How solid is the twist operation of your C01S (or variant)?
23 posts / 0 new
phouton
Last seen: 2 hours 49 min ago
Overall I quite like the C01S but I noticed some flakiness in the twist operation of my unit and wonder if it’s the same for others.
Once the light turns on, it must still be twisted further (~8-16 degrees rotation or ~1-2mm twist travel along the circumference). Otherwise in that region between turning on and being fully tightened, slight pressure on the head can cause it to flicker, or change modes, or turn off.
Pressing against the head shows there is some play in the threads. It’s only a fraction of a millimeter of compression, but it’s still noticeable.
In contrast, the Olight i1R 2 EOS has virtually no such compression if pressing against the head. Its switch is different, but when it turns on it does so solidly.
The C01S isn’t bad; I just have to remember to tighten it fully each time, but when I forget, it’s a bit frustrating to deal with the flakiness. Also, fully tightening the head makes it “stick” a little due to compressing the O-ring at the end of the thread travel, and that makes the operation less smooth.
Do all C01S behave this way?
maukka
maukka's picture
Last seen: 8 hours 58 min ago
Sounds concerning. My C01S hasn’t arrived yet but all of my original Yuji C01 are perfect.
iamlucky13
Last seen: 1 min 16 sec ago
What you’re describing sounds similar to mine. I suppose it’s less than perfect, but seems acceptable to me.
hank
hank's picture
Last seen: 1 hour 2 min ago
Yeah, I’ve seen the “barely off but easy to turn on by wiggling” thing happen with several kinds of little AA twisty lights.
A nuisance if it happens in a pocket. “Why are your pants glowing” isn’t the kind of question a flashaholic appreciates hearing.
phouton
“Less than perfect” is an apt description.
It’s certainly still usable, and I do tend to be picky. However, I didn’t notice anything indicative of a manufacturing defect. The clip on mine broke when I was trying to remove it, but that’s another story.
Muggles might be especially frustrated by the behavior. The Olight’s functioning is more as I would expect.
Note that it doesn’t turn on accidentally even if I try to wiggle it. If twisting more than 2mm past off, there is no problem. It’s really only in a small but critical region where I notice the flakiness.
drewski
Last seen: 4 days 9 hours ago
Similar to mine. I’ve just adapted to it and turn it tightly each time without thinking about it. My old Fenix e01 has even more ability to turn on by pressure to the head, but it doesn’t need to be tightened all the way to turn on like the C01s. I think I’ve overlooked this minor imperfection because of the nice sst20. Thanks for reminding me. EDC01 has a butter smooth action that works well.
djozz
djozz's picture
Last seen: 8 min 1 sec ago
Maybe it has something to do with the bezel not having a hard stop when tightened over the pill, and no glue. You can’t tighten it very hard because then it goes so far over the pill that the light does not switch on anymore. So twisting the head to switch on the light also moves the bezel a bit, twisting the light off may even screw your bezel off the pill. A drop of suitable glue under the bezel may make the switching more reliable.
Bearbreeder
Just get an EDC01
high CRI b damned Wink
phouton
drewski Yes, I really like the SST20.
That description doesn’t sound anything like the C01S. The bezel isn’t loose, and head definitely can’t be tightened too far, since it screws flat onto a ledge on the tube.
I wonder about wear on the PCB’s metal contacts that rub against the tube, and the center contact that rubs against the battery head. They do leave slight marks, so I hope they don’t cause contact issues later.
Bearbreeder I’m surprised at how much I like high CRI after experiencing it in person… gonna be hard to give it up now Silly
how crazy is this
Last seen: 1 week 5 days ago
Keeping the threads lubed will help.
Nismo
Nismo's picture
Last seen: 3 hours 17 min ago
I noticed that on mine, and it was due to the outer reflector ring being slightly loose. Overtightened that so it wouldn’t get loose again, and it was stable. I have five of these now.
Current lights:
Emisar D4V2 SST-20 4000K, D4V2 Ti SST-20 4000K, D4SV2 SST-20 3000K | Fireflies PL47G2 XPL HI V3 3A Lumintop FW1A SST-20 4000K Nitecore LR12 CREE XP-L HD V6 | Sofirn C01S SST-20 4000K, SP10S LH351D 5000K, IF25 SST-20 2700K + 6500K, BLF SP36, BLF LT1 | ZebraLight SC53Fc XP-L2 4000K
phouton
How would that help when the issue seems to be due to play in the threads?
Do you have a picture of what you’re referring to? I don’t see anything loose on mine.
bidas
Last seen: 19 min 45 sec ago
My keychain flashlight nowadays is a EDC01 with a led swap, a sst-20 4000k 95cri
Bearbreeder wrote:
Just get an EDC01
@phouton my Sofirn C01 had the same problem you are describing! But then i lubed it a bit and “voilà” problem solved.
phouton
I’m confused how that could help.
What common household products are good for thread lube?
drewski
I will add that my C01s seemed unlubed and was squeaky out of the box. It was much better after some lube and pulling rubbery stuff off the sides of the contacts on the head.
how crazy is this
I like Syl glyde. Maybe not “common” household stuff but well worth having on hand.
bidas
Without thread lubing is harder to go all the way down, preventing a good contact! I use Xtar X-lube (Silicone grease), but probably you can find something similar in a local hardware shop.
phouton
Oh, I see. Mine has no problem going all the way down to make contact. As I described, the issue happens before it is fully screwed in.
If it has trouble going all the way in, I’d think that would indicate the O-ring needs lubrication, more so than the threads.
The threads and O-ring on mine were very slightly greased when I got it. Not much, but there was definitely something on there. I’ll have to check if we still have some automotive silicon grease lying around.
iamlucky13
I just use silicone electrical connector / bulb grease from the auto parts store. It was $2-3 for a small tube. It only takes a little bit on the o-ring, so a small tube lasts a long time.
Boaz
Boaz's picture
Last seen: 4 hours 33 min ago
Yeah ... was gonna say lube . .. sometimes wonder if threads really need lube or if it's o rings only. I usually lube threads and then wipe them clean so they are slightly lubed . more generous on o-rings and more so on twisty lights .
phouton
I used some silicon lube from a spray can applied with a paper towel onto the O-ring and threads. It seems less viscous than whatever was already on there. The result is just that it’s easier to screw all the way, but doesn’t change the finicky behavior. If anything it seems I really need to screw it down all the way now, since with the O-ring more lubricated, it allows the head to move more easily.
I suspect this is just due to play in the threads. The head has to be firmly screwed in so that it is seated onto the ledge in the tube, otherwise I guess it can rock. The contacts are on the bottom surface of the PCB touching the ledge, so this can cause them to make/break the connection, causing flickering or cycling through modes. At least that’s my current hypothesis. I imagine this is why contacts are often designed as springs.
Unheard
Last seen: 4 hours 53 min ago
All my C01S, C01, Fenix E01, Jetbeam-II MK share this behaviour. There’s some play in the threads, thought this would be normal.
phouton
I now doubt the finickiness is due to play in the thread. Comparing with an Olight I3E, the C01S has much finer threads and less play, yet the I3E has no such issues.
My latest hypothesis is it might be due to the contact patch design. Notice how the C01S has less than half of the circumference of the PCB metalized for contact with the tube’s negative contact. The I3E has nearly the entire circumference available for contact.
The I3E’s tube (negative contact) has a pretty flat contact edge, while the C01S’s tube has a beveled interior edge.
In particular notice the kink at point A showing an enlarged bevel. I suspect that the head’s contact protrusions have been acting as a drill bit starting around point B until stopping at point A where the difference is most pronounced. There is a similar pattern 180 degrees away. This means the contact is at an angle and has now become more distant before making full contact. This might explain why I now need to screw the head in fully for the light to turn on solidly, compared to when it was brand new (not even a month ago).
Notice how the C01S’s head contact area is protruding like a drill bit. The metal is uneven and has either worn off at the very edges or was not fully coated. Wear marks show contact is made near the edge, which might explain flakiness.
Overall, I’ve been happy with the twisty style of operation, but the C01S’s implementation leaves something to be desired and gives me concern for future reliability.
I’m not certain of this diagnosis, but surely the following recommendations wouldn’t hurt:
  • no beveling inside the tube, only deburring, to allow larger and flatter contact area
  • metalize the head’s negative contact all the way to the edge
  • increase fraction of the circumference that is metalized
  • consider a circular PCB instead of one with protrusions which can act as a drill bit
The last point might not be possible with the current implementation since based on the wear marks, the contact seems to be made just at the border of the diameter of the PCB without the protrusions. Maybe that is why the protrusions are there in the first place…
