[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
514 posts / 0 new
Flying Luminosity
Flying Luminosity's picture
Last seen: 6 months 1 week ago
I̶n̶t̶e̶r̶e̶s̶t̶e̶d̶ ̶i̶n̶ ̶N̶W̶.̶
Wrong thread, didn’t realise this was for the XHP50.2 version.
AlexGT
AlexGT's picture
Last seen: 6 days 19 hours ago
Do you know the specific tint they plan to use on the NW? I am hoping 3A tint
jmbow24
Last seen: 8 months 3 weeks ago
Interested for 2 nw
Dep668
Last seen: 2 hours 55 min ago
Interested, possibly for 3
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 27 min ago
The FT03 with the 3v 50.2 is very nice….
I would be in for a few of them…not for myself…friends…
KB1428 “Live Life WOT
basic42
interested in 1 or 2 NW.
Ramblings
Ramblings's picture
Last seen: 1 week 11 hours ago
Keen!
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
Rah_BE
In for one FT03 XHP50.2.
d_t_a
Last seen: 10 hours 46 min ago
Let’s see if I understand correctly, the XHP50.2 may have around similar lumens as the SST40, but will have a bit more floody (but smoother) beam pattern than the SST40. Also XHP50.2 may (or may not) have a nicer tint than the SST40?
SST40 at low brightness levels will look a bit yellow/greenish.
XHP50.2 beam tends to have a hotspot that’s cooler and a corona/spill area that’s somewhat warmer.
delete
Last seen: 2 weeks 21 hours ago
delete wrote:
ZozzV6 wrote:
AnhTran wrote:
Anyone know why the FT02 is smaller but more expensive than the FT03?
Because of the driver. FT02 uses boost driver which is more expensive. But I think XHP70.2 is too much for this host. Simply not enough mass in the head and no fins just those little ribs on the neck. An L2 head is 90g more weight and it has smaller diameter. With SST40 it has good balance but XHP70.2 is a no go for me in this light. Even a 3V XHP50.2 can make a lot of heat and current.
i agree that XHP50.2 3V is can fit in same driver.
i hope freeme can manage 2 choice
1.xhp50.2 3v on same driver depend not over 35dollar and
2.xhp70.2 with new driver 3X.XX dollar
thank you freeme for my dream
i will collect 50.2 cool white
JasonWW
JasonWW's picture
Last seen: 4 hours 46 min ago
The 50.2 is over double the lumens of what the SST40 can do because it’s a bigger led.
SST40 die is 2mm x 2mm = 4mm2
Xhp50.2 die is 2.94mm x 2.94mm = 8.64mm2.
The smaller die size of the SST40 means it has a narrower beam angle which makes a smaller hot spot and has longer throw.
The 50.2 has much more lumens (making the spill light brighter), but the extra brightness does not compensate enough to give similar throw. It has less throw distance.
The tint on the 50.2 and 70.2 are always a bit wierd due to their flip chip design. Their coronas are always yellow compared to the hot spot.
The older xhp50 had the same color hot spot and corona which looked nicer, but they had a pronounced donut hole beam pattern in SMO reflectors.
So the 50.2 has the weird yellow corona, but at least the hot spot looks smoother with a SMO reflector. It’s the better trade off. I don’t notice the yellow corona much any more.
I can’t comment on the SST40 tint. I don’t have one.
MKayze
MKayze's picture
Will the runtime be the same as the SST40 version?
BlueSwordM
BlueSwordM's picture
Last seen: 46 min 32 sec ago
No, worse runtime.
JasonWW
JasonWW's picture
BlueSwordM wrote:
No, worse runtime.
I don’t know, this is a question of efficiency. If we pick a specific brightness level, like 500 lumen, I’m not sure which will run longer. The 50.2 is 4 x XP-G3 so maybe they will run more efficiently.
On Turbo, the bigger 50.2 will suck up the juice much faster.
HONDARIDER
HONDARIDER's picture
About when is the 50.2 going to be available?
MKayze
MKayze's picture
JasonWW wrote:
BlueSwordM wrote:
No, worse runtime.
I should have asked which will be more efficient at 1000 Lumen.
tittike
Last seen: 2 months 4 days ago
Interested for NW
JasonWW
JasonWW's picture
MKayze wrote:
JasonWW wrote:
BlueSwordM wrote:
No, worse runtime.
Just a rough answer, the SST40 might pull 3.5A at 1000 lumen OTF, while the 50.2 might pull 3A. So it looks like the 50.2 will be a bit more efficient at 1000 lumen.
One thing to consider, the SST-40 will probably look brighter at 1000 lumen than the 50.2 at 1000 lumen because the light will be focused to a smaller hotspot and look more intense. The 50.2 will spread it’s 1000 lumens over a bigger area making it look less intense.
I noticed this when dealing with similar sized lights using the 50.2 and the 70.2. I like 1000 lumen when walking around with the 70.2, but the 50.2 looks just as bright at 600 lumen. It’s about the intensity difference. Since I don’t mind the smaller hotspot, I tend to use the 50.2 at the lower level and get the benefits of less heat and longer battery life.
MKayze
MKayze's picture
JasonWW wrote:
MKayze wrote:
JasonWW wrote:
BlueSwordM wrote:
No, worse runtime.
Thank you for the explanation. By the looks of it, I think I will wait for the 50.2 version rather than getting the SST40 now. Quick question about the throw difference though. What’s the % in throw difference ?
Johm
Last seen: 2 hours 50 min ago
The 50.2 will have 33% less throw than the sst40.
There is a video a page back showing this.
JasonWW
JasonWW's picture
MKayze wrote:
Quick question about the throw difference though. What’s the % in throw difference?
Do you mean both lights maxed out?
The SST-40 should throw farther.
Do you mean with both lights at 1000 lumen? The SST-40 will throw further for sure.
JasonWW
JasonWW's picture
Oh yeah, I forgot about that. It shows both lights maxed out.
SST-40 = 900 meters
50.2 = 730 meters
In you go by distance and not candela, the 50.2 has about 19% less throw. Or the SST-40 has about 23% more throw.
Keep in mind these throw numbers vary based on the battery used and how they are measured.
gzed
Last seen: 4 weeks 13 hours ago
Interested for xhp50.2 NW
MKayze
MKayze's picture
SST-40 = 900 meters
50.2 = 730 meters
Thank you!
delete
i prefer
left hand SST40
right hand XHP50.2 3v
win-win hahaha
JamesB
Last seen: 1 hour 54 min ago
Intradested.
Do we know when this is supposed to be available ?
Thx Freeme.
freeme
freeme's picture
Last seen: 6 hours 7 min ago
Preorder will start TODAY!
JamesB wrote:
Intradested. Do we know when this is supposed to be available ? Thx Freeme.
Satan@103TFS
I’m in …we have to wait for you code right ?
JasonWW
JasonWW's picture
Yes, unless you want to pay full price. Wink
delete
code for for xhp50.2.please
