Relampago's picture
Last seen: 1 month 3 days ago
Odd, I find the D18 to be pretty special as is. The craftsmanship alone sets it apart from most manufacturers. I don’t mind alternative materials but the fact you can tint mix makes it pretty custom already.
“Electricity is really just organized lightning”
― George Carlin
DB Custom
DB Custom's picture
Last seen: 2 days 4 hours ago
I line up behind emarkd for the Ti/Cu D18… Big Smile
d_t_a
Last seen: 7 hours 40 min ago
Figgy
Figgy's picture
hey I bet all of you know skylumen so he sells this light with osram white with 6x white 1 and 12 white2 on the outer.. SO here is my question.. could it be possible to program the light to turn off the 12 leds on the outer ring to not flood out too much.. then turn off the center for less throw.. and third mode all the lights for max performance?
contactcr
No, besides white2 is not floody.
Figgy
Figgy's picture
what could be one of the best led options for the d18 for floody or just remove the 12 outer clear lenses and replace with frosted instead
contactcr
Yea if you want some combo beam it’s better to have wider/frosted TIR on some of them. Maybe even just every other outer lens. Up to you
Chatika vas Paus
Last seen: 1 hour 51 min ago
Has anyone tried the 3000k + 4000k mix? What are your feelings about this mix?
Pavlo
Last seen: 2 hours 36 min ago
I did this mix on my M43 but I used Bluesword LEDs that have lower DUV value. The result is amazing at all levels! Highly recommend it.
SKV89
Last seen: 10 hours 22 min ago
I tried it and although it looks much better than the greenish 4000k on its own that Emisar uses, it is still not rosy. I think if Emisar sourced the rosy 2700k that Fireflies was using and a rosier binned 4000k, the mixture could result in a very nice rosy tint.
hcanning
Last seen: 5 days 6 hours ago
Has anyone done any lumen measurements with the D18 yet? Maukka?
In my quasi-calibrated sphere I get 15-18k lumens depending on the cells I use (brand new VTC6 and 30Q or older VTC6) with mine which has 5000k SST-20s.
The VTC6 are clearly more powerful but just wondering if it’s likely this light is putting out slightly more than the claimed 14k.
bexamous
NM found teardown video.. ugh. So teadious to flash. Wish it had pads like D4V2.
dorpmuller
dorpmuller's picture
Last seen: 1 day 5 hours ago
Can't wait to get mine from Skylumen. Black with 219B's!
"I am the flashlight king! I can light anything!"
Gerrit
Last seen: 35 min 2 sec ago
Have ordered a D18 with Osram cslpm1.TG from Hank today.
Watched a video of a Fireflies rot66 gen.2 with Osram cslpm1.TG
and I was impressed, so I emailed Hank if he could do the same with the D18 and this was no problem. So, I just wait and see what it will bring.
EasyB
Last seen: 4 min 14 sec ago
Wow that should pull a huge current, like 50A with 3 good cells.
b3nault
Got me interested, keep us posted please! Smile
lawallac
lawallac's picture
I had mine done up with Osram cslnm1.23 red leds. I have no words for the flood of red on turbo.
http://budgetlightforum.com/comment/1641498#comment-1641498
b3nault
Yes and yes! tried to get one made but it didn’t seem to fly. Just in my dreams for now.
